novice
Boeing 737ng Flap Settings?
Thu Dec 06, 2012 11:18 pm
From what i know the Boeing 737ng has got 8 flap settings right? being; 1,2,5,10,15,25,30 and 40 does these numbers refer to degrees the angle its being reflected to the air at? if so why is there so little difference between 1,2 and 5 compared to the rest?
BMI727
RE: Boeing 737ng Flap Settings?
Thu Dec 06, 2012 11:36 pm
Quoting Novice (Thread starter):
Only in a very broad sense that it approximates the angle of the main flap. Once you're getting into the more complicated slotted flap setups of today, it gets muddled quickly.
Airbus, and most other manufacturers as well I believe, simply number the positions 1, 2, 3, etc. and completely dispense with angles. McDonnell Douglas, on the other hand, actually did have the designation correspond closely to the flap angle, which was actually important on their aircraft with the dial-a-flap feature.
tdscanuck
Fri Dec 07, 2012 2:11 am
No. Once upon a time, as BMI727 noted, they corresponded to the actual angle of physical things. That day is long past...now the numbers just stay what they are for commonality reasons.
1, 2, and 5 are takeoff settings. You don't want big deflections for takeoff because you don't want to drive drag up to high. For current Fowler flap designs, 1, 2, and 5 typically just push the slats out (improved stall AoA) and the slats back (not down), which increases area and hence lift.
Tom.
wilco737
Fri Dec 07, 2012 5:03 am
Quoting tdscanuck (Reply 2):
The 737NG is certified for flaps 15 and 25 take offs. As you said, it induced a lot of drag, but adds more lift for field length limited take offs where the terrain is no problem. I did a flaps 25 take off once on the 737-800, was interesting.
wilco737
tdscanuck
Fri Dec 07, 2012 1:55 pm
That should have said the *flaps* back...
wilco737's abosolutely right about the deep flap takeoffs...you get even more lift by deflecting the flaps but you pay a big drag penalty to do it. If you have the runway/terrain combination for it to work it can be useful.
Tom.
IAHFLYR
Fri Dec 07, 2012 2:45 pm
Don't most 800/900 operators use Flaps 30 for landing when the runway allows to avoid high deck angles and tail strikes?
wilco737
Fri Dec 07, 2012 5:25 pm
Quoting IAHFLYR (Reply 5):
Yes, we Used flaps 40 only when the runway was rather short. Most of the time we used flaps 30.
wilco737
chrisjw
Fri Dec 07, 2012 5:28 pm
I believe CO (now UA) forbid flaps 40 landings on their -900ER's due to the increased tailstrike risk. They also don't do derated takeoffs on the 900ER
BMI727
Fri Dec 07, 2012 7:07 pm
Quoting wilco737 (Reply 6):
I think many early 737s had flaps 40 deactivated due to noise concerns.
barney captain
Fri Dec 07, 2012 10:31 pm
The option that WN took on our -800's delays full slat extension until Flaps 25, as opposed to the standard Flaps 10 position. This is apparently part of a short-field package offered by Boeing.
Southeast Of Disorder
Mir
Fri Dec 07, 2012 11:38 pm
Quoting BMI727 (Reply 8):
That doesn't make a lot of sense - why deactivate them if you could just put an item in the ops manual that says "Flaps 40 shall only be used if necessary for performance considerations"? That why you can still use them, but the crews won't do so unless they have to.
-Mir
Jetlagged
Sat Dec 08, 2012 2:39 am
Quoting Mir (Reply 10):
That's exactly what they did though. That way crews can't accidentally select flap 40. But deactivating Flap 40 was simply a matter of blocking flap lever movement beyond the Flap 30 detent. Basically screwing a lump of metal into the pedestal.
Fabo
Sat Dec 08, 2012 5:37 am
I am in no way to be held as knowledgeable, but it would not surprise me, if at some airports/countries, a "worst case" noise level was considered in some application. It would make sense then to disable Flaps 40. You would be essentially doing the same thing (for example) Ryanair is doing with lowering their MTOW on their 738s. Since many fees are made off of MTOW, they are saying "We know the airplane could do more, but we made it so it will not do more".
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
CM
Sat Dec 08, 2012 6:56 pm
737-700 & -800 flap handle detents correlate to flap deflection angles as follows:
Detent......Angle
1...........8 degrees
2...........11 degrees
5...........14 degrees
10.........19 degrees
15.........22 degrees
25.........26 degrees
30.........35 degrees
40.........46 degrees
The -900ER has the same detents, but I believe it has slightly different deflection angles than the -700 and -800.
YYZatcboy
Sun Dec 09, 2012 1:14 am
The problem with flap 30 landings on the NG is it incorporates a 5-10kt increased speed bias in the VREF so you are flying your approach faster than you normally should to avoid tail strikes. Flaps 40 does not have this so you can fly your approach slower without that tailstrke risk.
DH1/3/4 MD11/88 L1011 A319/20/21/30/80 717 727 735/6/7/8/9 744 762/3 77E/W E40/75/90 CRJ/700/705 CC150
J/S DH8D 736/7/8
barney captain
Sun Dec 09, 2012 10:27 am
Quoting YYZatcboy (Reply 14):
I'm fairly certain that's only true for the 8/900 - the 6/700 have no increased REF speed bias.
YYZatcboy
Sun Dec 09, 2012 10:46 pm
Yes I believe you are correct sir. My mistake. Will have to go back to my FOM and re read it...
J/S DH8D 736/7/8
Users browsing this forum: ferpe, Ryanair01, SCAT15F and 1 guest
