arzouni
Spare Parts For Aircraft (Bogus)
Thu Dec 06, 2012 8:27 pm
I am writing an assay about the unapproved parts (Bogus)
i have to research and analyse the maintenance practices in a civil commercial aircraft environment, concerning the use and control of genuine and non-genuine (bogus) spare parts for aircraft use.
i need some advice on what exactly i have to write and if it possible suplay me with some good wesite that explaine everything
thanks
tdscanuck
RE: Spare Parts For Aircraft (Bogus)
Thu Dec 06, 2012 9:30 pm
Here's the FAA process for producing NON-bogus parts. This is probably a good place to start:
http://www.faa.gov/aircraft/air_cert/design_approvals/pma/
Producing bogus parts basically means generating a convincing enough paper trail that the part looks like it's legitimate.
Tom.
roseflyer
Thu Dec 06, 2012 11:09 pm
There is a process usually referred to as PMI. This is where airlines get parts from a supplier that was not the original supplier by Boeing or Airbus. There is a certification process for these parts. Using parts from alternate suppliers are not bogus parts. For example, airlines rarely use the original filter suppliers. They use alternate suppliers who still comply with FAA requirements.
KELPkid
Fri Dec 07, 2012 12:08 am
You still have the nutjobs around in GA circles who do things like stick a rebuilt Ford Mustang alternator from the nearest cheap auto parts store in a Cessna 172 when the alternator goes bad, rather than pay the mechanic to put the (PMA'ed version of) the same part in the plane. How these planes ever pass their annual, I'll never know...
Not exactly bogus parts, just unapproved ones (which renders the aircraft unairworthy!   ) Not to mention people who overstep the boundary of mechanic and allowed owner maintenance...
amccann
Fri Dec 07, 2012 12:36 am
Something you could look in to is/was the influx of counterfeit fasteners in not only the aerospace industry but also in the automotive industry.
"The Fastener Quality Act" was passed in 1990 to reduce the number of counterfeit fasteners through means of accreditation, certification, inspection, and testing.
What one person receives without working for, another person must work for without receiving. - Ronald Reagan
BE77
Fri Dec 07, 2012 11:36 am
Quoting KELPkid (Reply 3):
Quoting amccann (Reply 4):
Easiest part would have been to pass the annual - they used to look 'exactly' the same as the original part (which is not a suprise, since it was the same, just bought at a different store). You would have had to really be looking for it to find it.
They used the same alternator on Ford tractors for a long time too - and those were even cheaper to buy way back when than buying the same alternator at the Ford auto dealer. Even if you're mechanic noticed it, he'd probably 'not notice' during the annual, since it was the same alternator and it didn't affect the airworthiness - remember too that the manufacturing QA/QC and supply chain processes for parts like this were essentially the same (basically non-existent) for Tractor/Car/Aircraft until conterfeit parts started becoming an issue - as amccam noted things didn't start to change until the 80's and 90's.
Not to say any of this was legal, but things were (really) different then (seatbelts in cars weren't mandatory, no baby seats, and light aircraft (and pickup trucks) had fewer and simpler systems that any backyard mechanic could generally understand and fix. I couldn't change the snake belt on my truck now, but in high school we'd stock fan belts and us kids would install them in 5 minutes at the fuel island as part of normal the service provided at the local 'full service gasoline station".
I do miss the $200 annual (same plane, and I am lucky to get out at $3000 doing all the legally allowed owner assistance tasks - of course is was new in the 80's too and now has 30+ years on it).
Tower, Affirmitive, gear is down and welded
Tod
Mon Dec 10, 2012 4:15 pm
FAA suspected unapproved parts webpage.
http://www.faa.gov/aircraft/safety/programs/sups/
twincommander
Wed Dec 12, 2012 2:02 am
I changed a standby alternator on a caravan a while back... the one i removed had motorcraft stamped on it and the one installed had motorcraft stamped on it. the STC showed that exact ford part number. we paid $450 for the rebuilt replacement from someplace in anchorage, and napa had the same one for $56.40 before core.
however, while napa's would work fine, it would be considered a bogus part, as it is not certified for aircraft use.
aklrno
Wed Dec 12, 2012 5:49 am
On a remotely related topic a large number of the parts on a Ferrari are from ordinary parts suppliers who put their ordinary part in a Ferrari box. The price is then multiplied by 10. A $3.50 Fiat oil filter is thus transformed into a $35 Ferrari oil filter. I cannot tell the difference, and I suspect my engine can't either. I once needed a servo motor that Ferrari wanted to sell me for $650. I found the VW version for $50. Worked just fine.
I realize that the difference is that if my car stops I am really just inconvenienced, and if a 747 stops several hundred people are dead, but I can understand the frustration in the budget limited Cessna owner. Still, I wouldn't want to fly in his plane, or be standing under it.
AirframeAS
Wed Dec 12, 2012 10:22 pm
Quoting twincommander (Reply 7):
Actually, it wouldn't be a "bogus" part......at all.... It would be an unapproved part, full stop.
You can't use a part from NAPA and put it on aircraft, even if the parts look identical. NAPA isn't FAA approved FAR Part 23/25 certified, AFAIK......
NAPA is an auto parts store.
twincommander
Wed Dec 12, 2012 10:28 pm
Quoting AirframeAS (Reply 9):
correct. proper terminology aside.
however, i avoid napa parts even for my beater truck. regardless if they are better than OE...
BE77
Thu Dec 13, 2012 8:11 pm
Quoting aklrno (Reply 8):
Not nearly as common as before, but very, very likely that you have done both it you were in or around general aviation 20 or 30 years ago.
Quoting twincommander (Reply 10):
Generally a good policy to follow!
Very true. Also generally not safe, and may be really stupid to use.
There are some pretty unreliable approved parts too that we keep using because the certification isn't worth anyone's trouble.
A couple years ago I got caught in a electrical switch AD, and the $1100 replacement set which will eventually fail the same way could have been replaced with much better stuff for about $50, but it would have cost way more to certify than the $1000 cost per flying mid 70's to mid 80's Beech to certify.
Very true - and the supply chains are managed now to meet those rules, very aggressively.
25 or so years ago, not so much. It WAS the same part, and was tracked equally poorly. Even buying from an av supplier was not a guarentee of anything.
The paper trail, while expensive, has improved enough that it is getting much more difficult to get bogus parts in - and very few accidents are traced back to bogus parts.
(I suppose unapproved is the Ford alternator - maybe it's not bogus because it is the same part number, but it is unapproved since the paper trail back to Ford doesn;t exist, and so it might be bogus...)
