prizeframe
Flight Technicians And Others: Strange Questions?
Fri Nov 16, 2012 4:03 pm
I just wrote another thread about preventing airline equipment failures, as I'm a student doing research on making flight maintanence more fun, productive and profitable. It showed I was on the wrong track, and found out thanks to Starlionblue and tdscanuck here on the forum. But now I'm gonna find some new interesting subjects, and hope you can be of any help.
It doesn't have to be Flight technicians (can be other professions within the airline industry as well.) But that's what I'm going to focus on right now.
As a flight technician (or insert what you are here) what are the biggest problems you face on a day-to-day basis?
● What’s the most painful task you have day-to-day?
● What takes up most of your time?
● What are you currently doing that frustrates you?
● What tasks are you doing that you believe can be made easier or less tedious?
● What are some of the repetitive tasks you have to do on a daily basis?
I would just like to learn about the pain points you experience in your profession.
I would love to hear back from you, even if it is only one sentence!
Thanks! Looking forward to start an interesting discussion.
[Edited 2012-11-16 08:04:53]
Tristarsteve
RE: Flight Technicians And Others: Strange Questions?
Fri Nov 16, 2012 5:42 pm
I work on the ramp on line maintenance. The aircraft come from, and return to their main base.
I have been doing this job for a long time now and the biggest problem is boredom!
Aircraft are becoming so reliable that we don't have much to do. An A320 can fly all day, say five
flights and arrive at my station for a night stop with Nil defects. I look in the maintenance computor and there is nothing there either. I check the display in the flight deck and the oils and tyre pressures are all OK. All that is left is to walk around the aircraft checking for damage, and repairing some defects caused by passengers. This is normal. Because aircraft are so expensive when they are not flying, it pays my company to pay me to sit here so that once in a while I can make some repair and get the aircraft away. But nowadays most of those repairs are computor related.
I can look at the display from Airman. I log into Airbus web site and see my airlines page. We have 110 A320 series aircraft. They are all displayed on the screen with the most broken one at the top. There is one in red, it is in the hangar at main base. There are four in yellow. They have defects that might affect their next departure. There are 105 with NIL defects. It is becoming a problem on the line to keep proficiency. We read about other peolples problems, because we don't have enough of our own!
30 years ago I worked on the line at the main base for a fleet of Tristar aircraft. We were busy! There was always something to do. Times have changed. Aircraft are much more reliable than before.
The main thing that would make my life better is for the aircraft to tell us when it is going to break down 2 hrs in advance. Then we could sit at home, and come in when required!
tdscanuck
Fri Nov 16, 2012 8:36 pm
Quoting prizeframe (Thread starter):
I used to be a service engineer (guy at an OEM who helps airlines when the manuals they have don't cover the issue) and have also worked in an airline's engineering department. So what I saw was only what annoyed the mechanics enough for them to elevate it to engineering, but for whatever it's worth:
Finding part interchangeability. When something is dead and and you don't have an exact replacement but you've got a similar part, is it legal to go on the airplane? You would think this is an easy question but, thanks to age, AD's, and upgrades, it's usually not.
Paperwork. Rule of thumb was documentation took 2x the time to do the actual work.
Wading through manuals looking for the information I actually need.
Wading through manuals looking for the information I actually need. The latest iSpec 2200 manuals help a lot but the interfaces still aren't great.
Tom.
n901wa
Fri Nov 16, 2012 10:58 pm
As a Aircraft Inspector, I have not had too much day to day painful task.
Paperwork, Looking up Serial Numbers and Part Numbers and IPC refs. to make sure the parts are not restricted and can be used on the type of acft the mechanics are working on. Logging in all the steps in the work you are overseeing. Don't get me wrong, That is a Inspectors job, and I love it.
The only thing that drives me nuts at work, is using the Airbus A330 SRM for repairs. The manual is very hard to follow, and even if you get the Weight Version right, and tail number correct, it can lead you down a path that is not correct for that series of A330. The A320 SRM is ok, and I think its because the A330 has many WV. Don't get me wrong I like the other Airbus Manuals, and think Air Nav is great.
Looking up RII (required Inspection Items) On overnight work packages, could be coded better, and looking up EAs, ERAs could have a better search system.
I come in and Check all the Workpackages for anything that might require a Inspector to sign off at My station, and stations in my region, and plot my work for the night. I then check the out of service acft in my region to see if a Inspector can help, and set up a road trip if needed. That's about the only thing I do everyday that is the same. The rest of the night changes everyday   So again, I am not complaining, I LOVE my Job, and enjoy every day I go to work
Its amazing in my short 25 years working on aircraft, I am lucky to have worked on soo many types of Airliners, and enjoy learning something everyday.
Legs
Sat Nov 17, 2012 12:23 am
Just for comparison's sake, I dont work in the airline industry, rather I maintain fighters for my country's air force, swinging between the workshop and the flightline as needed.
The most frustrating job we have is a couple of the item servicings we are on the hook to do. A couple are 15-20 mins to do, but double that for the paperwork. Rinse and repeat 10 times a day, it gets pretty tedious.
Paperwork. Because we are civilians contracted to the military, for a lot of our work all our certifications are done in triplicate, in three different formats, on three different computer systems.
Parts availability. We are at the very end of a incredibly long logistics train, and as such we get the lowest priority (or so it seems sometimes). Things like ITAR restrictions, security clearances and sole source contracts make things very painful.
Streamlining things is one of our big focal points. We've made a lot of little changes, as well ordering or making specialised equipment and tools to make our jobs easier. And we keep pushing management to try and overcome some of the other problems that we cant control directly, but thats a much harder proposition
Like I mentioned before, we have to service a few different items very regularly. One in particular has to be tested every 30 calendar days, so testing those is takes 2 to 3 days a week for two people. Also, a few of our test benches require daily before-use servicings, which gets very tedious as well.
Hopefully that gives you a slightly different data point to all the line guys here.
fr8mech
Sat Nov 17, 2012 1:37 am
I ride a desk. My job is to monitor and assign folks to research chronic problems on aircraft. Then they are to develop a plan to correct and sometimes execute the plan they develop. I have to approve any plan developed. I also approve moving a chronic problem into watch status after the plan has been executed.
Going through my open work tasks and seeing a chronic problem return after executing the plan.
Doing my task audit for CAT and ETOPS chronics.
Really? Not much. I guess its frustrating when you have a problem you can't get a handle on, but that's the job...at least in this office.
I look at every open task, everyday, to ensure that a plan, that makes sense, is in place and the proper tools, parts and materials are orsered for the aircraft in question. I also review every delay taken in the last 24 hours and check the problem against the database and see if a trend is developing at the aircraft level. There is a whole other department that looks at the same stuff at the fleet level.
prizeframe
Sun Nov 18, 2012 5:13 pm
Thanks for all the answers. Very interesting! I'm gonna dig deeper in all the info you've provided.
CanadianNorth
Mon Nov 19, 2012 5:14 pm
Aircraft maintenance engineer here, mostly working on the turboprop fleet but also partake in some 737 work.
Hangar doors. I've submitted multiple safety reports and had a wcb claim with our hangar doors.
In the winter, keeping us and airplanes warm. In the summer, probably paperwork (I don't mind paperwork though, means I get to sit in a comfy chair in a warm office instead of rolling in a puddle of grease out in the yard)
Babysitting other departments is an on-going frustration for our department. Our airline has this culture where everyone sees maintenance as the responsible ones and thus expects us to check for and fix things that other departments do wrong. Ramp forgets the engine covers, we have to go do them. Grooming forgets something often we get the first phone call. It frustrates the heck out of most of us.
Probably a bigger hangar. It would solve much of our heat and hangar door issues, as well as making it a much more pleasant work place, not to mention noticeably increase production.
Moving airplanes in and out of the hangar, deep cycling batteries, daily inspections, a checks, reconfiguring (the majority of our fleet are operated as combis). Though most of that work I don't mind, it's nice to have some simple and easy parts to the day.
Overall I'd say really the only painful part of our job is lack of facilities, and most frustrating is being expected to babysit other departments. Other than those two points I quite enjoy my job. It isn't perfect, but the benefits are nice, the people are great, the work is generally pretty rewarding, and it seems there is always something new and exciting happening. In 5 years I don't think I've ever been bored.
Way to go, nice and slow, never late, 748!
737tdi
Mon Nov 19, 2012 8:12 pm
Quoting tdscanuck (Reply 2):
Tom.
Tom, You hit it right on the nose.
My biggest frustration is paperwork. It just keeps changing, changing and guess what? Changing. We have been through 3 logbook changes in the last 4 years. That may not seem like a big deal but the last 2 have been in the last 2 years.
They are minor changes, but major problems. Date format, station info., when caused, UTC v local time, oil servicing, tire servicing, sign off data. It goes on and on and on.
Conditional inspection references??? I have to research the exact reference to sign off a bird strike, overspeed, ramp rash, etc. etc.. It is really getting to the point of aircraft delays are built in now.
Actual aircraft maintenance takes i.e. 1 hour, paperwork takes .5 hours. Wow, things sure have changed over the last 30+ years. Hell, we now have to call for parts compatibility, on things like coffee makers??? They are compatible with all of out aircraft but we still have to call. Ridiculous.
To answer the OPs original question. It is paperwork that causes the biggest headache for Mechanics/Techs/Engineers. It is not the work. We experienced guys know how to replace parts and troubleshoot. We just have to figure out the sign off to be correct. Again, ridiculous. Take all of this in stride, it still is not terribly difficult.
320tech
Tue Nov 20, 2012 5:56 am
I am an aircraft maintenance engineer, working for a major airline in a small station. The answer to all of these questions is the same: aircraft maintenance software is absolute crap. Outside of work, the software I use is amazing. Every year, it gets better, faster, easier to use, and incorporates features I would never have thought of. At work, the software gets less intuitive, more demanding, more time consuming, and less useful.
I am currently using TRAX to enter snags. It is garbage. No one would use this software by choice. I hope the accountants are getting a benefit from it, because we do not. Their website looks like a failed community college assignment. http://www.trax.aero/index_main.htm
And yet, TRAX is not the worst system I have to use.
The only other real issue I face is lack of parts. But I'm used to that now.
The primary function of the design engineer is to make things difficult for the manufacturer and impossible for the AME.
Tue Nov 20, 2012 10:42 am
Quoting Tristarsteve (Reply 1):
Your post was just so true.......
Night shift fatigue esp between 0300hrs to 0500hrs can get tough.Finding a snack can be tougher due lack of free time.
Paperwork would def count as the least best.....
Again Paperwork, it takes almost 50% of the time, to get the documents in place,go thru them, complete the job & fill in the paperwork.
Night shifts on the same Type of Aircraft.But I try to study about other types too,keeps me busy.
A Reduction of paperwork & incorporation of more technology would def help out.
a Transit check Inspection is the most common in Line Maintenance...
Would love to work alongside passionate Aviators,that enjoy the job.....Not to many left around these days .....Sadly.......
tdscanuck
Tue Nov 20, 2012 1:56 pm
Quoting 320tech (Reply 9):
Although I agree with you in general, I worked with AMOS at one airline and absolutely loved it.
http://www.swiss-as.com/main.do
Which just makes some of the other offerings that much more painful...the industry knows how to do it better, we just usually choose not to.
Tom.
m1m2
Tue Nov 20, 2012 5:14 pm
To 320Tech, I have used TRAX and agree that it is not a very user-friendly program. There is a lot of potential there once you get used to it, but I still don't like it.
Wed Nov 21, 2012 8:08 am
Yeah....we used to use ARMS, now its TRAX......
JAGflyer
Thu Nov 22, 2012 6:57 pm
Quoting tdscanuck (Reply 11):
From the publication side I work with AMOS and find the program the module under developed in all many areas. At my airline we still use paper and hard copies (CD, etc) distribution so in order to manage and track who has received a document I still need to send out paper sheets to get signed. AMOS cannot be set to print a simple acknowledgement form with only the copy number and corresponding location changed. Instead its acknowledgement form lists ALL copies and ALL locations. Therefore I need to resort to our old form which we must manually fill out by hand. Another huge issue I find with the publications module is the lack of ability to bulk any changes to a set of documents. IE. we send 50 documents to a station that operates for 4-5 months. When the documents are returned I must MANUALLY go to each document's entry and remove it's copy from the location it was in. Why not just allow me to delete the location and all copies of documents at it?! Sure, I have some likes about AMOS but I still feel more comfortable at this point with our manual way of tracking that documents are received and previous revisions distroyed.
Hopefully the rest of the airline will come onboard with AMOS, mainly the AMEs as right now only office staff, stores, and accounting are using it....
[Edited 2012-11-22 11:04:57]
Support the beer and soda can industry, your recycle old airplanes!
tdscanuck
Thu Nov 22, 2012 11:30 pm
Quoting JAGflyer (Reply 14):
I never touched the pubs side of it; I have no reason to think your experience is unusual (I have yet to hear of a really great publication module from anyone). I worked almost exclusively with the job card, spares, and AD modules. I found those great.
Tom.
twincommander
Mon Nov 26, 2012 8:48 am
knowing that i may not get a call...
Paperwork. no reason to screw this up. you can get in more trouble for not writing correctly, than you could with doing an improper task...
some of the MOC controllers i deal with dont exactly know the aircraft they are having me fix...
theres always tasks that i feel that i can do faster, better, ect :p
Gate tows, jump starting our vans, more gate tows, and MD-80 call outs.
Mon Nov 26, 2012 8:03 pm
Quoting twincommander (Reply 16):
what call are you reffering to.....
twincommander
Mon Nov 26, 2012 9:24 pm
Quoting HAWK21M (Reply 17):
a call to come fix or defer a mtx problem.
charlienorth
Fri Nov 30, 2012 3:00 pm
I'm a Maintenance Controller..the things I cannot stand are mechanics who call me up and ask "what do you want me to do?"...I want you to fix the airplane! Ask your lead ask your foreman do not ast me what to do..you will not like the answer I give you..you will be shoulders deep in the airplane! Now this does not apply to the FBO mechanics, just the guys at our own stations,
Now I will tell you besides this issue I love this job, after 20+ years as a tech this is the place to be and I would not trade it for anything!
Work hard fly right..don't understand it
Sat Dec 01, 2012 6:10 pm
Quoting twincommander (Reply 18):
Still dont get it...Maybe its the language.....Are you saying the AME on the allocated aircraft developing the same does not attend it, or is underqualified.
Quoting charlienorth (Reply 19):
True....As a Qualified person,he should take the responsibility as per action needed,unless the actions were more than one & a decision at a higher level needed to be taken.
m1m2
Sat Dec 01, 2012 6:39 pm
I think twincommander is saying if he doesn't get a call, it's a long day. He wants to be working on an aircraft. Did I get it right?
Sat Dec 01, 2012 6:45 pm
Quoting m1m2 (Reply 21):
Get a call......Is it getting a Call to attend a snag at work from home.......
m1m2
Sat Dec 01, 2012 10:31 pm
Hmm, you're thinking he may be "on-call". That's possible although I was thinking he's in a maintenance office at the airport.
Sun Dec 02, 2012 10:01 am
Quoting m1m2 (Reply 23):
If a person is getting a call,it means the original people on that Aircraft are not qualified or unsucessfull in doing the job.
MD11Engineer
Sun Dec 02, 2012 11:17 am
Quoting HAWK21M (Reply 20):
IMO, tech services / maintenance control are the last resort if you have done everything in the books and still get no result. They are not an excuse for laziness on behalf of the tech on the ramp, who can´t be bothered to read the manuals.
Sometimes though you have exhausted every troubleshooting procedure the manual describes and all of you experience and knowledge and still can´t find the fault. Then it is time to call maintrol, backed up with full documentation of what you have done, and let him sort out the problem in cooperation with the aircraft manufactuer´s rep.
Sometimes you also discover that you can´t progress due to lack of special equipment or parts, which´s shipping to you will have to be organised by maintenance control. But again, you should have done YOUR work and be able to provide a complete documentation.
Maintrol is not supposed to support lazy techs.
Jan
fr8mech
Sun Dec 02, 2012 6:45 pm
Quoting MD11Engineer (Reply 25):
I wish everyone had that mindset. Then my folks could get on with their actual job, which is to deal with chronic problems.
Mel, I believe what he's saying is that the hardest part of his job is waiting. Just sitting around waiting for a line call from the flight crew. And, then, since it's a line environment, just deferring the item (if he can) instead of actually fixing it.
The boredom of a line mechanic.
Sun Dec 02, 2012 8:01 pm
Quoting fr8mech (Reply 26):
Its true.....The Line guy needs to get the Aircraft departed on time with minimum delay as possible.....So if deffering a snag is an option, then thats priority.....if one can rectify the snag with paperwork & have no elay then thats ideal.
twincommander
Thu Dec 06, 2012 5:27 am
i work for a company who provides contract maintenance to airlines who flight into and out of PDX, we have several stations through the US. im currently part of the "on-call" team. when im on shift, i do our scheduled stuff like gate tows, and the scheduled morning standby for one airlines critical departure. after that i sit at the office and wait for the phone to ring. in regards to Mel asking if i come out to a call after someone else cant fix it, well, thats kinda true as well, as my offical title is seinor technician.
we also provide other services for other airlines who need more than just someone hovering over the phone all day. Our scheduled maintenance guys do just that, transit, line, and time items for a couple of airlines. Im probably going to be doing both at the begining of the year for a new contract that we got.
i guess one of the things i should have said regarding the OPs questions was this - Getting multiple calls at once with just me on duty, is one of the thrills of my job, and i actually look forward to those days.
Quoting HAWK21M (Reply 27):
Deferred maintenance is preferred maintenance. :P
unfortunately, alot of our contracts state we contact maintenance control first, and do as they say. its also set that they provide up to date manuals for their aircraft. i would much rather have, or have access to the documentation i need to get the job done, however, the airlines dictate how they want us to proceed. we also dont manualy enter defects or log entries into their respective computer systems, so calls to maint. control are required for them to issue authorization numbers.
to counter point on controllers (dont hate me), i dont like controllers who dont know what they are talking about, or who i cant understand without me asking them to repeat themselves over, and over, and over...
MD11Engineer
Thu Dec 06, 2012 10:40 am
Quoting twincommander (Reply 28):
The European system gives the tech a bit more authority. He doesn´t have to ask anybody if he can defer something or what action he is going to take, as long as it is legal, but he has the full responsibility.
What I don´t like is bosses who don´t understand the difference between ad hoc line maintenance and planned and scheduled base maintenance, which is like factory work.
They don´t like us sitting in our office if there are no problems (but somehow they always happen to visit our office if there is no work, but they never come over when we are up to our neck in AOGs), so they try to dump additional work on us to do when there is no aircraft to fix. They don´t see that we don´t take scheduled breaks if there is a broken plane and often work 12 hours straight without break or do overtime to get a plane back into the air, but they see us sitting in the office when there is no work and consider us to be lazy.
A few months ago I had to change an APU on a 747 with a mixed crew from the base and my line team. We were in the middle of the work when suddenly the break chime rang in the hangar we were working in. Quick as lightning all the base guys were gone for break, only us linies continued because we knew that we had to get the plane ready for departure ASAP. Similarly most (though not all!) of the base guys close their toolboxes 15-30 minutes before shift end. Very few of them see the need to stay on to get the work finished. Most have the attitude "the next shift can do the job".
Jan
DarkSnowyNight
Thu Dec 06, 2012 1:38 pm
Quoting MD11Engineer (Reply 29):
Is it really attitude, or company policy? Part of what I like about my job now is that there's no practical limit to overtime, as long as it's billable. But when I worked in a hanger at one of the majors here, we had a pretty strictly enforced pass-down policy regarding open work at the end of shifts. The airline was watching OT like a hawk, and these people (base mx, that is) could actually get themselves in trouble staying late w/out authorization. Of course, yes, this leads to closing up boxes and signoffs before the next shift. Could that have been the situation for your company too?
I do agree that breaks should have been better managed though.
Be A Perfectionst, You're Nothing If You're Just Another; Something Material, This Isn't Personal...
Thu Dec 06, 2012 5:50 pm
Amazing....that never happens out here..........In the midst of a job....our break is ALWAYS delayed....no one quits without permission and def not in between a task that cannot be left halfway.....
fr8mech
Thu Dec 06, 2012 9:12 pm
Jan, I don't think that's a difference between the European system and the American system. I worked for 2 carriers that allowed the AMT to defer items on his own, excepting items with flight restrictions (he needed concurrence from Flight Control). He owned all the responsibility of ensuring that the aircraft was in compliance. The other 2 carriers I work(ed) with required Maintenance Control contact.
It's a difference between carrier SOP.
At least it was several years ago.
twincommander
Fri Dec 07, 2012 2:50 am
an airline i just got AWR for does NOT want us calling them for MEL's. this is awesome in my eyes. they gave us access to their tech pubs. so unless its an item that cant be deferred, i have no need to make a phone call. just notify that captain of the a/c status and send him on his merry way.
When i was in 747 school, i met an engineer from the EU. this guy was brilliant. he explained to me how he could only have 5 ratings on his license, and if wanted to work on something else he would have to remove one of his ratings. is this how it is with all EU type maintenance ratings?
MD11Engineer
Fri Dec 07, 2012 5:22 am
Quoting twincommander (Reply 33):
I don´t know. I currently have six type ratings on my licence (each version of the 747-400 with different engines counts as a seperate type) and a seventh being in process, and have no problem with this. I just have to prove that I´m current on the respective type I´m working on, but, at least for the German LBA one sign off within 6 months is enough. E.g. I didn´t work on the MD-11 since about six years (since I went to another company / airline, which doesn´t operate this type), so I either need a refresher type course or I have to work for a while under supervision if I suddenly had to work on an MD-11 again.
Jan
twincommander
Sun Dec 09, 2012 11:08 am
Quoting MD11Engineer (Reply 34):
there isnt much different between them, except for indication and TR operation.
i find it funny how much different things are when you cross a border...
DarkSnowyNight
Sun Dec 09, 2012 12:08 pm
Quoting twincommander (Reply 35):
You mean not much different about 744 powerplants? There's a lot different about them. Maybe not a lot you'll see on a Transit Check, or what you see on an EICAS, but take apart a RB211 and a PW4062 sometime and you won't confuse them, that's for damned sure.
There's not too much extra we need to know if we're just ever seeing them off at the gate, or locking out HPSOVs or like that. But for all we know, perhaps what MD11Engineer's company has him doing is more along the lines of an Engine B-check, or heavier, in which case, yeah, I would think they need the maximum level of systems training and specialization available.
twincommander
Mon Dec 10, 2012 3:35 pm
Quoting DarkSnowyNight (Reply 36):
they suck and blow, right?
im well aware of what the differences are. the chances of me working in an engine shop, however, are very significantly slim. im also aware that each engine has different design philosophies.
we could discuss ad-nausem what the differences are to a T, but in reality, if i have a serious on-wing issue with a power plant, most likely, im going to be asking the airline to send me tooling, and lots of it.
737tdi
Sun Dec 16, 2012 7:39 am
I partially agree with you here. The one thing at my airline is that when we are downline for an OTS aircraft, maintenance control is our supervision, parts getter and lead. We are required to maintain contact and advise them of our conclusions for the repair. They can and do override our decisions, say we have a discrepancy with a history of failures, they will attempt to troubleshoot from their desks and have us change other parts even though we think the problem is repaired.
Sun Dec 16, 2012 9:39 am
Quoting 737tdi (Reply 38):
The Ame certifying same needs to be convinced of maintrol decision too.
MD11Engineer
Sun Dec 16, 2012 3:31 pm
Quoting twincommander (Reply 37):
First, it is not only the engines, which are different, but in most cases the airframe / engine interface as well. So the differences will affect at least chapters 21, 24, 26, 30, 36 and possibly 22 and 45 as well.
E.g. the PW2000 on the 757 is a purely FADEC controlled engine, while the RB211 on the same aircraft still uses mechanical control systems.
Secondly, we are doing about everything in the AMM (our company does line maintenance as well as base maintenance up to C-checks). I personally do a lot of boroscope inspections on the various engines I have entered in my license.
I´m prinarely working in line maintenance (as a shiftleader and supervisor), but occasionally I have to help out in the hangar during C-checks and bigger maintenance tasks, like landing gear changes etc..
Jan
[Edited 2012-12-16 07:35:35]
charlienorth
Tue Dec 18, 2012 3:07 pm
That I don't have a problem with..it's policy, FBO's too...I just have a problem with tech's at our own hubs asking very basic questions that should stay at the gate.
AMT's are highly skilled people paid to make decisions as well as for their mechanical skills and it's kind of embarassing to hear some of the things we're asked.
737tdi
Tue Dec 18, 2012 11:53 pm
Quoting charlienorth (Reply 41):
The only time I call MC at home is to clear MELs or MX notes or if I face a dilemma that I have not seen. Realize that you guys deal with all in service aircraft problems and may have seen something that we as mechs haven't. I'm talking very rare occasions but it does happen. I have been doing this aircraft maintenance thing for 30 years and I still get problems that I haven't seen, I learn something almost everyday. You just have to say "What the hell".
Example: I had a gate call (this one is odd), when the FO adjusted the temp. control from manual to normal on the air conditioning temp. control the #1 fuel tank quantity indicator would fluctuate. Weird huh? I called my lead out and he was boggled. We took the aircraft out of service thinking an electrical short in a wire bundle or something similar. Ended up the mix valve was pulling excessive current to operate and this was inducing current into the FQIS. Come to find out the wiring runs in the same bundle. Replaced the mix valve and all was good.
We are all one team in maintenance and if you can help keep an aircraft in service that is why you are in the position you are in. I understand your point, we should be able to repair most problems but every once in a while we may need assistance. Thanks for what you have to deal with, I know its got to be a tough job.
charlienorth
Wed Dec 19, 2012 2:16 am
Quoting 737tdi (Reply 42):
Thanks! and we learn a lot from you guys in the trenches, it's cool when a tech calls back after one of those unusual items and tells us what he's (she's) found..believe me it goes in the notes we keep
Wed Dec 19, 2012 6:46 am
Quoting charlienorth (Reply 43):
True.....its very common that a snag on one type can occur on another aircraft of the same type at a later date & so similiar too.
Users browsing this forum: BravoOne, CrackInspector, whywhyzee and 17 guests
