SKAirbus
CDG - Terminal 1 - Which Satellite?
Wed Jan 02, 2013 2:22 pm
Hi,
I am fascinated by Terminal 1 at CDG with its unusual design where planes park at the various satellites. However, I was wondering which airlines use which satellite or whether it is purely based on a divide between Schengen and Non-Schengen departures? Also, how many satellites are used for Intra-Schengen and Extra-Schengen flights?
Base: BRU. Next flights to: FRA, TLL, FCO, ATH, CPH, ARN, HKG, ICN, TPE, MAD, LIM, SCL
DFWHeavy
RE: CDG - Terminal 1 - Which Satellite?
Thu Jan 03, 2013 10:19 pm
I'm fascinated by Terminal 1 as well. Hopefully someone can shed more light on your questions.
Christopher W Slovacek
Viscount724
Fri Jan 04, 2013 1:24 am
Quoting DFWHeavy (Reply 1):
This 2009 publication by the Paris airports operator describes the major renovations at CDG T1 which had just been completed. It says that 3 of the 7 satellites are Schengen and the other 4 non-Schengen. Not sure if anything has changed since. It doesn't indicate which are which.
http://www.aeroportsdeparis.fr/ADP/R...2e5a8cabad-DOSSIERDEPRESSET1VA.pdf
SKAirbus
Fri Jan 04, 2013 1:55 pm
According to this Map: http://www.gofox.com/common/images/flights/airportmaps/cdg.gif
Only Satellite 6 is not covered by the red dotted line which makes me assume that it is for flights within the schengen area with the others within the passport control zone.. or am I wrong?
I imagine satellites 4, 5 and 6 would be the schengen with the other non-schengen if the pdf above is right. Confusing!
N1120A
Sat Jul 26, 2014 8:52 am
Quoting SKAirbus (Reply 3):
Satellite 7 is Schengen too, though the SAS lounge is brutally inferior to the LH one in 6
Users browsing this forum: alasizon, CanadianNorth and 2 guests
