flyenthu
Ultra Long Haul Crew Shifts
Mon Jan 07, 2013 3:50 am
Hi,
Do ultra long haul flights have two sets of pilot crew because of the long duration flights? Last year while flying from IAH to DXB in business, I remember that we were attended by two different sets of cabin crew. One set worked the first and last leg of the flight. The second set worked the middle part- pretty much the transatlantic and Europe part. I was wondering if the pilot crew also rotated in the same flight?
Thank you!
TK787
RE: Ultra Long Haul Crew Shifts
Mon Jan 07, 2013 4:03 am
Yes.
TK, like most other carriers have 3 pilots on most long haul flights, like IST-JFK B777. 2 ON while one resting.
For longer flights more pilots on board. TK uses 4 pilots for IST-LAX B777 flights. Two ON, two Resting.
TWA772LR
Mon Jan 07, 2013 4:12 am
Quoting TK787 (Reply 1):
Then wouldn't one pilot go over their limit of hours?
"It's not getting to the land of the nonrev that's the problem, it's getting back." ~~Captain Hector Barbossa
wilco737
Mon Jan 07, 2013 4:13 am
Quoting flyenthu (Thread starter):
We at LH do not have any flight where we have 4 pilots on board. Our longest flight is FRA-EZE: 3 pilots. 1 resting, 2 on duty up front.
The cabin crew is resting as well. The first service is done, then one part is going to bed, the other is on duty and then they swap and the 2nd service is done by the whole crew again.
wilco737
UA787DEN
Mon Jan 07, 2013 4:20 am
3-man rotation is often as follows
Person A works the first 2/3 of the flight
Person B works the first and last 3rd (senior captain often does this)
Person C works the last 2/3 of the flight.
There are only ever 2 people at once, and everyone works similar hours
I have occasionally seen, often for 3-man training flights or flights workable by 2 people:
Captain runs the entire flight, and the FO switches halfway or every quarter.
The FAA has rules about going over the 8 hour limit. It is allowed, but only by flying one long haul flight, and the pilot must have extra rest after. An airline cannot have a pilot run 10 hours of A320 short haul. Someone else.may elaborate if they choose.
TWA772LR
Mon Jan 07, 2013 7:08 am
Quoting UA787DEN (Reply 4):
That makes sense. Thanks for clarifying.
Mon Jan 07, 2013 8:28 am
The shifts also depends on whether there are cruise pilots or not. Those will typically only be in the seat above 24000 feet or some such. Not all airlines have cruise pilots though. So you might have one Captain, one F/O and one S/O (second officer), with the Captain and F/O handling the first and last bits together, and both being spelled by the S/O in cruise while they rest in sequence. With four crew you could have one Captain, two F/Os and one S/O but the same sort of principles apply. The S/O will only be in the seat over a certain altitude.
Rest days can be predicated on length of duty AND number of time zones crossed. The more of either, the longer the subsequent rest.
sciurusmdg
Mon Jan 07, 2013 11:34 pm
I have a question about NetJets/ similar outfits- on a lot of their LR jets (Gulfstream 550 etc) there are 2 crew and (to my knowledge, apart from new Globals) no crew rest. However these planes are quite capable of going further than LHR-GRU or similar... what happens on board for these flights?
FlyboyOz
Mon Jan 07, 2013 11:49 pm
Quoting Starlionblue (Reply 6):
Yes... that's right...that's what I have heard from the pilots.
[Edited 2013-01-07 15:53:28]
The Spirit of AustraliAN - Longreach
roseflyer
Tue Jan 08, 2013 12:02 am
You might have been served by different crew members, but I don’t know of any airline that has multiple sets of cabin crew on a flight. Usually everyone works for the first meal which is the main production. Then they stagger their breaks. Depending on what the second meal is, all the crew may be working for it or it may be a partial crew if it is just a light snack. The majority of work for the cabin crew is the meal service. After the meal service, half - two/thirds can be on break since there is little work in cruise.
As for pilot crew. SQ has 5 crew on their ultra long haul flights that rotate since above 16 hours can require 5 pilots. 2 captains and 3 first officers (I think). Some airlines will operate ultra long haul with 2 captains and 2 first officers or 1 captain and 3 first officers.
Tue Jan 08, 2013 12:23 am
Quoting sciurusmdg (Reply 7):
Autopilot flies while the crew sleeps.   Jokes aside, there may be no need for a designated crew rest. A nice reclinable seat works.
AR385
Tue Jan 08, 2013 12:30 am
Quoting wilco737 (Reply 3):
You are right, of course,but back in 2010 when I took that flight, in November, there were 4 cockpit crew. Maybe training? And what type of training would it be?
Tue Jan 08, 2013 12:35 am
Quoting AR385 (Reply 11):
Training would be either a new captain or F/O getting checked out, or a recurrent check. Quite a large number of flights are actually training flights. Much more efficient do this kind of training while carrying passengers than in the sim or an empty plane.
Could have been an extra pilot deadheading also maybe?
wilco737
Tue Jan 08, 2013 3:10 am
Quoting Starlionblue (Reply 12):
Back then it was flown by 4 pilots. Same to SIN, but the conditions canged and the contract were renegotiated which made it possible to fly it with 3 pilots. The EZE flight is very close to the max duty time for 3 pilots. So 20 minutes delay and you have to call a standby crew.
That's the reason the 744 is still flying to EZE, the 340 would need longer on that flight and you would need a 4th pilot. No A vs B war here, but it is fact that the 340 flies slower and on such a long flight it makes a difference between 3 and 4 pilots.
And deadheading crew is always sitting in the cabin. Our contract doesn't allow crews to fly on the jumpseats. So they need to have a seat.
wilco737
[Edited 2013-01-07 19:11:56]
AR385
Tue Jan 08, 2013 3:35 am
Quoting wilco737 (Reply 13):
Interesting. We were delayed by about 35 mins. from departure time. The FA told me it was due to being overweight and having to offload cargo. F was full, there was 1 empty seat on C and Y had 6 empty seats. The 744 was D-ABVB. It was a fantastic flight.
UA787DEN
Tue Jan 08, 2013 4:13 am
Quoting FlyboyOz (Reply 8):
Yep. I was going to elaborate on it later. It really depends on the airline for normal ops, and the pilots make the final call. If crew members are all different ranks (a la CX) a cruise pilot will normally be used.
If a crew is similar ranking or seniority, and on some airlines, it is a simple rotation. The captain will fly TO and landing generally. The FOs will generally each handle a TO and landing. Often times, an FO will still end up doing most of the autopilot babysitting. It won't be split between the two.
Same thing for 4 pilots (also used some by CX and others)
Some airlines will have a Captain/FO pair running TO and landing, with a SO cruise crew. Others will have two film crews, switching at regular intervals.
These days, a cruise pilot crew often costs less and is used more.
wilco737
Tue Jan 08, 2013 4:17 am
Quoting AR385 (Reply 14):
Yes, that can happen and then there can be made a duty time extention. It cannot be done by the company, only by the captain. And then you can have a duty time of 21 hours.
wilco737
FlyboyOz
Tue Jan 08, 2013 8:10 am
Quoting UA787DEN (Reply 15):
True... I told him (a cruise pilot) that he is lucky that he doesnt have to worry about lots of work to do for take off and landing. lol
Really... I didn't know that.
Wilco... LH doesn't have cruise pilots? Does it mean that pilots - (first and second officers) are allowed to do take off and landing?
wilco737
Tue Jan 08, 2013 8:13 am
Quoting FlyboyOz (Reply 17):
We don't have 2nd officers. We have First officer and senior first officer. The Senior First officer takes the left seat during cruise when the captain is on his rest. But all FO's and SFO's are allowed to take off and land.
We have a couple CRC's left, they are not allowed to take off and land.
Actually, we do have 2nd officer, but those are the guys just getting from the flight school. During their line training they are called 2nd officers but visually cannot be identified (look the same like FO). After their final check on the line they become First Offciers.
wilco737
Tue Jan 08, 2013 9:56 am
Quoting wilco737 (Reply 18):
AFAIK CX second officers are type rated and qualified to land the aircraft. They stay current in the sim.
Mr AirNZ
Tue Jan 08, 2013 10:10 pm
Quoting Starlionblue (Reply 19):
S/O's at Cathay do not receive a full type rating.
FlyboyOz
Tue Jan 08, 2013 10:34 pm
CRC
What does CRC stand for?
Thanks for explanation. It's so interesting to talk about it.
Tue Jan 08, 2013 11:36 pm
Quoting Mr AirNZ (Reply 20):
Ah thx. And so what do they get?
Mr AirNZ
Wed Jan 09, 2013 7:22 am
Quoting Starlionblue (Reply 22):
A P2X rating from the HKCAD that allows them to act as a relief pilot.
wilco737
Wed Jan 09, 2013 8:35 am
Quoting FlyboyOz (Reply 21):
Something like Crew Relief Crew. Usually we call them Crew relief pilot.
At LH Cargo we still have a couple. I haven't seen one on the 744/ 748 yet. But I heard there are 1 or 2 left.
wilco737
flyingturtle
Wed Jan 09, 2013 9:36 am
Quoting wilco737 (Reply 24):
How I love the word "CRC". Crew relief crew. In signal transmission, CRC means "cyclic redundancy check".
Do the CRC pilots have less strict training or medical standards? Some of the old flight engineers turned into cruise pilots, but would it be possible to be a CRC pilot from the beginning?
David
FlyboyOz
Wed Jan 09, 2013 10:38 pm
Quoting flyingturtle (Reply 25):
Good question... I am curious about it too!!
wilco737
Thu Jan 10, 2013 6:25 am
They have different training as they do not need to land the airplane. but they get training on the airplane, they are able to fly it, operate the autopilot and handle abnormal situations.
CRC from the beginning? I doubt it to be honest. But I am not sure.
wilco737
flyenthu
Thu Jan 10, 2013 11:32 am
After EK 211 took off and leveled, I saw, who I believe was the captain, wearing an informal crew t-shirt and headed to their resting area at the back of the plane. He had also announced there was a secondary crew as well. My flight took over 16 hrs and having 2 crew sets made sense.
flyenthu
Thu Jan 10, 2013 4:35 pm
My flight actually took almost 17 hours- 16 hrs and 49 min.
bhill
Thu Jan 10, 2013 7:17 pm
Curious, so how is "rest" time actually, legally, calculated? Time away from the flight deck with no flying "responsibilities," or just reclining in place with no "hands on the stick or buttons?"
Carpe Pices
Fabo
Thu Jan 10, 2013 8:50 pm
Cruise Relief Crew?
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
Thu Jan 10, 2013 11:47 pm
Quoting flyenthu (Reply 29):
With the crew briefing and pre-flighting you're adding another couple of hours, so the "flight" for them is closer to 19-20 hours.
wilco737
Fri Jan 11, 2013 5:57 am
Quoting Fabo (Reply 31):
Haha, yes of course. Crew relief crew doesn't make any sense. Thanks.
wilco737
kpc777
Fri Jan 11, 2013 9:14 pm
Quoting Roseflyer (Reply 9):
Thanks for that information! I've always been curious about SQ's EWR-SIN flight and how it was crewed. I was always hesitant to start another thread.
Do you know if the aircraft has a crew rest area or do the pilots take one of the business class seats?
Fabo
Mon Jan 14, 2013 1:02 am
Most planes sized maybe A330 up have proper rest areas, at least as an option. Of course any airline is not required to have such option, but if you need a rest area, it makes sense to put it somewhere else than seats you could sell.
flyingturtle
Mon Jan 14, 2013 10:24 am
Quoting Fabo (Reply 35):
http://i277.photobucket.com/albums/kk76/batcave777/Crewrestmodule.jpg - crew rest box in the plane's belly.
Seats are not really a consideration IMHO because you couldn't do ULH flights without a proper crew rest area. The crown area of an aircraft is seldum used for anything (at least on the widebodies), and so many A/C have the crew rest there:
http://www.boeing.com/companyoffices...s/commercial/crewrest_location.jpg
David
Fabo
Mon Jan 14, 2013 1:11 pm
Quoting flyingturtle (Reply 36):
I suppose you could block a premium cabin to be designated crew rest area, if you absolutely needed to operate an ULH flight with aircraft not equipped with proper crew rest. But this is just unimportant academics anyway.
northwestEWR
Re: RE: Ultra Long Haul Crew Shifts
Thu Sep 01, 2016 1:09 pm
Fabo wrote:
Quoting flyingturtle (Reply 36):you couldn't do ULH flights without a proper crew rest area
Delta does this on some 767-300ERs that don't have the dedicated crew rest facilities. They block 7A in Business and that seat is equipped with a floor to ceiling curtain that gives the crew some privacy and quiet/darkness.
Delta operates two ULH flights per their pilot contract and those are LAX-SYD and ATL-JNB. They come with special duty time restrictions and rest requirements before and after those trips.
Other flights operate with 2 full crews but without the ULH restrictions and requirements. DTW-Asia, etc.
Northwest Airlines - Now You're Flying Smart
BravoOne
Re: Ultra Long Haul Crew Shifts
Thu Sep 01, 2016 2:42 pm
While there are formal regulatory guidelines regarding ULH operations there can be significant union applied rules as well. Most operators/pilot groups have established union sub committees to oversee these type of flights. I would venture to guess that there are at least a half dozen or more flight deck crew combos, some using all rated F/O and no cruise pilots. Others with 2 Captains and 2 F.O's. The list is endless. Regardless there is only one individual that signs the paperwork, with a few exceptions.
Regarding corporate operators, most G650/Global aircraft have a dedicated crew rest area. Not much compared to a 777 or A350 but a place that has a reclining seat and the ability close off the light. No crew, rest be it a 747 or G550, is going to give great comfort and deep sleep.
tmu101
Fri Sep 23, 2016 4:35 am
Regarding a SO for those airlines that employ them - on the cruise portions of flight should an emergency arise requiring an immediate landing i assume the captain and FO resume control and land? Or would/could the SO remain at the controls working the radio, performing checklists, troubleshooting the issue at hand, etc?
Very interesting topic btw!
Fri Sep 23, 2016 5:30 am
The Captain and FO would get in the seats. At my airline SOs are trained to perform approaches and landings and stay current on this in the sim. It is a rating requirement. SOs also practice single pilot approaches and landings due to pilot incapacitation. Systems and airport equipment permitting, an autoland would be performed in a single pilot situation.
Depending on the emergency, a captain might choose to have the SO sit in the seat for a bit longer while he concentrates on the big picture. It really depends on the situation and on the captain.
Fri Sep 23, 2016 8:08 pm
FYI
ULH is > 16 hrs flight time
LH is > 10 hrs flight time
Aircellist
Sat Sep 24, 2016 3:43 am
zeke wrote:
FYI
… So I've never flown LH…
"When I find out I was wrong, I change my mind. What do you do?" -attributed to John Maynard Keynes
tmu101
Mon Sep 26, 2016 4:01 am
Very interesting thank you.
BravoOne
Mon Sep 26, 2016 9:20 am
Please note that what tmu101 has written is not the industry standard here in the US, at least. A fully augmented crew of four pilots typically will include at a minimum, 3 fully rated and airplane landing current F/O's, none of which are "cruise pilots" along with a Captain or in some cases depending on the working agreement, 2 F/O's and 2 Captains one of which would be designated the Aircraft Commander. Fully qualified for all eventualities, at all times. Not arguing the merits of this, but that is the way it works.
Between 8 and 12 hours scheduled times require 3 fully qualified pilots. 2 F/O's and one Captain and again there are no cruise pilots or S/O's.
Aircraft landing currency took on a new meaning after UAL just about hit the hills west of SFO on one late night departure in a SYD bound 747 departing 28R.. You can probably Google this incident to learn more about the actual event and follow up investigation and recommendations that followed.
Mon Sep 26, 2016 10:45 am
Aircraft landing currency took on a new meaning after UAL just about hit the hills west of SFO on one late night departure in a SYD bound 747 departing for SFO. You can probably Google this incident to learn more about the actual event and follow up investigation and recommendations that followed.
As you say it is a regional thing and depends on the jurisdiction. Pure cruise pilots with limited ratings are a way for the airlines to save money, which is why you see them in some jurisdictions. It also locks new pilots into their contracts since they can't just take their type rating somewhere else. The type of operation is significant. Unless a large part of the flying is 8+ hours, there's no need for cruise pilots.
On a side note, there's the matter of nomenclature. I know of at least one airline with second officers in a window seat, meaning they have full ratings.
At my airline a 4-man crew is 1 captain, 2 FOs and 1 SO. 3-man crews are 1 captain, 1 FO and 1 SO. The FOs flying with SOs must be relief command qualified. Having said that, on the day anything can happen because planning is never perfect and people call in sick or are stranded downroute at the last minute. We have flights leaving with 2 captains and 1 SO, 1 captain and 3 FOs or whatnot. The only certain thing is that there will be a captain on board. In cases with 2 captains, one is designated as the commander.
Mon Sep 26, 2016 12:20 pm
Not exactly true, some 3 crew flights only require RP (Hkg-mel), some RQ (Hkg-akl), some require 2xFOs (eg Hkg-lhr)
We have also have had 4 crew flights with 4 captains, and the biggest issue the FP had was who gets what color cup.
Mon Sep 26, 2016 12:34 pm
Proving that every time I think I have a faint grip on flight crew licensing, obviously there is much more to learn.
That cup colour may well be the biggest CRM issue in the cockpit. :lol:
Users browsing this forum: akiss20 and 2 guests
