CVR CB Pullout....When.
Mon Dec 17, 2012 7:24 pm
What is the SOP regarding CVR CB pulling out at the end of the flight....Out here we have two norms....For the B737 The CVR CB is pulled out after every Chocks on post Crew checklist readout,where as on the B757 it is pulled out only after chocks on & crew checklist completion after the LAST flight of the day/night.
longhauler
RE: CVR CB Pullout....When.
Mon Dec 17, 2012 7:36 pm
Per SOP, we are never instructed to pull out a CVR or FDR C/B unless an incident is suspected. Then when we do, we must advise Maintenance Operational Control that the C/B is pulled.
Mon Dec 17, 2012 7:55 pm
Quoting longhauler (Reply 1):
What about long halts when power is switched off the Aircraft totally....
CosmicCruiser
Mon Dec 17, 2012 8:13 pm
AS longhauler said we never mess with the CVR CB unless we want to preserve the tape due to a suspected incident.
Dogbreath
Tue Dec 18, 2012 8:20 am
Not sure what type of B737 you fly there HAWK2M, but on the B737-800, there is no requirement to open the CVR CCB after the final shutdown and for long ground stays.
The Flight Recorder has two positions, Auto and On, and is defaulted to Auto.
In the Auto position, the CVR will begin to record after the start of the first engine and will remain recording until 5 minutes after the last engine is shutdown. So there is no reason to open the CCB after the last shutdown.
The ON position (which is held in place by a solenoid) will begin the recording as soon as the switch is held in place (provided it is electrically powered). It spring loads to Auto during the start of the first engine, or when elec power is lost (ie. when shutting down elec power after the last flight).
In my airline's SOP, we select the Flight Recorder switch to ON when doing the pre-flight checks, so that the pre-flight and briefings are recorded, and again after we land and the engines are shutdown, so that the turnaround and subsequent briefings for the next leg is recorded.
Like a few other posters on here have written, any time the CVR CCB is opened a Tech Log entry must be made and the reason why it is opened reported.
Truth, Honour, Loyalty
b78710
Tue Dec 18, 2012 5:50 pm
We have a quality notice to pull it after any reportable incidents.
And usually Maintrol will contact you when they want it pulled.
Not pulled at any other times
Wed Dec 19, 2012 6:49 am
Quoting Dogbreath (Reply 4):
That was the B732F in those days.
Quoting b78710 (Reply 5):
Thats done after any Incident reported to avoid rewriting on the CVR and data erasure.
BTW...The Parking brake set & erase button depress facility has to be deactivated out here due Regulatory requirement, by removing the erase supply/card at the module itself.This is not common in other places.
TheCol
Wed Dec 19, 2012 10:13 am
Quoting HAWK21M (Reply 6):
Is that only exclusive for the 732F, or does that apply to all 732s in India? My employer operates 732s in a combi config, and, as far as I'm aware, the crews aren't normally required to pull the CB.
No matter how random things may appear, there's always a plan.
Wed Dec 19, 2012 10:44 am
Quoting TheCol (Reply 7):
This mandatory modification issued by the Regulatory is required to be complied by ALL aircraft registered in the country.
The intent was to eliminate the erase of CVR recorded data.even the switch disconnection was not reccommended as a short could have still erased data,but required the Card to be removed from the CVR module itself.
LimaFoxTango
Thu Dec 20, 2012 12:29 pm
In the Dash 8, the CVR starts recording as soon as power is applied to the aircraft. The FDR starts recording when the anti-col is turned on before engine start or weight off wheels signal.
You are said to be a good pilot when your take-off's equal your landings.
readytotaxi
Thu Dec 20, 2012 5:31 pm
Question, what happens to the box when an aircraft is parked in the dessert for X months, is the box removed after arrival or left in place until scrapping
Thu Dec 20, 2012 7:07 pm
Quoting readytotaxi (Reply 10):
An Aircraft that is parked under preservation schedule will retain the Module unless it is due for a shop visit.
Users browsing this forum: Arniepie, BlueF9A320 and 2 guests
