Quokkas
Wing-mounted Versus Tail-mounted Engines
Mon Dec 17, 2012 4:58 pm
An obvious one maybe, but I am not an engineer.
We see aircraft designed to have rear (tail) mounted engines and aircraft that have wing-mounted engines. Compare the E145 with the E170, for example. Both have two engines. The former has the engines mounted at the rear while the latter has them suspended from the wing.
Is there any performance benefit in having one versus the other and at what point does it become impractical to design an aircraft with rear mounted engines (I'm guessing passenger capacity and the weight of the engines and structural strength of supports would be involved)?
Current aircraft tend to have two engines but in the past there were a number with three. What motivated the move to two? Was it just improved efficiency, reducing the weight, or reducing maintenance costs with having fewer engines to maintain?
Fabo
RE: Wing-mounted Versus Tail-mounted Engines
Mon Dec 17, 2012 5:39 pm
Big thing with twins is lower maintenance. If you can make it with two engines, you do it. Only if you cant (such as A380), you start thinking 4.
Wings vs. tail mounted is discussed often around here. Short version, plane with engines under wings is lighter, therefore more economical. If there is a recent plane with tail mounted engines, there is probably other design constraint, like it being too small for it to make sense to place the engines under the wings, or it needs fuselage to be low, so that you can benefit from easy access to it (typically bizjets, you want to be able to operate without external stairs and beltloaders and whatnot)
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
L-188
Mon Dec 17, 2012 6:05 pm
The big reason that engines got mounted on the tail was for cabin noise, the cabin is just that much quieter with the engines way back there.
Tail mounted engines also are less likely to pick up fod from sloppy runways, are less likely to be damaged by something running into them, and allow for a clean wing leading edge whose while length can be used for lift devices.
Wing mounted engines are easier to service, less likely to be fodded by ice on the wings but more likely to be fodded by runways slop. And the tail structure of those aircraft can be made lighter since they aren't supporting motors. Also wing mounted designs are simpler to offer multiple engines types on since on e pylon really has to be changed. However
flyingturtle
Mon Dec 17, 2012 6:21 pm
Hi,
yes, this discussion often pops up. And it gives you a good opportunity to learn about aircraft design.  Smile
Some older threads about that topic:
Engines Under Wing Or On Fuselage (by Extra300 Oct 18 2012 in Tech Ops)
Wing Mounted VS. Fuselage Mounted (by Jmacias34 Oct 19 2001 in Civil Aviation)
Under Wing Engines Vs Tail Mounted Engines (by Qatar Feb 27 2002 in Civil Aviation)
Happy reading & your questions are always welcome!
David
[Edited 2012-12-17 10:27:54]
DocLightning
Tue Dec 18, 2012 1:12 am
Quoting L-188 (Reply 2):
That and also because at the dawn of the jet era, smaller aircraft like the Caravelle and DC-9/727 might have been operating into semiprepared airfields. Rear-mounted engines are much less likely to ingest FOD.
The 737 Jurassics sat about the same distance off the ground as the 727 did, in spite of having wing-mounted engines, and the engines were the same JT8D's used on the DC-9 and 727, so it probably wasn't necessarily about noise (although Boeing marketed the 727 that way). The original 737 had an optional gravel kit that allowed it to operate out of gravel airstrips with reduced FOD risk.
-Doc Lightning-
-Carl Sagan
fanofjets
Wed Dec 19, 2012 4:59 pm
...In addition, the wing-mounted engines counterbalance wing flexing that would occur as the airplane gained speed during take-off, allowing for a more economical wing structure.
The aeroplane has unveiled for us the true face of the earth. -Antoine de Saint-Exupery
flyingturtle
Wed Dec 19, 2012 5:35 pm
Quoting fanofjets (Reply 5):
That's also the matter during cruise.
For the same reason, the center fuel tank is emptied first, afterwards the wing tanks are.
David
Viscount724
Wed Dec 19, 2012 11:52 pm
Quoting DocLightning (Reply 4):
Some 727s operated from unpaved runways but as far as I know, no Caravelles or DC-9s were certificated for such operations. 737-200s of course did (and still do in Canada) and Boeing offered a gravel runway kit for that model.
workhorse
Tue Dec 25, 2012 3:28 pm
Talking about wing mounted engines, I have always wondered who can be reasonably called the inventor of this way to mount engines on aircraft (that is, on pylon under the wing)? This can definitely be called one of major inventions in aviation history: it's still in use after at least 60 years!
It looks like the first passenger aircraft to feature this was the Boeing 707, however, the DC8 had a similar layout and was developed around the same time.
Looking at military designs, it seems that the first one was the B-47 (Boeing again), followed by the B-52, however, I wonder if there wasn't a German WWII design (Arado?..) that had something like that as well...
[Edited 2012-12-25 07:35:30]
flyingturtle
Tue Dec 25, 2012 5:04 pm
Quoting workhorse (Reply 8):
Yes, the Arado 234 bomber and the Messerschmitt 262 fighter, for example. The British Gloster Meteor had engines like the RB-57, and all other jet fighters of that era had the engines within the fuselage (AFAIK).
David
U2380
Tue Dec 25, 2012 10:40 pm
Wing mounted engines have the benefit of increasing the speed before the occurrence of wing flutter (or in other words, gives greater buffet margin) by damping out aeroelastic forces. This allows the wing construction to be lighter. Aft mounted engines also require the tail section of the aircraft to be reinforced.
Rear mounted engines also have a rearward effect on CoG which may require a larger tailplane and control surfaces. One way of counteracting that issue is the T-tail.
As a side note, aft mounted engines tend to produce a pitch down moment upon application of thrust and wing mounted engines produce a pitch up effect ( the thrust line is below the CoG) all other things being equal.
However, aft fuselage mounted engines do have their own advantages, for example they produce a lesser yawing moment in the event of an engine failure and they also allow the wings to be 'cleaner' in comparison to wings with pylons and engines attached.
Well, that's my rather rudimentary ATPL understanding, I'd be more than happy for more knowledgeable members to correct me.
[Edited 2012-12-25 14:44:16]
[Edited 2012-12-25 14:51:21]
tdscanuck
Wed Dec 26, 2012 7:33 pm
I believe credit goes to the Germans. The British had a love affair with embedded engines for a while, and the B-47 and it's descendants stole basically everything they knew from the Germans after the war.
An aero prof of mine once said that the answer to "Who first thought up X configuration?" is always "The Germans in World War II."
Tom.
Users browsing this forum: SAAFNAV and 1 guest
