Faro
Pilots Overriding ATC
Fri Nov 23, 2012 10:54 am
Given the abundance of lame-to-incompetent ATC recordings on the internet, how straightforward a proposition is it for pilots to ignore, change or go against ATC instructions?
Is there automatically a presumption of pilot fault attached to such actions which becomes the pilot's burden to disprove? Are both the captain and co-pilot treated in the same way in such a proceeding, if the co-pilot was the one in command at the time of the ATC incident?
Faro
The chalice not my son
RE: Pilots Overriding ATC
Fri Nov 23, 2012 12:02 pm
Simply put, the only time you can ignore instructions is during an emergency. In that case you may (and should) do whatever you need to do for the safety of the aircraft.
In case there is no emergency, prepare for everything from gentle prod to tongue-lashing to investigation. Note also that most violations are inadvertent, due to misunderstanding or incompetence.
A lot depends on what actually happened and if you endangered anyone and/or how much you disrupted traffic flow. If you are flying a Cessna 172, the pattern is completely empty and through inattention to your take-off clearance you take off and turn to your (reciprocal) on course heading with a left instead of a right turn, these things (though bad) happen. If you busted Class B in the same Cessna 172 and disrupted the JFK arrivals corridor, ATC will be more "insistent" (heh...). If you busted Class B in that way and kept going despite repeated calls from ATC, you will certainly get "a number to call once you land".
With regards to getting a clearance changed, there is a simple procedure: Ask the controller. They are typically happy to help if they can.
Quoting faro (Thread starter):
The Captain is always in command, even when he is PNF (Pilot Not Flying). Ultimately, the Captain is responsible, though I suppose if he is not in the cockpit when the violation occurs whoever is senior in the cockpit would be in the hot seat.
In any case it would depend on the particular circumstances.
[Edited 2012-11-23 04:35:45]
Faro
Fri Nov 23, 2012 12:52 pm
Quoting Starlionblue (Reply 1):
And legally, the onus is on whom? The flight crew to prove the necessity of their non-compliance or ATC to prove the well-foundedness of their instructions? Or are they both treated on an equal footing?
Faro
Fri Nov 23, 2012 12:55 pm
Not true, pilot can always say "unable XXX"
Quoting faro (Reply 2):
The crew has the final responsibility that the aircraft does not run into another aircraft or terrain.
Fri Nov 23, 2012 1:02 pm
In the US, AIM 5-5-1 paragraph b. states "The pilot-in-command of an aircraft is directly responsible for, and is the inal authority as to the safe operation of that aircraft. In an emergency requiring immediate action, the pilot-in-command may deviate from any rule in the General Subpart A and Flight Rules Subpart B in accordance with 14 CFR Section 91.3"
Other countries may vary.
So I the pilot in command is always legally responsible. However, I would assume if the Captain is, say, asleep in the rest area while the First Officer (acting in command) violates procedure, the authorities would make the First Officer answer. On a case by case basis of course. Conveniently, all this stuff is recorded on the radio and, in the case of larger airliners, in the DFDR and the CVR.
Fri Nov 23, 2012 1:07 pm
Quoting zeke (Reply 3):
Oops. Of course you are correct. ***bangs head on table*** This would fall under "The pilot-in-command of an aircraft is directly responsible for, and is the final authority as to the safe operation of that aircraft."
However if you bust Class B because you were "unable" you'd better have a good explanation.
[Edited 2012-11-23 05:17:29]
speedbird128
Fri Nov 23, 2012 2:56 pm
One issue I have with a simple recording is that the entire scenario including other tasks are not shown along with that. It might sound like a ballsup, and might have been a ballsup, however its usually a little more complicated that "lame" or "incompetent" ATC. I'm not saying that we are perfect, we do make messes. Its how we resolve it afterwards!! But to listen to an liveatc clip and determine that the atc was lame-to-incompetent is not quite fair.
It would be like saying that every pilot inn a CFIT accident was a moron. Not true, circumstances play a big part, and its that part the public realm don't get to see.
Most definitely correct! - If its a silly speed, or a heading that puts and aircraft into a storm, or a level assignment with there is something coming head on etc etc, that is most acceptable. I encourage it - because it makes a controller aware that they are giving an unrealistic instruction.
I have had in recent times a rash of deliberate ignoring speed instructions. 280 is not 210. Saying sorry after the wild vector doesn't help, and if you have an issue with a speed *please* speak up when its issued so we can slow the traffic behind and/or re-vector somebody. Whatever the reason, whether it be company policy, fuel conservation, or you just don't like it or feel comfortable or crew are training, just say so early!!! When you're spacing to be exactly 3.0nm apart at touchdown there is not a lot of tolerance for us...
And as has come out in another thread, with the advent of Mode-S Enhanced Surveillance, we can see very quickly who's 'forgotten' about a speed, or 'fudged' a heading etc etc...
A306, A313, A319, A320, A321, A332, A343, A345, A346 A388, AC90, B06, B722, B732, B733, B735, B738, B744, B762, B772, B7
Fri Nov 23, 2012 3:27 pm
In my admittedly limited experience, pilots screw up way more often than ATC.
If ATC screws up, the first alternative is not to ignore them and do your own thing. Ask for clarification, say unable and suggest an alternative, etc...
tdscanuck
Fri Nov 23, 2012 3:43 pm
The procedure to ignore/change is very straighforward. It's the justification afterward that's a problem.
It's not a presumption of pilot fault; the pilot is in command at all times. However, there is a presumption that ATC instructions will be complied with as issued unless the pilot is unable to safety do so. So there is a burden on the pilot to show that it would have been unsafe to comply. That doesn't mean the pilot was at fault, but it does mean the pilot has to have a legitimate reason.
It's on the flight crew. ATC instructions don't have to be well-founded (try pissing off a controller some time and see how well-founded their vectors will become), they just have to be complied with unless it would be unsafe to do so. Pilots can *never* escape the obligation to maintain safe operation of the aircraft.
Tom.
Faro
Fri Nov 23, 2012 4:50 pm
Quoting Speedbird128 (Reply 6):
Agree 100%, there are in fact even more examples of pilot messups on those recordings. The present thread is simply based on the premise that ATC has a central co-ordination role vs that of pilots; they are the nominal arbiter. And to be fair, linguistic misperceptions seem to account for a large chunk of both of the aforementioned messups.
Faro
tb727
Fri Nov 23, 2012 5:04 pm
Being a pilot and able to admit this on behalf of all of us, I know there a lot more lame to incompetent pilot actions going on out there versus ATC as a whole, they just aren't always recorded or seen by the public
I've heard this from a few guys that if the pilot screws up, the pilot dies. If ATC screws up, the pilot still dies.
But that being said, I don't think I have ever really been in a situation where I absolutely felt I had to override ATC's instructions. I have questioned some and maybe hinted at something I would rather have done, sometimes getting my way and sometimes not but that is mostly with routing.
Quoting tdscanuck (Reply 8):
Exactly.
I do think as PIC, I would have to follow the aviate, navigate, then communicate "rule" if I was ever in doubt and I better have a darn good reason if I do go off and do my own thing.
Viscount724
Fri Nov 23, 2012 8:14 pm
Item from the Transport Canada daily occurrence reports a day or two ago below, which seems somewhat related to the subject:
The WestJet Boeing 737-700 (operating as flight WJA325) was ready to depart on a scheduled IFR flight from Toronto (CYYZ) to Edmonton (CYEG). The American Airlines Boeing 737-800 (operating as flight AAL1586) was concluding a scheduled IFR flight from Los Angeles (KLAX) to Toronto. NAV CANADA staff at Toronto Tower reported that the WJA325 flight crew was asked by the Tower Controller if they were able to conduct an immediate take-off with AAL1586 approximately five (5)NM final. The WJA325 flight crew said that they were able, however, when cleared for an immediate take-off, they were very slow to comply. A reduced power take-off by WJA325 resulted in AAL1586 being instructed to overshoot.
Mir
Fri Nov 23, 2012 10:33 pm
I'm not aware of this abundance. I know there are a lot of recordings out there where the controllers aren't able to convey what they want to convey, but I have heard very few recordings that would lead me to believe that the controller does not have a firm idea of how he or she wants to work the traffic flow and maintain separation, which is about the only time a pilot would be justified in disregarding instructions (on safety grounds, of course).
-Mir
Sat Nov 24, 2012 3:31 am
Don't worry, this annoys me too, what annoys me more is that ATC often do not vector these people around to join the sequence later, they make people behind pay for it. I was following someone recently they were asked to maintain 300 or greater, we were asked to maintain 290 or less, they slowed to 250. ATC spun them 90 degrees off track, increased our speed, let 4 aircraft through and then let them join back in. They got they message.
IAHFLYR
Sat Nov 24, 2012 5:08 am
Quoting zeke (Reply 13):
Perfect, and that is exactly what should happen IMHO.
In the for what it's worth department, in over 32 years of being a controller I can only think of once when a pilot even attempted to override what the clearance was that I issued and that was in the very early days of TCAS. This particularly bright MD80 crew flying from LAX to HOU thought they had the plan when I had turned then base leg for the approach. The figured out due to TCAS that the airplane they were following would be to close to them so they didn't turn nor told me they were not turning. Since the wind was 50 knots or so on their tail it was necessary to turn them early to fill the hole on final and when they didn't turn the got to see the very far northeast side of HOU for an extended period of time.
Oh so true!
Mir
Sat Nov 24, 2012 5:26 am
Quoting IAHFLYR (Reply 14):
So just out of curiosity, what should happen when ATC gives you a vector to join a different approach from the one you were told to expect, and then when you say you're unable to fly it (don't have the appropriate equipment and certification), they give you a fifteen minute tour of the west side of Chicago? Because that was rather frustrating.
-Mir
IAHFLYR
Sat Nov 24, 2012 5:35 am
Quoting Mir (Reply 15):
Curious what approach you were told to expect and what may have been advertised on the ATIS if the airport was equipped with one?
Where I have worked you'd be assigned the advertised approach on the ATIS, if anything different which from time to time you could be told to expect maybe an RNAV (GPS) or RNAV (RNP) if not advertised would be inserted into the data block for the final controller to know that is what was assigned. So in my mind there should not be any tour of any place, unless the crew didn't inform the controller they couldn't accept the assigned approach then I can't tell ya other than you're going back in the conga line.
Mir
Sat Nov 24, 2012 7:04 am
Quoting IAHFLYR (Reply 16):
ATIS advised the ILS and RNP to 13C in use (at MDW). Was told to expect the ILS by the first approach controller we talked to, the second controller tried to put us on the RNP.
It's true that I didn't say that we couldn't accept the RNP approach (until we were given clearance for it, that is), but if we had been told to expect it I certainly would have.
-Mir
speedbird128
Sat Nov 24, 2012 10:28 am
Hi Zeke,
Yes, I am sure that is annoying. However, one thing to consider with this, is that when we operate really close to the minimum separation (where I am 3nm on final), it becomes tricky to break out the offender without a loss of separation. I am not permitted to use visual separation during this sort of maneouvre, so it ties my hands unfortunately...
What I refer to as an "Educational Vector", it is - as you rightfully say - deserved by the non-complying aircraft...But once they are below you and ahead of you on the GS, and they throw the anchors out, its hard for us to break them out without a flashing red set of radar targets, and tea later with the boss...
Sat Nov 24, 2012 11:23 am
Unless its an emergency & same action is conveyed to ATC......Other cases there is always the right to counter the Instructiions & convince ATC if things are not accurate.
IAHFLYR
Sat Nov 24, 2012 1:15 pm
Quoting Mir (Reply 17):
If RNAV (RNP) 13C and the ILS are overlays (I haven't looked at them) with the same lateral/vertical paths then I would not have a problem changing the approach clearance, take all of about 5 seconds or less. It shouldn't make a difference what you flew in that case unless the weather was such you needed a lower min.....but my guess is they are not overlays.
Somebody has to keep ya guessing.
wilco737
Sat Nov 24, 2012 1:19 pm
I had this case yesterday during approach. We were instructed to reduce speed to 300 knots and descent to 10,000 feet to reach at a specific point. This was simply impossible unless the 744 changed to a flying piano.
So we told the controller: either 300 knots or 10,000. So he picked the 10,000 feet and we did our best to get as close as possible to that target altitude.
So it is basically a working together here. The controller does his best and we try our best to obey and follow the instructions, but if we cannot, we simply are unable to follow and let him know early enough so that he can plan for Plan B.
We should work together and not against each other.
Same for the approach. They said plane for ILS 27L (which is rather short). I requested runway 28 and he said: "Expect ILS 28." Simple as that.
wilco737
IAHFLYR
Sat Nov 24, 2012 1:31 pm
Quoting wilco737 (Reply 21):
Exactly, and I believe we do in 99.99% of the situations.
wilco737
Sat Nov 24, 2012 1:47 pm
Quoting IAHFLYR (Reply 22):
Yes, I 100% agree.
The best support I received from ATC was during a medical emergency. The work of ATC was just excellent. They supported us as much as they could, held the airspace free for us and we could land right away, right to our parking spot where the paramedics were waiting. Was for sure a great job by ATC.
wilco737
musapapaya
Sat Nov 24, 2012 1:53 pm
lol Zeke, thanks for the insight, who was that aircraft? i will try to avoid flying on such an airline, 300 or greater and 250 is QUITE different!
Where is this Wilco? back at your homebase I hope not?
Lufthansa Group of Airlines
wilco737
Sat Nov 24, 2012 1:56 pm
Quoting musapapaya (Reply 24):
No, the guys in FRA are pretty good. It was in ORD. They kept us high for quite some time and then wanted us to descent like a piano...
wilco737
speedbird128
Sat Nov 24, 2012 2:47 pm
Most definitely agree 100%. My aim is to get everybody in and out as fast as possible within the safety margins.
I drum it into my students never to ask for a simultaneous expedited descent and speed reduction... It's the easiest way to lead a crew into an unstable approach... I have found that some crews will try, and respond with "we'll do our best". But I have seen it all come undone at some later point, which ultimately led to a more complex solution than just turning somebody out earlier... I realise that the decision whether you can comply is sometimes hard to assess and decide within seconds, but if you're in doubt just let us know and we'll make another plan. I just know that if traffic is above 100 at 25nm and you want a speed reduction then give the crew a heading for another 5 or 10 miles, and when on profile turn them back in.
I know the heavies have a lot of inertia compared to an A319 for instance... and i always tried get the students to understand what that four letter aircraft code on the radar tag means to him/her.
But it doesn't help with non-compliance or silent deviation from a clearance... I don't understand why speeds are seen as "flexible"...
CosmicCruiser
Sat Nov 24, 2012 2:54 pm
I don't know if this holds true for every FMS but in the -11 it will honor the alt first and airspeed second so to do both requires some pilot input.
FOR IAHFLYER, I curious if you guys understand the confusion this eg. creates? "cross XXXX at 10,000'." now well into the descent we get "slow to 250kts". From what I've seen, making airspeed changes in a "profile" descent will certainly confuse the FMS for a bit until it's reset on the new airspeed. It can result in a failure to meet the restriction.
wilco737
Sat Nov 24, 2012 4:21 pm
Quoting Speedbird128 (Reply 26):
Very good. Thanks for that
Neither do I. Of course it takes a while to reduce from 360 knots to minimum clean, but I comply with the clearance. If not, I'll let the controller know.
Quoting CosmicCruiser (Reply 27):
Yes, same for the 744. It complains and let us know 'DRAG REQUIRED", telling us that with the clean airplane and idle the path cannot be followed.
wilco737
speedbird128
Sat Nov 24, 2012 4:23 pm
Yup it sure can confuse the FMC. However, unless your crossing restriction is specifically cancelled, it still holds true. Yes slowing down results in reduced sink rate, then let ATC know ASAP that the level restriction will not be able to be met.
Out here the tendency is to have everybody start their descent early, as it gives us a more manageable speed to absorb any delays without having to resort to holding... As our airspace is so fragmented - its not possible for anybody to know where in the sequence the traffic is that they are handling... And so we have standard levels inbound and then we push/pull the sequencing with speed control and some vectors...
CosmicCruiser
Sat Nov 24, 2012 5:36 pm
We are encouraged to stay on prof. and not start down early due to extra fuel used but it can get busy if an airspeed change is given and the FMS says "let me think about this for a minute or two". Of course there are numerous places where the FMS can be fooled easily and pilot modifications are required like V/S or level change. Essex radar in the UK are known for giving you vectors left and right of the STAR route but still give "cross abeam xxxx at FL150. I wonder if they consider that the further off course I am the less accurate the altitude will be abeam the fix.
tdscanuck
Sat Nov 24, 2012 6:40 pm
We got into that situation on a Boeing Field approach before (they wanted to keep us under SeaTac's traffic). Fortunately, we'd been out testing emergency descent rates all day. ATC said they'd take altitude over speed. So out came the gear and boards, throttle to idle, dropped like a rock. Got a polite inquiry from ATC shortly thereafter about our actual descent rate because they weren't totally buying what their radar was telling them. Not having to keep passengers happy does have its advantages.
Tom.
speedbird128
Sat Nov 24, 2012 7:59 pm
Quoting tdscanuck (Reply 31):
Yes, without the pax it can be fun!
I had the privilege of flying up front with some friends in a 77W, and also, the expedite climb/descent commands were interesting to watch...
FLCH with the 'gear and boards' as you say is very fun for a non-regular!! LOL
Same as the climb - we were only 5 on board with 50t remaining fuel and got the 'expedite to level 160'... 6500fpm on the way up! very cool to experience...
Mir
Sat Nov 24, 2012 10:38 pm
Quoting IAHFLYR (Reply 20):
It doesn't, though. Even if the points were the same, we'd have to go into the FMS, load the other approach, pull up the chart for the other approach, scan it for differences (minimums, missed approach instructions, etc.), and then brief those differences. You might be able to get all that done in a minute if you hurry and you weren't pre-occupied with something else, but it's certainly not going to get done in 5 seconds.
They're not. The RNP approach comes in at a 90 degree angle to the final and then flies a turn (which is the part our FMS can't do) to line up with the runway. The ILS is straight-in, obviously.
-Mir
Moose135
Sun Nov 25, 2012 3:16 am
Did that in a KC-135 going into KGUS one time. For some reason that I've long since forgotten, ATC held us up high over Indy and gave us a late decent into the home drome. I do remember that it felt like I was going to fall out through the windscreen...
MHG
Sun Nov 25, 2012 10:55 am
Quoting Mir (Reply 33):
He was probably talking about the controllers side ...
I miss the sound of rolls royce darts and speys
IAHFLYR
Sun Nov 25, 2012 2:45 pm
Quoting MHG (Reply 35):
No probably, I was!
I was referring to the fact you've loaded and briefed for the approach expected and the controller cleared you for the other it would be a problem to re-clear you for what you had loaded in the box...IF everything was an overlay. You would not be required to re-brief the approach or make changes in the FMC.
My point was strictly from the ATC side, where if the approaches are mirrors, it makes no difference what you fly, the path is the same so a controller could tell you to fly a VOR back-course to the NDB side-step 13C and who cares.....everything goes to the same place.
Some do, not working in an ARTCC I can't speak for them however; from both flying and at times receiving the same type clearance as well as talking with guys who fly large metal it appears many don't get the "come down/slow down" issue not working. And I love the "do the best you can"!!!! NOT
Quoting CosmicCruiser (Reply 30):
Even when using a route offset?
CosmicCruiser
Sun Nov 25, 2012 6:41 pm
Quoting IAHFLYR (Reply 36):
If I understand correctly, yes you would be required to "rebuild" the app and rebrief. For example, the LOC app may have diff. mins from the RNAV to the same runway.
right! do your best is not a get out jail free card.
these are vectors "turn right 10deg." "turn left 15deg. There is no route offset here.
IAHFLYR
Sun Nov 25, 2012 7:12 pm
Quoting CosmicCruiser (Reply 37):
Oh that makes it fun then for sure. And even more fun expect more of those type altitude/speed constraints as those who have a slight understanding of what the capabilities of the FMC are retiring from the controller ranks.
Sorry for the confusion Cosmic, I was actually making a poor attempt at saying if the approach was an overlay and you were initially told to expect the ILS 13C and crew briefed that approach then I wouldn't think you'd have to re-brief or make any changes in the FMC as that's what you expected. The controller most likely would not care what you flew as long as the lateral/vertical paths were identical.....so much better if we did have all overlays so we could get to phraseology that was something like "cleared Runway 13C approach" and you fly whatever nav solution (ILS/RNAV/GLS) you want.
CosmicCruiser
Sun Nov 25, 2012 7:42 pm
but it is a separate app in the data base. I can pick the ILS or RNAV or LOC therefore you must load what you're cleared for.
tdscanuck
Sun Nov 25, 2012 7:53 pm
Quoting CosmicCruiser (Reply 39):
If you're cleared for the ILS and the RNAV is an overlay (i.e. it's the same physical path in space with the same minimums and requirements) do you actually need to reload? I can understand that might be SOP for a carrier but, offhand, I can't think of any actual FAA requirement to do so.
FlyHossD
Sun Nov 25, 2012 8:00 pm
Good thread.
Over the course of many years, I've said "Unable" a few times and in most cases, that was that.
There were examples of the Controller being offended, though. In the first to-come-to-mind example, we received a reroute that was quite extensive and we just didn't have the fuel for it, so we declined the new route, by saying "Unable." About 5 minutes later, another Controller issued the same reroute. Of course, we had to decline it again - he demanded we accept the revised route or divert!
Attorneys became involved in that one!
sprout5199
Sun Nov 25, 2012 8:13 pm
After reading all about you big airplane guys, I will throw in my little airplane story.
On approach to PBI, in a C152, I was vectored offshore to pass behind a 737 landing on 27R and I was landing on 27L. I was at 3000 and was heading east off shore, when I realized that I would be soon out of gliding distance to the beach. I asked my instructor what to do. He just told me to tell ATC that I need to turn towards the airport soon. I asked to be turned soon, and the controller turned us right then, she even said that she forgot that we were a C152. She could have landed two more planes before we even got close to the airport.
But also, ATC have asked me to do a 360, even though I was number one to land because there was a faster aircraft behind me(is there a slower one than a C152?) and I said sure, as I'm a student and need all practice I could get. What comes around goes around.
Dan in Jupiter
CosmicCruiser
Sun Nov 25, 2012 10:07 pm
Quoting tdscanuck (Reply 40):
Well for us I'm sure it's partly not to be so easily lead to think one is the other. If the app is in the data base we're suppose to pick the app we are cleared to fly. Also you must be in NAV & PROF for the RNAV and for the ILS you don't; a possible screw up there. I did just pull up a couple of app here in MEM and found that the ILS to 2 runways have different app altitudes and different mins as well as differently described MA proced. than do the same RNAV apps. There were also notes that were more restrictive for the RNAV that certainly should be briefed.
I don't think I'd want to be getting a line check or worse yet have the FAA on the jet and brief "don't worry it's the same flight path.."
IAHFLYR
Sun Nov 25, 2012 11:33 pm
I really think you're missing my point. Let me try again because I don't want to confuse anyone, let alone myself!
Point is, you're told by the feeder controller to expect an ILS, you brief that.....the final controller then clears you for an RNAV to the same runway......but you can't fly that because of certification or lack of it etc. Had both approaches been the same as in lateral/vertical such as what IAH has then the controller really should not care if you fly the RNAV or the ILS because they look the same.
http://aeronav.faa.gov/d-tpp/1212/05461IL27.PDF
http://aeronav.faa.gov/d-tpp/1212/05461RRY27.PDF
http://aeronav.faa.gov/d-tpp/1212/05461GLS27.PDF
The controller should come right back and clear you for the ILS rather than what they issued you in the initial approach clearance. Hope that explains it a little better!!
Quoting sprout5199 (Reply 42):
I would have had to ask how can you forget the airplane type when it's on the display you're looking at, let alone our ground speed of something like 110? You're kidding right?
Quoting FlyHossD (Reply 41):
So what place did you divert, or did the idiot finally realize when a pilot says unable they might really be serious?
Mir
Mon Nov 26, 2012 12:45 am
I'd say so. I don't like flying an approach different from the one I have in the FMS, or the one I've pulled out the chart for.
If it's an overlay approach (i.e. one that has "or" in the title, such as "VOR or GPS 17" or "ILS or LOC 35"), then there's no need to reload the approach from the pilot end because it is the same approach. You might have to brief different minimums, but the chart will already be out and visible so it's not incredibly difficult. But I don't consider approaches on different charts to be overlay approaches, even if the fixes are the same.
-Mir
IAHFLYR
Mon Nov 26, 2012 1:20 am
Quoting Mir (Reply 45):
While I completely respect your opinion, they are totally considered overlays.....everything except maybe the missed approach and respective minimums are the same, everything.
Guys, I am not saying an approach brought up from the database with a different name from another approach does not to be reloaded or briefed as I have no clue to company SOP. All I am telling you is if you're expecting and briefed an ILS and cleared for an RNAV the controller should not have any issue with giving you a new clearance for the ILS since that is what you have in the box and briefed if lateral/vertical paths are the same, period.
FlyHossD
Sat Dec 01, 2012 5:50 am
Quoting IAHFLYR (Reply 44):
No, we didn't divert - we continued to the destination on the original clearance.
But there was a threat of a violation (to be issued against us). As I said, attorneys became involved - quite successfully from my perspective.
highflyer9790
Sat Dec 01, 2012 4:05 pm
I think its already been covered, but as long as i have the ability to mouth the words "unable," then i will always make sure whatever ATC is telling me to do i safe, my aircraft can handle it, and it makes sense. ATC usually does a great job, but the one time the mess up, bottom line they are still in a room, i am in an airplane with my crew and passengers.
Yes, legally the PIC is always responsible. However, per the orignal posters question, when we are actually flying we defer to the flying pilot when ATC gives us an option. If i am flying and ATC asks if i can accept a circle to a different runway, or a certain preference as to which runway i want, i'll give the captain a thumbs up or let him know what i want to do prior to him calling ATC back. ill do the same when the captain is flying and see what his preference is prior to answering ATCback on a question about what we want. this is how we handle normal everyday ops.
Quoting Starlionblue (Reply 4):
correct, sleeping or not.
highflyer
121
Sat Dec 01, 2012 5:39 pm
Quoting highflyer9790 (Reply 48):
Yepp. It was covered. I had a brainfart and totally missed "unable". Duh!
