Gonzalo
Thrust Reverser Deployment Before Touchdown
Tue Dec 18, 2012 6:07 pm
I was doing my usual tour for some of the aviation video channels, and I came across this video of a Tu-154 activating the thrust reverser well before the wheels touched the runway. I had the ( wrong? ) idea about all the commercial / civil aircraft had weight on wheels sensors, to prevent in flight deployment of the T/R ( I remember the case of a Lauda Air Boeing 767 crashed after an uncommanded T/R activation, with a high loss of lives )
Video :
https://www.youtube.com/watch?v=Yq5HLtdGeqE
Is this a characteristic of the Tu 154 ? Or was this particular aircraft on the video under some special condition ( MEL'd, Ferry flight to MX ) ?
Are there any other civilian / pax aircraft type / model that allows this ?
Thanks in advance.
Rgds.
G.
Gear Up!!: DC-3 / EMB-110 / Fairchild-227 / Ab318-19-20-21 / B732 / B763 / B789
DocLightning
RE: Thrust Reverser Deployment Before Touchdown
Tue Dec 18, 2012 6:17 pm
Quoting Gonzalo (Thread starter):
Deploying The Thrust Reverser While Flairing? (by LH492 Jul 25 2006 in Civil Aviation)
Photo Question (by Kaitak744 Oct 24 2005 in Civil Aviation)
There are a few others. Presumably, the Tu154 locks out the reversers until the engines are at idle, although given that it's a 1960's Russian design, I'm not entirely sure about that.
-Doc Lightning-
-Carl Sagan
northstardc4m
Tue Dec 18, 2012 6:18 pm
This was the case on a few jetliners:
DC-8 up to model 61
VC-10
IL-62
some models of Tu-134 and most is not all models of the Tu-154
Not common but if the plane is designed for it...
DC-8s had it only on engines 2 and 3, and some issues causing a couple crashes cause it to be disabled later on.
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety.
Spacepope
AFAIK a few other aircraft can do that too, including the IL-62. See at about 0:32 on this video: http://www.youtube.com/watch?v=N29ZFnQfm7I
Fuzzy memories make me think the DC-8 was also capable.
BoeingGuy
Tue Dec 18, 2012 6:29 pm
Quoting northstardc4m (Reply 2):
The DC-8 in flight thrust reversers were intended to be used as speedbrakes. I don't think they were intended for use shortly before touchdown the OP was referring to. I'm not aware of crashed because of it. I experienced as a passenger as late as 1977 and thought I heard that the CFM engines on the -71s and -73 were also designed to used in reverse in flight.
Can you elaborate on the crashes and how in-flight thrust reverse used was disabled on the DC-8s?
migair54
If i´m not mistaken the conconrde also could do to reduce speed, Russian planes as usual have some special features, they fly in somehow a different way from the western planes.
For example, when you see a russian plane taking off, for them getting speed first and then climbing is the procedure, but for western planes altitude is first then speed, if you think a bit in a place with a big clearway and no noise abatement it could be a good practice because in the Lift formula V is Square so increasing speed has a very big effect on lift.
But anyway, I´ve seen few Tu-154 and IL-62 mainly doing that. I think the pilatus porter can also do, but of course that´s not a jetliner.
i´m sure the forces generated in the pylon of the engines must have been terrible, they are designed to do let the engine pull the plane forward and not backward.
citationjet
Tue Dec 18, 2012 6:33 pm
Here are other threads on this topic:
DC-8 And Reverse Thrust Use In Flight (by Ttailsteve Jul 3 2006 in Civil Aviation)
Thrust Reversers Before Touchdown? (by DocLightning Jul 7 2008 in Tech Ops)?threadid=232417&searchid=232483&s=DC-8+reverse#ID232483
Inflight Reverse Thrust On DC 8 (by 6YJCX Dec 4 2007 in Tech Ops)?threadid=211585&searchid=211930&s=DC-8+reverse#ID211930
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
BlueShamu330s
Tue Dec 18, 2012 6:34 pm
Flying around India
northstardc4m
Tue Dec 18, 2012 6:35 pm
Quoting BoeingGuy (Reply 4):
http://www.airliners.net/aviation-forums/tech_ops/read.main/211585/
apparently all 4 engines could do reverse sorry... and I was under the impression that it was actually disabled, though apparently it was just airline policy.
And i'm finding more types:
Trident
Concorde
Tu-144
Jetstar
Tristarsteve
Tue Dec 18, 2012 7:38 pm
Quoting northstardc4m (Reply 8):
Trident
Ah de Havilland.
Now the Trident only had reverse on 1 and 3.
But they were deployed regularly in the descent as speedbrakes.
Then the aircraft could descend very fast. So fast that one Trident, I think it was the 2E did not have passenger oxygen fitted. In case of emergency, engines to idle, select reverse, descend nose down!
BoeingGuy
Tue Dec 18, 2012 7:40 pm
Quoting Tristarsteve (Reply 9):
I can't imagine that. It's still like 3 minutes from cruise to 10,000 feet.
MH017
Tue Dec 18, 2012 8:37 pm
Flew once a Syrian YAK-40, and they applied the (single) thrust-reverser before touch-down at DAM...
don't throw away tomorrow !
longhauler
Tue Dec 18, 2012 8:48 pm
Actually, it was the other way around. The Trident One, and the Trident Three did not have passenger oxygen (in Britain, I am not sure about export models), the Trident Two did.
Same thing with most versions of the BAC-111, no passenger oxygen.
tdscanuck
Tue Dec 18, 2012 10:55 pm
They all have systems to prevent inadvertent T/R deployment. Those aren't always weight-on-wheels sensors. The 737, for example, can deploy off the radio altimeter (and hence can deploy in a very thin range of "in-the-air").
Tom.
737tdi
Wed Dec 19, 2012 12:01 am
Quoting tdscanuck (Reply 13):
Tom
Tom: I believe once the "sync-loc" mod. was installed the reversers can not and will not deploy until weight on wheels. You can pull the handle but nothing will happen until then.
As far as the DC-8 the inboard reversers can be deployed at any time. There is a mechanical lock off of the nose landing gear to prevent deployment of the outboard reversers. I have flown many test hops where this system was verified and it feels like you hit a wall when those CFM-56-2s are reversed in flight. Remember the DC-8 does not have speedbrakes so they use the reversers to slow.
PGNCS
Wed Dec 19, 2012 1:06 am
Quoting Gonzalo (Thread starter): I had the ( wrong? ) idea about all the commercial / civil aircraft had weight on wheels sensors, to prevent in flight deployment of the T/R
Tom.
The DC-9 series has nothing to inhibit inflight deployment (WoW or RA, etc.) other than good sense. In over 10,000 hours on the aircraft I have never seen it be an issue. Of course the throttle does have to be at idle first, so I suppose you could make the argument that this interlock is a system to prevent inadvertent deployment, though it will NOT prevent inflight deployment regardless of altitude.
tdscanuck
Wed Dec 19, 2012 1:32 am
Quoting 737tdi (Reply 14):
The sync-lock is triggered by microswitches on the T/R deploy handles...the sync-locks will release as soon as you pull up on the handles. They're there to prevent a Lauda-type incident by providing an independent level of redundancy in the actuation hardware. The sync-locks will not prevent an intentional deployment.
Assuming that the pilot pulls the levers (releasing the sync locks), another relay needs to actuate to command hydaulic fluid to the actuators. The ground for that relay can go through two paths...one is the air/ground system (basically weight-on-wheels) and the other is the radio altitude from the flight control computer (less than 10'). Either path is sufficient to allow deployment so if you're on the ground (specifically, the air/ground relay is in ground) or the FCC thinks you're less than 10' from the ground, the T/R's will deploy.
If you have access, check out 737 AMM SDS 78-34-00 for more details.
The key to most T/R systems is preventing *inadvertent* deployment. Many aircraft will inhibit deployment in flight regardless what the crew says but all of them don't want the T/R's to ever deploy unless the flight crew wants them to.
Tom.
XXXX10
Sat Dec 22, 2012 9:20 am
Not sure about the TU144
I may be wrong but AFAIK there where no T/R on this bird. I beleive a parachute was used on landing !
Sasha
Sat Dec 22, 2012 1:54 pm
Yak-40 also could do this. not sure about Yak-42. landed in one last sunday - it didn't use it
An2/24/28,Yak42,Tu154/134,IL18/62/96,B737/757/767,A310/320/319,F100,BAe146,EMB-145,CRJ,A340-600,B747-400,A-330-300,A-340
Fabo
Sun Dec 23, 2012 1:58 am
IIRC YK42 does not have reversers - at all.
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
atct
Tue Dec 25, 2012 4:05 am
Quoting BoeingGuy (Reply 10):
There are also regs (someone else will have to find em) that say how many O2 masks are required per passenger. I was a flight attendant on a US regional and though we "briefed" the masks, we did not have more than 1 for each 10 passengers on board the aircraft.
atct
Trikes are for kids!
DualQual
Thu Jan 03, 2013 9:42 pm
IIRC (haven't really looked at that system page in a while) it's 10feet on the RA you can deploy the reversers on the 737. I don't know why anyone would want to do that but you could.
There's no known cure for stupid
longhauler
Fri Jan 04, 2013 3:39 am
That must have been later B737s, the B737s I flew (-200, and -200ADV) required positive oil pressure and weight on wheels to power the hydraulics to work.
In fact, some of them also had a squat switch in the nose wheel as well, which also had to be activated. Makes sense, the -200 had huge buckets and in a nose high attitude, you could scrape them on the ground.
tdscanuck
Fri Jan 04, 2013 3:03 pm
Quoting longhauler (Reply 22):
Yes, I was talking -300 and onwards. -100/-200 had a totally different reverser system.
Tom.
Kaiarahi
Fri Jan 04, 2013 9:35 pm
NZ lost a DC-8 at AKL on a training flight when a TR was activated on a touch-and-go. My father was an FE with NZ at the time and scheduled to be on that flight, but was swapped out for other duties.
Empty vessels make the most noise.
BA777
Sat Jan 05, 2013 10:30 am
Yep thats correct on the 737 you can deploy them just before touchdown, a Captain did it last week and it made for a very....commercial landing!
fsnuffer
Sat Jan 05, 2013 2:30 pm
While at Offutt there were rumors RC-135 pilots were deploying TR during the flare and it was called a "Shemya Short Landing". Since I never took a flight to Shemya, it is only second hand.
longhauler
Sat Jan 05, 2013 3:57 pm
Quoting Kaiarahi (Reply 24):
When I hear stories like this, I often think of fate.
My father was supposed to be the Second Officer of the Trans-Canada DC-8 that was lost at YUL in 1963, but the crew's inbound flight was late and a reserve crew was used instead. When I asked him about that, he just said, "If I were on the aircraft, it wouldn't have crashed, I guess it was meant to crash!"
Maybe it was the same in your Father's case. His hand on the thrust levers might have had a different weight, angle, etc ... and the T/R would not have been activated.
Kaiarahi
Mon Jan 07, 2013 6:21 pm
Fate for sure! I can't find the accident report archived anywhere, but the story within NZ at the time was that the training captain (left seat) may have hooked his finger around the "leg" of #4 throttle (rather than the knob) and pulled it back aggressively (they were doing engine out drills), causing the TR to jerk up and deploy. If he'd had his hand on the top of the throttle, it likely wouldn't have happened. As I recall the report, there was a recommendation for better TR lever mechanical protection, but I don't remember if it was implemented. I do remember that when I was learning to fly Hercs a few years later, simulated engine out training was done with a smooth throttle retardation - the AKL accident was still fresh in everyone's mind.
Kaiarahi
Mon Jan 07, 2013 7:39 pm
Whoops - training captain was right seat .... And in the DC-8, they were actually called "thrust brakes", rather than TRs.
[Edited 2013-01-07 12:34:27]
Users browsing this forum: NZPM and 2 guests
