1337Delta764
FA Cockpit Call Lights-Boeing Pink And Airbus Red?
Sun Jan 06, 2013 11:43 pm
I recently had a roundtrip vacation on US to Puerto Rico, and noticed a striking difference between the colors of the FA cockpit call lights on Boeing vs. Airbus aircraft. On Boeing aircraft (the 757 in my case), the FA cockpit call lights were pink, while on the Airbus aircraft (A321 and A330 in my case) they were red. What is the particular reason for this difference? I thought pink was supposed to be the standard color for FA cockpit call lights. The 717 I heard has a red light that indicates the lavatory smoke detector went off.
Fabo
RE: FA Cockpit Call Lights-Boeing Pink And Airbus Red?
Thu Jan 10, 2013 6:31 pm
Maybe they were "worn-out" pink, i.e. that kind of pink, that used to be red all those years ago?
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
1337Delta764
Thu Jan 10, 2013 6:43 pm
Quoting Fabo (Reply 1):
No, looking at numerous online sources, pink is the standard color to indicate an FA call from the cockpit. I think only Airbus uses red.
JBirdAV8r
Thu Jan 10, 2013 8:56 pm
On the CRJ, I believe they're green. Our FA call button in the flight deck is green.
unattendedbag
Thu Jan 10, 2013 9:55 pm
Quoting 1337Delta764 (Thread starter):
I think you answered your own question. Boeing uses pink and Airbus uses red. The difference is the aircraft manufacturer.
Slower traffic, keep right
1337Delta764
Thu Jan 10, 2013 10:00 pm
Quoting JBirdAV8r (Reply 3):
Typically, a green light I think indicates an FA to FA call. Blue typically indicates a passenger call from a seat. Yellow/amber typically indicates a passenger call from the lavatory, and if flashing, it indicates a smoke detector went off in the one of the lavs (except on the 717 where it is indicated by a separate red light).
Quoting unattendedbag (Reply 4):
McDonnell Douglas used pink as far as I know as well. Why is Airbus different?
[Edited 2013-01-10 14:01:21]
JBirdAV8r
Thu Jan 10, 2013 11:02 pm
Quoting 1337Delta764 (Reply 5):
Okay, I guess I misinterpreted your question. The light on the interphone is green. The flight deck call indicator that's mid-cabin on the emergency exit sign is red.
PGNCS
Fri Jan 11, 2013 1:45 am
Maybe because it isn't regulated and each manufacturer has different ideas?
bwaflyer
Fri Jan 11, 2013 10:46 pm
on BA A32x aircraft a cabin crew to cabin crew call is green, a flight crew to cabin crew call is red, pax call is bell is blue and a toilet call bell is yellow
TupolevTu154
Sat Jan 12, 2013 3:33 pm
Quoting bwaflyer (Reply 8):
Interesting, EZY airbus' only have three colours. Red is interphone call (from other cabin crew or flight deck), blue is passenger call bell, and yellow is toilet call bell. If the lav smoke alarm activates, the yellow light flashes and there's a low chime.
Sat Jan 12, 2013 6:34 pm
I don't think regulations cover the colour code of the lights, hence each manufacturer determines their choices.
bwaflyer
Sun Jan 13, 2013 9:22 pm
Quoting TupolevTu154 (Reply 9):
Which is the same as the bmi aircraft amd confuses some of the BA crew who think the captain is calling when it's just the back galley!
eoinnz
Mon Jan 28, 2013 11:35 am
At QF all our aircraft both Boeing and Airbus have a pink light regardless of who is making the call (it flashes for an emergency call).
roseflyer
Mon Jan 28, 2013 5:20 pm
Quoting HAWK21M (Reply 10):
As far as I know, the only FARs (Federal Air Regulations) concerning colors of enunciation are about warning and indication in the flight deck. Lights used in the cabin are up to the manufacturer to choose.
edina
Wed Jan 30, 2013 3:26 pm
Quoting bwaflyer (Reply 11):
How quickly some of the existing BA crew forgot about the G-BUSx series!! They've not been gone long, and they had red lights for all crew calls  )
Worked on - Caravelle Mercure A300 A320 F27 SD3-60 BAe146 747-100/200/400 DC10-30 767 777 737-400 757 A319 A321
Users browsing this forum: Gr8Circle, Murf and 1 guest
