Max Q
PIA 747 Classic Question
Sun Dec 23, 2012 7:30 am
The great photo of the PIA 747 on approach to Karachi on the home page has me puzzled.
There is a cylindrical object above the left side window just behind the Captains left shoulder.
Anyone know what it is, Tds are you out there ?
amccann
RE: PIA 747 Classic Question
Sun Dec 23, 2012 8:02 am
Quoting Max Q (Thread starter):
I do not know the answer to your question. However to help in getting an answer and in case the home page image changes before the question is answered I have added the image to this thread.
Photo © Sam Chui
What one person receives without working for, another person must work for without receiving. - Ronald Reagan
Max Q
Sun Dec 23, 2012 9:25 am
Thank you Amc.
Very helpful of you.
freeze3192
Sun Dec 23, 2012 10:01 am
Sun shade would be my guess. There's one on the FO's side as well.
"A passenger bets his life that his pilot is a worthy heir to an ancient tradition of excellence and professionalism."
SAAFNAV
Sun Dec 23, 2012 10:07 am
If you mean the cylinder right above the side window, lying on it's side, then it would be the escape rope to go through the side window.
Erich
fr8mech
Sun Dec 23, 2012 4:10 pm
Quoting saafnav (Reply 4):
Unless PIA had some special version, and from the picture, it doesn't appear so, the B747 does not have a side window that can open. Emergency egress is through the crew service door via a slide or the overhead hatch using an escape reel.
I haven't been on a Classic in 5 years or so, but I think that unit is over the L3/R3 window. Can't recall what it is, though.
SAAFNAV
Sun Dec 23, 2012 4:29 pm
Quoting fr8mech (Reply 5):
My apologies then. I was guessing based on other aircraft I've seen with the escape rope in that position.
Thanks for the info!
Erich
747classic
Sun Dec 23, 2012 5:32 pm
This is a movable holder for locking one of the standard Boeing (green) sun shades.
The LH holder can be moved to any window at the LH side by a sort of rail system above the windows
The same rail system is installed above the RH windows, the RH holder is visible aft of the F/O position above window R3.
In our airline (KL) we had two holders installed for each side of the aircraft.
In the picture below you can see a green sun shade locked into the RH. holder . It was also possible to lock the sun shade in a 90 degrees rotated position.
Photo © Patrick Lutz
[Edited 2012-12-23 10:05:48]
Operating a twin over the ocean, you're always one engine failure from a total emergency.
amccann
Sun Dec 23, 2012 7:29 pm
Quoting Max Q (Reply 2):
Thank you Amc.
No problem. Just trying to help, even if I didn't know the answer.
Quoting 747classic (Reply 7):
Interesting, so it appears the green sun shade is removable from the movable holder? Where are the sun shades stored when not in use?
747classic
Sun Dec 23, 2012 8:44 pm
Quoting amccann (Reply 8):
At the LH side of the F/E panel, just behind the F/O chair, almost at cockpit floor level, were a few storage holders in our aircraft.
Users browsing this forum: Legs and 2 guests
