LAXintl
Pilot Review: Flying The Boeing 787
Thu Dec 13, 2012 7:05 pm
Aviation Week pilot and aircraft evaluation reporter Fred George recently received the opportunity to pilot the 787 between Boeing-King Field to Moses Lake and is out with written story and video report about his impressions and experience.
Article:
http://www.aviationweek.com/Article....e-xml/AW_12_10_2012_p46-522072.xml
Video:
http://www.youtube.com/watch?feature=player_embedded&v=-s9ynMnPdCQ
waly777
RE: Pilot Review: Flying The Boeing 787
Thu Dec 13, 2012 9:11 pm
Flightglobal also did something similar last week.
http://www.flightglobal.com/news/art...-the-boeing-787-dreamliner-379890/
Both articles certainly give a very positive impression of flying the airplane.
The autodrag feature enabling the plane to intercept the ILS from the top, is that a first?
The test of first-rate intelligence is the ability to hold 2 opposed ideas in the mind concurrently, and still function
tdscanuck
Fri Dec 14, 2012 1:40 am
Quoting waly777 (Reply 1):
That exact implementation is a first, as far as I know. The concept of increasing drag to modify glidepath is not new. The 787 needed it because it's so slippery...it's very hard to descend at steady speed at much more than about 4 degrees without adding more drag.
Tom.
airtechy
Fri Dec 14, 2012 7:14 am
Based on the article, it is evidently possible to (accurately enough) determine airspeed and altitude without pitot and static port inputs, but instead using the combined input from other sensors. I'm amazed.  Wow!
Better CRM based on tracking controls! Gosh, who would have thought that.
DarkSnowyNight
Fri Dec 14, 2012 11:30 am
Quoting tdscanuck (Reply 2):
A pilot I know said she started doing that with 757s when the winglet mods came out. Of course it was manually, and without the ability to deploy them progressively outboard-in, but I've heard that's another plane that just wants to stay in the sky all day. In my own travels, I've noticed this a lot too on 757s with the wing dingers; maybe it's company SOP at some airlines now...
Much like a GE90, I'm a huge fan of Big Twins...
JHCRJ700
Fri Dec 14, 2012 2:29 pm
Interesting, I noticed on my recent 787 flight that it seemed like they were using more speed brakes then usual on decent and now I know why! Thanks for the info. When I spoke with the pilots they were both very excited about their new toy. Looking forward to reading these articles.
RUSH
tdscanuck
Fri Dec 14, 2012 2:33 pm
Quoting airtechy (Reply 3):
It's accurate enough to keep you flying...but not good enough to maintain RVSM or RNP so you don't want to use it as your primary system. It's a lot better than now knowing how fast or how high you are though, that's for sure.
Tom.
s5daw
Fri Dec 14, 2012 2:36 pm
Did I understand correctly 787 has a system that could prevent the AF447 when pitots are disabled?
tdscanuck
Fri Dec 14, 2012 3:24 pm
Quoting s5daw (Reply 7):
Sooooort of. The 787 has a non-pitot airspeed backup system as standard, which the AF447 A330 didn't have (but Airbus does offer as an option called BUSS - BackUp Speed Scale on some of their aircraft, I believe including the A330). So, if a 787 had iced over all the pitots, the system would have reverted to AOA SPD and the flight crew would have retained an airspeed tape (albeit with somewhat degraded accuracy). However, nothing would prevent a 787 flight crew from climbing, stalling, and crashing as the AF447 crew did.
Tom.
av757
Fri Dec 14, 2012 3:43 pm
Quoting JHCRJ700 (Reply 5):
Quoting tdscanuck (Reply 2):The 787 needed it because it's so slippery...it's very hard to descend at steady speed at much more than about 4 degrees without adding more drag.
Originally installed on the L1011 TriStar that used to use the Direct Lift Control System (DLC) as it was called by Lockheed. Where the system automatically activates spoilers on top of the wing to increase or decrease lift during the descent maintaining minimal pitch changes allowing for high rates of descent with minimum airplane attitude changes and good speed control during approach.
Quoting tdscanuck (Reply 8):
Yes they do offer it as optional equipment, all of Avianca´s A330-243's have BUSS installed.
AV757
s5daw
Fri Dec 14, 2012 3:47 pm
If non-pitot airspeed system is activated on a 787, does the plane degrade into direct law or some other law with no envelope protection? (as it did in case of AF447 after ADR disagree?)
Same question for Airbus' BUSS.
JAAlbert
Fri Dec 14, 2012 3:48 pm
Interesting article - to the extent I could understand it! The article states the fuel tanks are flooded with nitrogen to prevent fire - how exactly does an airline do this? Do the fuel trucks now carry a tank of nitrogen as well?
longhauler
Fri Dec 14, 2012 3:54 pm
I found that to be a fascinating feature too!
Back driven flight controls and throttles appears to be a Boeing staple. It almost appeared to be a "slap" at Airbus.
It is interesting to note that as new aircraft are being developed, Boeing and Embraer with FBW, back drive the flight controls and throttles, where Airbus and Bombardier chose not to. (Although I can find no reference if the Cseries throttles move).
oldoilguy
Fri Dec 14, 2012 4:35 pm
Quoting JAAlbert (Reply 11):
I don't know exactly how 787 fuel tank system works. But, in oil tankers and oil industry, N2 recovered from engine/boiler exhaust gases (via scrappers) has been injected into top of the tanks to prevent fire for many years.
[Edited 2012-12-14 08:37:09]
SEPilot
Fri Dec 14, 2012 5:48 pm
This information would likely have saved AF447-I'm surprised that they did not have more ability to determine their airspeed than they did. GPS will give groundspeed, and knowing the winds will give you a pretty good idea of airspeed. But I guess the real problem with AF447 was lack of situational awareness, probably compounded with panic, and there is little that can overcome that combination in time.
mpdpilot
Fri Dec 14, 2012 6:27 pm
I find cockpit design to be quite fascinating, and videos like this one are just awesome!
After watching a video like this I really can't think of a situation where the pilots would loose control like the AF447 incident (not knocking Airbus).
Also after watching this video I found a video about the C-Series cockpit. And it brought up some questions about cockpits and their design.
How do companies like Boeing, Airbus, and Bombardier know how to design their cockpits? Is there a lot of independent research or is it all in house?
The Chief Pilot of the C-Series made a comment in the video about the cockpit, something like "this cockpit doesn't feel like it was designed by a 60 year old airline captain". Having only ever been trained on CRJs it got me thinking about how things have changed with cockpits and how manufactures make those decisions.
During my CRJ training, I felt that the CRJ was one of the most intuitively designed cockpits I had ever seen. Everything made sense to me, which made the significant departure in the C-Series all the more interesting. For example, the decision to go to the side-stick, I am a yoke person, I much prefer it over stick aircraft but why the change?
Even if you look at the 777 to 787 the cockpits aren't that different, even going back to the 767. So why does Boeing seem to have their "Boeing" style cockpit yet Bombardier doesn't.
Someone mentioned how Bombardier is going the Airbus route with design, though I feel like the 787 cockpit is way more advanced than the A380 (though I probably just don't know enough about the A380 cockpit).
Here is that video I mentioned:
http://www.youtube.com/watch?v=YyVa8amVPig
One mile of highway gets you one mile, one mile of runway gets you anywhere.
tdscanuck
Fri Dec 14, 2012 7:31 pm
Quoting s5daw (Reply 10):
787 flight control laws will go into secondary mode (Boeing has Normal/Secondary/Direct) with loss of pitot data. The PFC's are still in the loop but running simpler control laws that don't need the air data to function. 787s, like all Boeing 7x7s, don't have hard envelope protection so they can't lose it. Some of the protection warnings and tactile cues may not function in secondary mode.
The system compresses ambient air through a solid-state air-separation module. It's basically a bunch of small tubes made of a material that's preferentially permeable to oxygen. Oxygen enriched air goes overboard, nitrogen enriched air goes into the tanks through vent tubes. No ground service or action by the airline required. It's basically the same as the military OBIGGS (OnBoard Inert Gas Generation System):
http://www51.honeywell.com/aero/technology/solutions/obiggs.htm?c=13
Quoting mpdpilot (Reply 15):
They have flight deck design groups. A lot of the design is dictated by regulations, the rest is a hybrid of a lot of in-house trade secrets, independent research, and human factors stuff from industry, customers, and academia.
Technologically, they're pretty close. The 787 has slightly newer components but that manifests more in things like larger displays than in being more technologically advanced. The A380 *looks* older because of some commonality and architecture choices but that's just cosmetic.
Tom.
BoeingGuy
Fri Dec 14, 2012 10:12 pm
Quoting tdscanuck (Reply 16):
And well proven and vetted philosophies. The 787 certainly wasn't Boeing's first rodeo so to speak. Its flight deck is based on many years of experience.
bhill
Fri Dec 14, 2012 10:16 pm
Very cool....how many quarters does it require?? I want a turn!!!
Carpe Pices
seabosdca
Sat Dec 15, 2012 1:47 am
Quoting bhill (Reply 18):
A roll of quarters weighs approximately half a pound and has $10 worth of quarters.
A typical day-cab semi truck can carry a payload of approximately 60,000 pounds, so a semi truck loaded to load limit with quarters has about $1.2 million in it.
So if my math is right, a medium-size fleet of semi trucks' worth of quarters ought to get you your own.
[Edited 2012-12-14 17:47:37]
Users browsing this forum: Mir and 1 guest
