RussianJet
Parked On Stand With Strobes On
Thu Dec 27, 2012 10:41 am
So, as we came onto stand in AMS from JHB this morning, the 777 on the neighbouring stand was chocked and no beacon on, yet the strobes were going ten to the dozen for a good 15 minutes or more. Why would this likely be?
✈ Every strike of the hammer is a blow against the enemy. ✈
RE: Parked On Stand With Strobes On
Thu Dec 27, 2012 11:04 am
Quoting RussianJet (Thread starter):
and no beacon on,
Probably someone forgot about the switch in the on position........
RussianJet
Thu Dec 27, 2012 4:08 pm
Quoting HAWK21M (Reply 1):
and no beacon on,
Well, that's what I thought about suggesting, but in light of other threads that suggested a pilot may have 'forgotten' such a thing I didn't entirely dare to, fearing a flamefest.
Is that the most likely answer, or are there other possibilities?
PGNCS
Thu Dec 27, 2012 5:05 pm
Quoting RussianJet (Reply 2):
It's the most likely answer on most airliners other than aircraft that have strobes inhibited on the ground.
CosmicCruiser
Thu Dec 27, 2012 5:06 pm
maint. was doing a walk around chk. Our guys did it on every station where the jet laid over. Checked all lights, etc.
PGNCS
Thu Dec 27, 2012 5:10 pm
Quoting CosmicCruiser (Reply 4):
Good point and better stated than my post. I was trying to make the point that almost assuredly the issue was that the switch for the strobes was on for whatever reason, rather than a peculiar failure of some sort.
RussianJet
Thu Dec 27, 2012 5:11 pm
For at least 15 mins, and nobody seen on the ground performing such a check (which admittedly I had not mentioned earlier)?
Thu Dec 27, 2012 7:30 pm
15mins for strobe to be on while a check is being done seems too long....
speedbird128
Thu Dec 27, 2012 7:42 pm
Yup probably an abbreviated landing checklist LOL.
Same as all the departures with transponder still off. Or Mode S or FMC ID set to the previous leg's ID
A306, A313, A319, A320, A321, A332, A343, A345, A346 A388, AC90, B06, B722, B732, B733, B735, B738, B744, B762, B772, B7
Users browsing this forum: No registered users and 33 guests
