audidudi
No Strobe Lights On The B787 Dreamliner
Fri Jan 04, 2013 9:15 am
Sorry if this has been mentioned before, but I noticed that the B787 Dreamliner does not have strobe lights on the wing tips, but instead has just single flashing white lights. Why did Boeing decide to do this when almost every other commercial and private aircraft has strobe lights?
ak907
RE: No Strobe Lights On The B787 Dreamliner
Fri Jan 04, 2013 9:37 am
That is the new strobe light. It's an assembly of LED's that simply blink. The 747-8 has the exact same thing. Probably less maintenance and power intensive. I actually think it looks better, easier to see too.
[Edited 2013-01-04 01:38:24]
tdscanuck
Fri Jan 04, 2013 2:59 pm
Quoting audidudi (Thread starter):
Strobes burn out. LEDs generally don't (at least, not over the aircraft lifetime). I expect you'll see a lot of this going forward...almost all OEMs are switching to LED lighting everywhere they can.
Tom.
vikkyvik
Fri Jan 04, 2013 3:53 pm
Quoting tdscanuck (Reply 2):
I was actually going to start a thread about this. Did Boeing do any studies regarding effectiveness of blinking lights versus strobes in recognizing and identifying aircraft? Did the different on/off config have to get approved by the FAA or anything?
Just curious, because it seems like the blinking lights would be less likely to attract my attention than the strobes.
DashTrash
Fri Jan 04, 2013 4:04 pm
I'm not a fan of those blinking LEDs, but they are more noticeable that strobes. They are brighter, and the longer duration of them being lit gives you a longer opportunity to spot them.
rfields5421
Fri Jan 04, 2013 4:16 pm
LEDs do burn out, but a LED of that type will be composed of dozens of very small individual bulbs, so a few burning out will not require replacing the entire light.
Quoting vikkyvik (Reply 3):
I'm confused. Strobes blink also.
Just the fade in/ fade out are different due to the physical nature of the bulb.
bond007
Fri Jan 04, 2013 4:23 pm
As long as they comply with the FARs, which is a flashing light 40-100 cycles/minute, specific angles of visibility, and intensity, then they would not need any special approval other than installation related ones.
Remember, before LEDs, the only easy way to flash a bright light every second or so, was to use a strobe. You cannot flash an incandescent bulb fast enough, and even if you could, it's life would be very short.
Although LEDs have been around for some time now, white LEDs, especially high-intensity ones, are fairly new to the market.
Jimbo
pilotpip
Fri Jan 04, 2013 4:38 pm
One of the CRJ-200 operators has put them on the tail of the aircraft as well. I think it's Air Wisconsin. Makes sense, LEDs have a much longer life and that will save mx costs over their life. I'm also starting to see them used as nav lights on a variety of aircraft.
DMI
vikkyvik
Fri Jan 04, 2013 5:10 pm
Quoting rfields5421 (Reply 5):
I know. But I notice a strobe much more readily than a slowly-blinking light. Just catches my eye much quicker. Especially when looking down at the ground at night - there are plenty of slowly-blinking lights on the ground, but relatively few strobes, so it's pretty easy to identify an airplane.
That said, I'm not a pilot, so....
tdscanuck
Fri Jan 04, 2013 6:09 pm
I'd be surprised if somebody didn't, just because that would be a huge risk when you change technology. No idea if it was Boeing though.
In principle, yes, but the just have to demonstrate FAR compliance (which never said anything about strobes).
I actually find they grab my attention *more*, but I can't tell if that's because they're inherently more attention-grabbing, or if it's because they don't look like strobes, hence look different than everything else, and that might not work so well once everyone has them.
Tom.
CALTECH
Fri Jan 04, 2013 6:15 pm
They seem to be very bright and work just fine. Saw them at IAH, they are bright.
http://www.youtube.com/watch?v=m3subQWRGCY
UNITED Would Be Nice
IAHFLYR
Fri Jan 04, 2013 7:45 pm
Quoting vikkyvik (Reply 8):
As CALTECH said and the video shows they are very very bright and easy to see even in the daylight. I like the look.
futureualpilot
Fri Jan 04, 2013 8:00 pm
From my own experience in my short time operating in and out of the same airports as the 787 and 747-8, the LEDs are significantly easier to acquire and keep track of versus the older and faster flashing strobes. This has made a difference mostly at night, against a city back drop or at a busy airport in a sea of lights.
Life is better when you surf.
KC135Hydraulics
Fri Jan 04, 2013 8:15 pm
Our C-17s have new LED beacon lights. They don't flash, they just glow bright red when they cycle on. You can see them for MILES (farther than a flashing light bulb) and they are super high intensity without the epileptic flashing effect. LED lights are the future of aviation and they're awesome.
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
tjwgrr
Fri Jan 04, 2013 9:56 pm
There are quite a few corporate a/c and some light singles which have been equipped with LED's for quite some time as well.
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
TWA772LR
Fri Jan 04, 2013 10:10 pm
Those LED's are bright as H*ll!!! You can always tell a 787 at night when it's on approach to IAH. Is it just me or do the new white LED's kind of look purple, even in the slightest?
And for my next miracle, I'm gonna turn water into funk!
tdscanuck
Fri Jan 04, 2013 10:11 pm
Quoting TWA772LR (Reply 15):
I think their "white" is a lot hotter (blue/violet-er) than the previous strobes. I agree with you.
Tom.
bond007
Fri Jan 04, 2013 10:55 pm
Quoting tdscanuck (Reply 9):
I think it's likely because the "on" time is much longer than a strobe. Even though it's flashing at the same frequency, most of the time spent between flashes for a strobe is time spent getting bright, and dimming again. The LED is simply on and off, with no in between, hence in theory at least, a longer "on" time.
...maybe
Jimbo
CALTECH
Sun Jan 06, 2013 3:57 pm
At IAH what I noticed about the 787 white lights is that they did have a bluish tinge to them. They do seem more blue than white for the position, tail , 'strobes' and landing lights . All the so called white lights do have that bluish tinge to them, as in the nose gear taxi light in this photo.
Photo © Andrew Compolo
sccutler
Tue Jan 08, 2013 5:03 am
As a pilot, I find the LED "strobes" to be very much easier to spot in flight, and they generally consume less power, weigh less and create much less electrical "noise." there is no discernible down-side, to the point that I intend to replace all of the strobes and Nav lights on my plane with LEDs.
...three miles from BRONS, clear for the ILS one five approach...
FlyDeltaJets
Tue Jan 08, 2013 10:46 am
Quoting pilotpip (Reply 7):
ASA has them too
As mentioned above they are much brighter than traditional strobes.
The only valid opinions are those based in facts
AirframeAS
Tue Jan 08, 2013 5:49 pm
I wouldnt say that.... I would say that todays strobes flash, like a camera flash. The LED on the 787's blink.
bikerthai
Tue Jan 08, 2013 8:08 pm
We cyclist have been the beneficiary of those LED's for years.
Starting with those flashing red LED and then the White LED's.
The blue hue you get with the "Cool White" LED is from the luminescence coating on the bulb that generate the light.
Most color LED is generated by the frequency of the emitting diode. The exception is white.
Because white require the complete spectrum, it is generated by shining a high power colored LED onto a luminescence coating on the bulb. The emission from the coating is what gives you the "white". And depending on the composition of the coating, you get varying hue of white.
As for applications of these LED's . . . it depends on the designers. Some LED car tail lights that are extremely bright and irritating and others warm and pleasing . . . depending on hue and intensity.
bt
Aesma
Wed Jan 09, 2013 4:21 am
Quoting bikerthai (Reply 22):
I don't know if "LED bulbs" are made like this, but when you don't need something looking like a bulb you don't bother, so white LED mostly look like this :
There is indeed some phosphorus in them, otherwise they would be blue.
bond007
Wed Jan 09, 2013 12:25 pm
Quoting Aesma (Reply 23):
But that really is 100 small LED 'bulbs' , right?
It just so happens that even the larger high-power LEDs are very small, but still separate glass or plastic 'bulbs' of some description, each with a small lens.
Jimbo
bikerthai
Wed Jan 09, 2013 2:21 pm
From a layman's point, a LED light is actually a diode that looks like small computer chip. The chip has circuitry to control the frequency of the diode to emit specific frequency of light. You can imagine then the reason why LED would have problem with high power . . . the ability to dissipate heat energy from the chip.
That is why they have to do this:
Quoting bond007 (Reply 24):
The lens is necessary to distribute the LED light to a broader angle. Otherwise you'll get a very narrow beam from each chip.
So tailoring LED light shapes (as opposed to an LED "bulb" which is just a lenses) is a matter of ganging a bunch of LED's (with lenses) on a circuit board (more than one board if you have complex light shape) and some heat dissipation mechanism along with an overall package (aerodynamic transparent cover and power interface).
The house hold LED bulb are cheap enough now that you can buy one and see how it works. I just recently bought some at Costco for $5 each to replace some of my compact fluorescence once those burn out.
bt
rwessel
Wed Jan 09, 2013 9:27 pm
To expand on bikerthai's comments, I just put some of these:
hxxp://www.amazon.com/Feit-Electric-BPG161-CL-LED/dp/B0052YVD6O
(note: the forum software kept mangling the link, so you'll have to cut and paste it, and change the "hxxp" to "http")
and some similar "flame tip" style bulbs in some hallway fixtures that are constantly having incandescent burn out and are a pain to change. They look great, BTW.
Anyway, as you can see in the photograph, these have nine LED chips with nothing more than a thin clear plastic coating/diffuser over the chips mounted on a central pyramid. No bulb.
The flames have a more sophisticated lens/diffuser, but the same chips are hidden in the base.
bond007
Wed Jan 09, 2013 11:16 pm
Quoting bikerthai (Reply 25):
Quoting rwessel (Reply 26):
Yes, I understand the technology, which is why I put "bulb" in quotes
Technically, depending on the definition you read, a light bulb can only be of the incandescent type.
Jimbo
timz
Thu Jan 10, 2013 1:03 am
Quoting FlyDeltaJets (Reply 20):
[LEDs] are much brighter than traditional strobes.
They look brighter-- but presumably the strobe's intensity during its flash is vastly greater than the LED's?
Or are aircraft strobes that much weaker than camera strobes?
Thu Jan 10, 2013 6:56 am
As Long as the New lights are effective on the type.....it serves the purpose & does not violate regulations.
