ecbomberman
What Is Wrong With This VS 343 Fin?
Sun Dec 16, 2012 2:30 pm
What's wrong with this VS A343 Fin? It seems that it has been torn apart. Doesn't seem to be a regular check as the photographer has mentioned. Can anyone shed some light?
Photo © Dn280
[Edited 2012-12-16 06:34:28]
VS343/346/744 CX744/L1101/343 MH332/333/733 BD32x/EMB 145 AK320 SQ310/77E/773/744 UA747SP/744 BA744 BI763ER/319 QF763ER
rwy04lga
RE: What Is Wrong With This VS 343 Fin?
Sun Dec 16, 2012 2:42 pm
The rudder is removed....so? It also states that it's a 777 for CX, which doesn't seem correct.
Just accept that some days, you're the pigeon, and other days the statue
anstar
Sun Dec 16, 2012 2:45 pm
Quoting rwy04lga (Reply 1):
The photographer looks like they may be IN a 777 from CX.
Plus all the airbus heavy maintenance is done in Manilla - so presumably G-VFAR (which is the only 343 owned by VS) is undergoing some routine Maintenance there.
Dalmd88
Sun Dec 16, 2012 4:07 pm
It might have been repainted. Usually the rudder has to be removed to repaint and then re balance.
Mon Dec 17, 2012 6:14 am
Quoting anstar (Reply 2):
Yep, that looks like the top of a 777 engine.
Looks like the ramp near the Lufthansa hanger, that also looks like the new VS red has been applied.
ecbomberman
Tue Dec 18, 2012 2:18 am
Zeke,
Are those hinge points for the rudder or has it been torn out. The reason I'm asking is because there are bits and pieces sticking out in the remainder part of the rudder.
tdscanuck
Tue Dec 18, 2012 3:34 am
Quoting ecbomberman (Reply 5):
Those are hinges and actuator attach points. If you tried to tear the rudder out, you'd probably take the spar out too (the hinges probably aren't the weakest part).
Zoom in on the tail here and you can see some of the lower structure:
http://www.flightglobal.com/airspace...industrie-a330-cutaway-drawing.jpg
http://www.flightglobal.com/airspace/media/civilaviation1949-2006cutaways/images/82665/airbus-industrie-a330-cutaway-drawing.jpg
Tom.
b78710
Tue Dec 18, 2012 6:02 pm
Definately rudder removal, not been torn off.
Heavy maintenance is performed by LTP in Manilla.
