dennys
A340-600's And A340-500's Rear Fuselage Length Q.
Sun Dec 02, 2012 1:42 pm
Hello ,
i just need your help to know how much longer is the rear part of the A340-600 compared to the A340-500's one .
1 meter , 2 meters ...
Many thanks
dennys
Stitch
RE: A340-600's And A340-500's Rear Fuselage Length Q.
Sun Dec 02, 2012 4:37 pm
The rear fuselage plug for the A340-500 is 1.07m and for the A340-600 it is 3.20m - so the A340-600 plug is 2.13m greater.
http://www.aviamarket.org/reviews/civil-aircraft/521-airbus-a340.html
dennys
Sun Dec 02, 2012 6:25 pm
Many Thanks !!! My Friend !
LH707330
Wed Jan 01, 2014 10:42 pm
Quoting Stitch (Reply 1):
Fascinating link! Do you by any chance know why the fuel capacity for the 500 and 600 is different? I always thought the wing structure was the same for these two?
Stitch
Wed Jan 01, 2014 11:09 pm
Quoting LH707330 (Reply 3):
The A340-500 has a rear center tank with a capacity of 20,042 liters that is not present on the A340-600.
LH707330
Thu Jan 02, 2014 5:42 am
Ah ok, thanks! Per Wikipedia, the HGW versions have an extra ~7000 liters, do you know where this is stored?
Stitch
Thu Jan 02, 2014 6:32 pm
Quoting LH707330 (Reply 5):
It looks like Airbus later added an optional 10,800 forward center tank for the A340-600.
As for the A340-500, it looks like the standard aft center tank is five frames in length, but can optionally be seven frames in length which offers an additional 7,970 liters of volume.
[Edited 2014-01-02 10:34:42]
LH707330
Fri Jan 03, 2014 5:35 pm
Quoting Stitch (Reply 6):
Ok thanks! Do you have technical drawings of this somewhere?
SAAFNAV
Fri Jan 03, 2014 7:17 pm
Quoting Stitch (Reply 4):
Sorry, I have to ask. 20 000l per tank?
Man, whats the total fuel capacity?
Stitch
Fri Jan 03, 2014 7:22 pm
Quoting LH707330 (Reply 7):
An excellent overview of the initial A340-500 / A340-600 fuel system is available in the September 2000 issue (#26) of Airbus' Flight Airworthiness Support Technology (FAST) technical magazine. Back issues are available at airbus.com/Support/Publications
Sat Jan 04, 2014 1:41 am
Quoting SAAFNAV (Reply 8):
222000 liters for the A340-500HGW and 204500 for the A340-600HGW. Note that airliners rarely fly with full tanks as it tends to cut down on payload.
SAAFNAV
Sat Jan 04, 2014 8:45 am
Quoting Starlionblue (Reply 10):
Sure, but wow!
That is 2.5x C-130B models at max overload!
Sun Jan 05, 2014 1:06 am
Quoting dennys (Thread starter):
The A340-500/600 have a common center section length between frames 38 and 54. After frames 54, both have the additional frames, the additional length is close to what is provided in reply 2.
Its 19741l with 5 frames, or 27900l with 7 frames on the A340-500.
The 7200l option is what the call an additional center tank, it is the shape of a LD6 container that is loaded into the cargo hold, these are available on all Airbus wide bodies. A smaller version is available for the A320 series.
Some details in here http://www.airbus.com/support/public...?eID=dam_frontend_push&docID=17453
It is just an additional ACT in the aft section of the forward cargo hold.
All he would have is google.
A340-500 it is 215 262 l (56 866 US gal) with a 5 frame RCT - 7 frame RCT: 223 421 l (59 022 US gal). The A340-600 has a total usable fuel capacity is 195 521 l (51 651 US gal).
The fuel tanks are in the positions that follow:
- the center tank (in the center wing) between the rib 1 (LH) and the rib 1 (RH) - 55202l
- the LH and RH outer tanks (in the wing) between the rib 23 and the rib 35 - 12442l
- the inner tank 1(4) is between the rib 5 and the rib 11 (and the center and rear spars) and between rib 11 and rib 23 (and the front and rear spars). - 69648l
- the inner tank 2(3) is between the rib 1 and the rib 6 (and the front and rear spars) and between the rib 6 and the rib 11 (and the center and front spars) - 34824l
- the trim tank (in the Trimmable Horizontal Stabilizer (THS)) - 9051l
- the rear center tank (A340-500 only):
- 7 Frame RCT is between frames C53-2 and C53-9 - 19741l
- 5 Frame RCT is between frames C53-2 and C53-7 - 27900l
aft of the center landing gear bay.
Users browsing this forum: badgervor, edgaren, kalvado, Starlionblue and 1 guest
