tmoney
Why Russian Ac Have Fans In Their Cockpits?
Sun Nov 25, 2012 7:22 pm
When I google searched it there's a link on Yahoo answers that says because their APU generators aren't strong enough and their aircrafts' airconditioners draw too much power from the engines. Is that why Russian/Soviet aircraft need to have a fan in the cockpit?
Besides those fans don't have covers around their blades! Doesn't that pose a threat to the flight crew?
s5daw
RE: Why Russian Ac Have Fans In Their Cockpits?
Sun Nov 25, 2012 7:35 pm
I have seen a fan in an Antonov An2, but modern jets, really?
aviatorcraig
Sun Nov 25, 2012 7:43 pm
Yeah, and also why are their cockpit panels always painted turquoise, AND why do all Russian aircraft from fighters to transports have their wheel hubs painted olive drab green? I think we should be told!
707 727 Caravelle Comet Concorde Dash-7 DC-9 DC-10 One-Eleven Trident Tristar Tu-134 VC-10 Viscount plus boring stuff!
Dufo
Sun Nov 25, 2012 7:46 pm
We had those fans on L410 and they were sufficient and caused less clogged noses and soar throats than air conditioning with apu on other types.
Blades are made of rubber, you can easily stop them even with a finger.
I seriously think I just creamed my pants without any influence from any outside variables.
Viscount724
Sun Nov 25, 2012 8:43 pm
Quoting aviatorcraig (Reply 2):
Also common on many DC-9s.
Photo © Rainer Nyberg
Photo © Jose M Gutierrez
Photo © Tero Paassola
Photo © Louis Bellefeuille
NASCARAirforce
Sun Nov 25, 2012 11:51 pm
Quoting s5daw (Reply 1):
Even on the AN-225
Photo © Bernd Sturm
BMI727
Mon Nov 26, 2012 2:25 am
I want to say that the color was suggested by psychologists because it is supposed to fight fatigue or increase alertness or something like that.
I'm pretty sure they use it for different reasons than doctors do.
ptrjong
Mon Nov 26, 2012 8:13 am
Quoting Dufo (Reply 3):
Brilliant. I guess it never occurred to the topic starter it might simply be a good idea.
AirlineCritic
Mon Nov 26, 2012 5:38 pm
Because the Russian pilots are friendly, and let the local a.nutter and other fans in for jump seat ride?
Oh wait, you meant something else...
Mon Nov 26, 2012 8:00 pm
They Russians believed it reduced fatigue & kept the crew Alert
Quoting tmoney (Thread starter):
Any pics......was these unpressurised Aircraft.
bohica
Mon Nov 26, 2012 8:59 pm
I think it has more to do whether the cockpit was equipped with gasper vents or not. In the pictures with fans, I didn't see any gasper vents but I saw them in photos of the more modern planes without fans.
Quoting Ptrjong (Reply 7):
The OP never said it was a bad idea. He is just asking a question.
tmoney
Mon Nov 26, 2012 9:56 pm
Quoting bohica (Reply 10):
Thank you. Yes, I was just asking a question.
And thanks for all the input too. I just thought it's ironic that while the massive jet engines' fan blades are pushing the aircraft forward, there are tiny lil fans that's blowing at almost the opposite direction in the flight deck.
bikerthai
Mon Nov 26, 2012 10:53 pm
That is an interesting trade.
The fan is a simple installation that only require electricity as opposed to ducting and stuff in a gasper air.
How are the equipment in the cockpit cooled? Draw through or blow-by? If it's draw through then the gasper air would require a separate ducting system.
Of course, with the fans you may have higher failure rate/maintenance issue depending or how reliable those fans are . . . but I guess you can still dispatch if one of those fail
bt
SAAFNAV
Tue Nov 27, 2012 4:06 am
Quoting tmoney (Reply 11):
So if you put in on the conveyor belt, and have the fans blowing over the pigeons in the back, you won't take off?
KC135Hydraulics
Tue Nov 27, 2012 8:32 am
On the KC-135 we have at least 5 fans on the flight deck. They all have cages around them of course! There is no air conditioning system for use on the ground so they're a requirement for a warm day. You want pictures?
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
ptrjong
Tue Nov 27, 2012 11:33 am
Sorry for that, you're right.
bond007
Tue Nov 27, 2012 8:34 pm
Well, wouldn't they be blowing the same direction as the big fans on the wings?
In this case they will of course be providing additional thrust, which is necessary for some of the under-powered Russian aircraft. Obviously 5 fans are required for a fully loaded KC-135, because it's heavier.
They are usually the type that can rotate at least 180 degrees, so you often see the pilots quickly turn them in the opposite direction upon landing, especially if the engines do not have thrust reversers.
Basic stuff really.
Jimbo
Aquila3
Tue Nov 27, 2012 9:08 pm
Not only they have Fans. Sometimes they even have Cheerleaders. The Russian version, with the taller MLG.
chi vola vale chi vale vola chi non vola è un vile
Users browsing this forum: mmo and 2 guests
