dhawald3
Gyroscopic Effect Of Turbo Fan Engines
Mon Jan 07, 2013 7:10 am
Hi there!
the gyroscopic effect due to the rotating mass affects engines, it is more pronounced in turbo prop engines due to a larger fan.
Even though it is less in turbofan engines is there anything done to counteract it in modern turbofan engines?
rwessel
RE: Gyroscopic Effect Of Turbo Fan Engines
Mon Jan 07, 2013 9:36 am
Not really. Compared to the mass of the aircraft, the effect is pretty small, particularly since much of the rotating mass is in the relatively small diameter section of the engine. Some engines do have counter-rotating shafts, and that will obviously reduce the effect, but it's not a prime consideration.
Mon Jan 07, 2013 10:16 am
Quoting rwessel (Reply 1):
Counter rotating shafts mitigate torque, not gyroscopic effects (rigidity in space and precession). Though I guess you get precession in opposite directions when the engines changes direction.
[Edited 2013-01-07 02:17:28]
[Edited 2013-01-07 02:18:17]
Jetlagged
Mon Jan 07, 2013 4:27 pm
For a V/STOL aircraft like the Harrier gyroscopic precession is important as it adversely affects hovering stability. That's why the Pegasus engine has counter-rotating shafts. Counter rotating shafts in engines like the RR Trent are more for aerodynamic reasons than to reduce precession torque. Airliners don't usually pitch or yaw at high rates so any precession torque will be relatively low, but it is taken into account when stressing the engine mountings. It's more likely to be significant in a military fighter as a rapid pitch up will create a yawing moment.
Users browsing this forum: 767333ER, badgervor, bradmovie, psimpson, SAAFNAV and 1 guest
