ferpe
Pallets Or LD3s And How Do You Restrain Them?
Thu Nov 22, 2012 10:19 am
Looking at the cargo capacity of the new generation of frames /787, 350, 777X) what is the prioritized cargo format (Palets, ULD) for normal passenger frames which also ads cargo under the floor after the bags have taken their part.
I guess what I am really asking is; for what format will the framers optimize their cargo hold? Some thread stated ULD in the back and pallets up front, true? I am disregarding the bulk area at the extreme back of the frame in this discussion.
How tight are the ULD / Pallets packed and how are they retrained? I have seen the typical T shaped locks you put in the moving direction (red in the picture) but do these really hold the cargo sufficiently? Do you deploy automatically or does a person follow the pallet / ULD and put up the locks manually to hold it in position?
http://i298.photobucket.com/albums/mm262/ferpe_bucket/777-200cargohold.jpg
Cargo hold of a 777-200 with the locks in red and the electrical rubber wheel Power Drive Units (PDU) which pull the cargo in the desired direction recessed in the floor.
It looks there must be wiggle room as these locks are only placed at fixed distances on the rails. For me I would like the cargo locked down from the sides as well where you are dimensionally fixed ie any lock would be a tight fit and hold the cargo fixed to the floor. I such case how you do cater for the different pallet sizes and ULDs?
Non French in France
strfyr51
RE: Pallets Or LD3s And How Do You Restrain Them?
Thu Nov 22, 2012 3:35 pm
the pallets and LD units are a std size and the cargo pit is spaced for the load to be rec'd. 88X108, 88 X 125 LD3,LD6, LD11 and there are side guide rails to keep the pallets or "cans" in place because were the pallet locks to fail or not be there?? the noise of banging cans in the pits would scare the passengers and pilots half to DEATH
9MMPQ
Thu Nov 22, 2012 6:09 pm
Quoting ferpe (Thread starter):
In general the framers provide the options to fly various configurations of pallets and containers. What is used will typically depend on the nature of cargo booked while loading positions are determined by weight & balance so as to keep the aircraft flying straight & level.
How tight are the ULD / Pallets packed and how are they restrained? I have seen the typical T shaped locks you put in the moving direction (red in the picture) but do these really hold the cargo sufficiently? Do you deploy automatically or does a person follow the pallet / ULD and put up the locks manually to hold it in position?
Once loaded everything is packed together quite tightly. You have mentioned the red locks in your picture already which (if all 4 are available) are certified to hold a pallet of up to 5 tons in place. These are put up manually. Strfyr51 has already mentioned the side guide rails which have a number of restraints fixed to them, the edge of every pallet or container slides underneath these restraints. All of these together will keep your pallet or container firmly in it's place and will prevent movement in any direction.
Hope that answers your questions
[Edited 2012-11-22 10:14:03]
I believe in coincidences. Coincidences happen every day. But I don't trust coincidences.
ferpe
Thu Nov 22, 2012 8:02 pm
Thanks both, answered all my questions. But there are more  :
Now one can see the central isle locks being raised in the picture (probably prepared to load LD3s) but these would have to be lowered otherwise the loading would be difficult (drawer effect between side wall and central locks)?Why are they then raised in an empty cargo bay?
Also what decides if a forwarder packs things in a ULD or a pallet? In understand a pallet gives more freedom for large goods but additionally tare weight of the pallet (only a plate) should be lower ie if things can easily be stowed on a pallet this is the lower weight variant and therefore more economical of the two? What about the airliners tariffs, are these neutral between ULDs and pallets ie for same volume and weight taken one charges the same price?
Which takes longest to load ULD or pallet?
B777LRF
Thu Nov 22, 2012 8:59 pm
Just for good measure. ULD = Unit Load Device, and that covers both containers or pallets. Thus saying "ULDs and pallets" is a bit like saying "aircraft and biplanes".
Anyway, some aircraft (like for instance the B777) has a lower-deck hold that is certified for loose loading. This means that ULDs can be stack-loaded, which is to say there's no locks securing each ULD individually, but rather a set of locks near the front or back of the hold securing the entire stack. Stack loading is, generally speaking, only possible if the hold is completely full, otherwise ULDs will be locked down individually.
As for distribution of ULD types it very much depends on the operation, the airline and the destinations served. In most cases, however, passenger airlines will load LD3 (AKE) ULDs in the aft hold containing passenger bags, and load P1 or P6 size ULDs in the forward hold. Reason for that is ground stability; you load the aft hold last and un-load it first, and passenger bags usually take priority over freight.
The only time ULDs are locked to the side of the aircraft, instead of using the laterally placed locks, is when you load 16 and 20ft units on the main-deck of a freighter.
From receips and radials over straight pipes to big fans - been there, done that, got the hearing defects to prove
ferpe
Thu Nov 22, 2012 9:58 pm
Quoting B777LRF (Reply 4):
Thanks, I also thank you for explaining some of the thinking behind container or pallet.
More questions comes to mind:
- What frames would be cleared for loose loading in the lower holds more then 777? 787? Any A types?
- Are one in general free to load what a hold can take in terms of ULDs and mix and match to get maximum capacity (ie if it is OK from weight (pressure on hold floor) and CG). Or are there restrictions from the framer on this (I am only asking for the A and B double isle frames) and if so what would these be (except for floor loading or CG restrains, which are pretty obvious).
9MMPQ
Thu Nov 22, 2012 11:22 pm
Quoting ferpe (Reply 3):
These are indeed for LD3s. Usually the first few locks are set up, a few LD3s are loaded & then you repeat this again until all are loaded. With well used LD3s and a less then brand new PDU system there's always a few you'll need to push and shove a bit to help them get in their place. Unloading is a bit easier and it's quite possible they have left them all up during unloading. Alternatively there's also the practice of putting them up once you're done so the next loading crew to come on the aircraft can see that all are in working order.
I assume you are meaning the LD3 or a pallet here. Dimensions & weights of the cargo being shipped are the name of the game here, obviously the container is much more restricted in what it can take. Tare weight is not a concern.
Assuming agents have delivered the cargo loose for the airline to build it up, yes.
Generally pallets are the easiest to load. Containers are a bit more difficult but not very much more.
Quoting ferpe (Reply 5):
Add any aircraft that can take LD3s, it applies to both manufacturers.
You've got it right, provided you stick with maximum weights per hold or zone and CG remains within limits you're free to make up any load configuration you like.
ak907
Thu Nov 22, 2012 11:31 pm
Most LD3 locks are not T-shaped, they are rather L-shaped. LD3's are held down by center locks and side locks, which are T-shaped. On some planes there are also I-shaped locks that retract electronically, you can see them in the picture you posted (the two gray flat bars, bottom right). Like B777LRF mentioned, LD3 can be stacked with no locks in between them, only at each end. The center locks you were wondering about that are up, most of them are on a hinge and spring loaded so that when a pallet rides over, it simply pushes them down and they pop back up after.
- As far as I know, loose loading is only allowed in the bulk compartment.
- Each hold will have several arrangements available. For example, you can have 4 pallets and 4 LD3's, 3 pallets and 6 LD3's, or maybe all pallets or all LD3's. They are many more configurations. Most of the time they are enough locks to allow any configuration without having to rearrange locks.
- Pallets are usually quicker to load simply because there are less of them. 2 or 4 LD3's can take the spot of 1 pallet.
http://imgur.com/a/hUefk Here are two terrible pictures taken with my old phone. You can see there is little room once loaded with LD3's. In the center there are T-Locks, while AKE62591CI is held in place by I-shaped locks.
It's too bad you didn't post this thread a week earlier. I had an NCA 747-8F Loading Manual in my car for weeks, but I threw it away because I didn't need it anymore. It shows every lock in detail and every arrangement possible, downright to how many locks per compartment and their use and location. It would have been perfect for this. I might be able to grab another one tomorrow.
[Edited 2012-11-22 15:34:23]
B777LRF
Fri Nov 23, 2012 2:50 am
Quoting 9MMPQ (Reply 6):
Not quite. The A300s we operate, for example, are not approved for stack loading. I know the 74 and 76 is, but I'm not familiar enough with any other type to say whether or not it's approved.
There are certain practical restrictions when it comes to how you can combine different ULD sizes, but the permutations are quite high. The aft hold of a 777F, for instance, can be loaded in 128 different ways.
Besides the weight limitations per position there are also linear load limits, cumulative load limits and running load limits to take into account. Some of those limits are valid for positions directly above each other (we're talking freighters here), which is to say that a heavy set of ULDs in the aft main-deck may impose a cumulative limit on lower-deck ULDs loaded directly beneath them. There's also the wonderfully named "unsymmetrical load limit" and the equally nice sounding "lateral imbalance limit" to contend with. All this, and you also have to make sure the aircraft is within CG limits, preferably with a nice tail-heavy trim (for fuel economy).
All in all there's quite a bit more to it than just slinging the ULDs onboard, close the doors and light the fires.
B777LRF
Fri Nov 23, 2012 2:54 am
Quoting ak907 (Reply 7):
The lower-deck holds on a 777 is certified for loose loading. In the case of the 777F that means you could, in theory, loose load a combined 52.5 tons in the forward and aft holds. But that is very much in theory; it would be a very cold day in hell indeed before we'd do something as daft as that. But the book says we can.
sunrisevalley
Fri Nov 23, 2012 3:05 am
I notice that Boeing are providing various pallet and LD3 combinations for the forward and aft cargo bays on the 787-8 and 787-9 lower lobe drawings which are part of the ACAP sheets
tb727
Fri Nov 23, 2012 3:19 am
At my company we always leave the locks up in an empty airplane. Just a safety habit I guess. If you always put them up theoretically you won't forget when you have cans or cookie sheets on board.
ferpe
Fri Nov 23, 2012 6:54 am
Thanks all for very good answers, now I know a lot more on how one loads cans and cookie sheets  .
Tristarsteve
Fri Nov 23, 2012 7:45 pm
Remember that not all cargo doors can take a pallet, because they are too small.
All B767 rear doors are for Cans only, and most B767 fwd doors as well. The BA B767 have a B744 door fitted on the fwd hold so can take std pallets loaded lengthways (instead of across like a B744 etc.)
The original B777 also had small rear freight doors.
Our (BA) B767 carries a lot of freight. The dispatcher calculates how many LD3s he will need for bags, and releases the rest of the space for cargo. With small pax loads, this will mean cargo LD3s in the rear. Sometimes with a very low pax load, there will be balance problems with a full fwd hold, so the dispatcher will call cargo and get them to split a pallet down into LD3s to go in the aft hold. We only use LD3s in our B767, so they can go in a B744 or B777 as well.
B777LRF
Sat Nov 24, 2012 1:14 am
Quoting Tristarsteve (Reply 13):
Negative.
A large aft door on the 76 is an optional extra, something most freighters are equipped with. Never seen a 76 with a small fwd door, but won't dispute they exist. If you're only ever going to carry LD3 or LD2 ULDs, having "just" a small door might work for you. I'd hate to be the one trying to off-load them to the second hand market though.
http://i50.tinypic.com/141qfm8.jpg
DHK B767-300ERF. If you look closely enough you'll see large doors both fwd and aft.
Small rear door is standard for pax operations only, on factory built freighters the large door option is often chosen.
http://i46.tinypic.com/28rzeq0.jpg
AeroLogic B777F aft door.
[Edited 2012-11-23 17:20:03]
Tristarsteve
Sat Nov 24, 2012 10:45 am
Quoting B777LRF (Reply 14):
Thanks for info.
British Airways first 5 B777 had small rear doors, all the rest have large ones.
Sat Nov 24, 2012 11:22 am
Most of the folks have been brilliant in their posts as usual.....I cant think of anything much to add as almost what I wanted to state has been said.....
On the B737/757 freighters we use the 88x125 & 88x88 pallets....Containers of similiar size was rejected as the added weight penalty existed on the tare weight of approx 130kgs to 300kgs of a pallet & container respectively.
Loads are pushed manually & locked in place manually too.
ferpe
Sat Nov 24, 2012 12:34 pm
Thanks for the additional answers, every piece of info is appreciated. The net is full of info and pictures of cabins, interiors and seats but very little on what goes under the floor or on both floors on a freighter, I happen to think this is equally interesting   .
Now for someone like LAXDESI or similar to say how much revenue does a 1.5 m of cargo (2*LD3 or 1*LD 6 or 2/3 of a 96in pallet ) bring in compared to 2 rows of economy (8 abrest) on a typical 8-10 hour leg?
I.e. what I am asking is how interesting is cargo compared to pax in Y if one had a weight limit and needs to prioritize (what is the per m price of a cargo hold vs a pax hold) ? This is of course dependant on your routes but lets assume it is a trip from HKG to CDG .
sunrisevalley
Sat Nov 24, 2012 6:44 pm
Quoting ferpe (Reply 17):
I believe cargo density is the first variable to be determined. Below is an extract from a study the link for which is below.
Commodity description Density in M^3
CONSOLIDATIONS 170.73
ELECTRICALS 202.33
FRESH SALMON 266.82
PHARMAC NOHAZ 126.59
NCS FLOWERS 150.00
LEATHER 223.03
COURIER GOODS 184.00
BUMBLE BEES 200.00
VW AUTOPRTS 45.13
MERCEDES CAR 135.57
http://www.tiaca.org/images/TIACA/PD...r%20Cargo%20Density%20Research.pdf
wn676
Sat Nov 24, 2012 9:42 pm
Some of Delta's 763s (the non-ERs I believe) have the small fwd door:
Photo © Michael Arcellana
American's 762s are the same way:
Photo © Chad Thomas - Jetwash Images
Tiny, unreadable text leaves ample room for interpretation.
dlramp4life
Sat Nov 24, 2012 10:15 pm
The LD3 is not the ideal can for 767s but it will fit, you can only fit one a position inside the bin. Your ideal 767 can is the LD2 but other cans can fit:
LD4
LD8
LD11
LD7(even on the narrow door 767) depends on the size of the cookie sheet.
http://www.baworldcargo.com/configs/BAWCconfigurations.pdf
http://www.hawaiianairlines.com/Cargo/containers
http://www.delta.com/content/www/en_...hipping-containers-guidelines.html
Of course I am talking about passenger airliner cargo
Quoting wn676 (Reply 19):
Correct          The DL 763 nonER have the narrow door up front.
SEA Ramp, wettest place on earth
ha763
Sun Nov 25, 2012 1:58 am
Quoting sunrisevalley (Reply 10):
Boeing has the same information in the ACAP for all their widebody aircraft. The individual airlines' loading manuals have way more loading configurations.
Quoting dlramp4life (Reply 20):
There is no way a LD7 will fit through the 767 narrow door. A LD7 is either 88 x 125 in or 96 x 125 in. The 767 narrow door is 70 in wide.
dlramp4life
Sun Nov 25, 2012 8:45 am
Quoting ha763 (Reply 21):
Narrow Cookie sheet, offloaded one tonight out of the back bin of a 763. I know an LD7 is 88 x 125 or 96 x 125 but I don't really know what to call it...
DarkSnowyNight
Sun Nov 25, 2012 9:45 am
Can't answer your question, but I can say that most cargo runs will not be 8 - 10hrs, even w/ twin aisle aircraft. This is part of why cargo operators will trade away a lot of range for raw uplift capability.
Be A Perfectionst, You're Nothing If You're Just Another; Something Material, This Isn't Personal...
9MMPQ
Sun Nov 25, 2012 9:55 am
Quoting dlramp4life (Reply 22):
Going with the IATA codes we use normally these would then be: P1P for 88 x 125 & PMC for 96 x 125. Never heard them being called cookie sheets, learned something new again
I.e. what I am asking is how interesting is cargo compared to pax in Y if one had a weight limit and needs to prioritize ?
Full fare passengers have priorty, non revenue passengers may get bumped if the flight is restricted. Whose more intresting is difficult to tell, passenger ticket prices can vary greatly and cargo has a lot of rates to work with depending on the type of goods or the need to get them somewhere as fast as possible.
[Edited 2012-11-25 01:56:30]
Sancho99504
Sun Nov 25, 2012 7:34 pm
The center locks down the middle are guide locks for LD3s, they provide for proper alignment and the lip on the containers slide underneath the t to keep it grounded. On most aircraft I have worked, they are spring loaded past the door and will collapse as pallets slide over them.
Quoting B777LRF (Reply 8):
On Boeing you can load 4 ld3s per each row of locks. Ld8s and pallets much be secured seperately. On Airbus, each container or pallet must be locked seperately(no loose loading.)
All of deltas non-er 763s have small forward doors.
Quoting Tristarsteve (Reply 15):
AA 77E have the small aft door afaik.
On all the 747f I have worked, all pallets and containers are locked from the side, however there are specially made spots on 16 and 20ft pallets that the side locks go into. BTW, 20ft are a hell of a lot easier to load thru the nose when load height allows for it. On pax flights, we routinely mixed loaded aft and forward based on cg needs. All bag cans would be loaded with direct door access.
Air India's 744s are the worst. PDUs utilize the old big rubber wheel, warped and never catch on anything except overweight pmcs.
kill 'em all and let God sort 'em out-USMC
MCOflyer
Sun Nov 25, 2012 9:39 pm
Wow, great thread guys. I learned a lot from this thread thanks to the many posters.
KH
ferpe
Sun Nov 25, 2012 9:53 pm
Quoting sancho99504 (Reply 25):
Is this applicable for all DA types ie essentially 767, 777 and 300/310/330/340 ?
If so is this OEM policy or are there differences in equipment which leads to these differences?
sunrisevalley
Mon Nov 26, 2012 3:29 am
Quoting MCOflyer (Reply 26):
Agreed.......    What software is there out there that takes the number of pallets/cans and the weight of each and calculates a loading plan for a specific aircraft ?
B777LRF
Mon Nov 26, 2012 5:24 pm
Never seen a 10ft ULD that was not secured by a row of laterally placed locks, forward and aft of the ULD, on the main-deck of any freighter. Well, outside a military derivative of Russian or Ukrainian persuasion that is.
I have seen the side locks used on 10ft ULDs as well, but only as a measure of vertical restraint.
You mention the "pockets" for the side locks on 16 and 20ft. Never seen a 10ft ULD with the same configuration, so am wondering how the side locks can provide longitudinal restraint?
Sancho99504
Mon Nov 26, 2012 5:52 pm
Quoting ferpe (Reply 27):
Afaik, Boeing has their policies regarding restraints as does Airbus. The first time I worked an Airbus wide body, I tried to load 4 ld3s and put the locks up, but there was about a 2 inch gap from lock to container. I think its OEM differences, seems like Boeing gets a little more space out of the lower deck of their widebodies than Airbus, while Airbus gets more out their narrowbodies than Boeing sans 757.
Quoting B777LRF (Reply 29):
Sorry, I was just talking about the side locks. All locks are put up regardless of container or pallet length, although I have loaded some AMA and AMJ containers that had those "pockets" or indents, not sure what their technical name is. Sorry for the confusion, just trying to add a little to your post.
Mon Nov 26, 2012 7:57 pm
An u/s pallet/container lock is deffereable provided the entire Pallet located in that zone of the u/s lock is removed.
dlramp4life
Tue Nov 27, 2012 1:35 am
What is the difference between the interior loading system on the 763 and the 764? Which one is easier to use?
B777LRF
Tue Nov 27, 2012 6:47 pm
Quoting HAWK21M (Reply 31):
Are you saying that a single broken/malfunctioning lock will render a position unusable? If so, that's certainly not true.
Depending on the type of lock, the direction it is restraining against, it's location and the number of locks restraining in the same direction as the broken one, you may have a max. weight restriction if one or more are broken. There are, however, also plenty of examples where one or more locks will not have any effect. Vertical locks in Boeing lower-decks springs to mind (up to 3 vertical locks on the 777 broken = no restriction), but I can show you plenty of examples where a single broken main-deck lock will have no negative impact.
Below are a couple of tables showing the effect of broken locks on the B777F.
Aft Lower-deck (LD3 loading)
http://i47.tinypic.com/2v0jout.jpg
Main-deck (125/88 and 125/96 loading)
http://i46.tinypic.com/ety4q8.jpg
N/R = No Restriction
Wed Nov 28, 2012 10:25 am
Quoting B777LRF (Reply 33):
It is true as per our SOP.Single lock renders the space for Pallet unserviceable.
B777LRF
Wed Nov 28, 2012 4:58 pm
Quoting HAWK21M (Reply 34):
That sounds a bit overtly restrictive, knee-jerk reaction?
sunrisevalley
Wed Nov 28, 2012 7:38 pm
who has responsibility for checking for and issuing orders to repair/replace defective pallet locks? It is not something that the flight crew would be aware of ...or is it ?
tdscanuck
Wed Nov 28, 2012 7:54 pm
Quoting sunrisevalley (Reply 36):
Maintenance. Ground crew would notify maintenance when discovered, maintenance would log the appropriate actions.
The flight crew should get it from the discrepancies pages in the log book when maintenance hands the book over.
ak907
Wed Nov 28, 2012 10:50 pm
Quoting B777LRF (Reply 35):
Sometimes there is a weight limitation in place if a lock is broken. For example, on the 747F main deck there are three locks on both the front and aft of each pallet. If one of the outer locks is broken, there is a weight limit (really low). If the center one is broken, two adjacent positions of that lock are forbidden to be loaded.
And for sunrisevalley's question for the w&b program, there are many out there. DHL uses a program called SABLE, which is what we use at our station. Link: http://www.rekencentra.be/v2/en/pagina.php?niv=2&niv1_ID=2&niv2_ID=9
B777LRF
Thu Nov 29, 2012 6:57 pm
SABLE. One of the better decisions I was fortunate to be part of.
And, speaking of restrictions associated with broken/missing locks, that functionality is built into SABLE. Simply hover your mouse over the position, right click and select "missing restraint". New window opens, click the lock that's broken and SABLE will display any applicable lower weight. Works like magic, and to my knowledge no other W&B system can do that trick.
It's 10 years old now, but still the most advanced piece of W&B software on the market. Has been sold to a number of other operators, including Cathay Pacific and Polar Air Cargo. Lufthansa Cargo dearly wanted it too, mainly owing to it's vastly superior performance over the lethargic WAB system, but mother Lufthansa Passage wouldn't have it. Their loss.
If you're interested in buying it let me know and I'll point you in the right direction. It will talk to any DCS you can think of and will, of course, also trim passenger aircraft. Won't come cheap though but, then again, quality never does.
tb727
Thu Nov 29, 2012 8:22 pm
Out of curiosity I just checked my MEL and we void the position forward and aft of that position with a broken or missing lock. Interestingly enough, there are provisions to carry ballast or spare parts in those voided positions.
Sat Dec 01, 2012 6:14 pm
Ground crew report the same to Maintenance, who then defer the same under MEL.
Quoting tb727 (Reply 40):
Exactly ....
Users browsing this forum: No registered users and 4 guests
