mke717spotter
AA MD-80 No Thrust Reverse?
Tue Jan 08, 2013 10:22 pm
Since May 2011 I've been on six AA MD-80 flights (including ORD-DFW-TUS yesterday) and every time during landing it seemed like there was no thrust reverse. It was completely silent. since it sounded like the may have been minimally kicked it, but it paled in comparison to my recent DL MD-80 flight. Does AA have some sort of fuel-saving policy where they're not MD-80 pilots aren't supposed to use thrust reverse? I could've sworn I remember something like this about AE and the ERJs.
RE: AA MD-80 No Thrust Reverse?
Tue Jan 08, 2013 11:33 pm
Maybe they only used idle reverse. Makes way less noise and wears on the engines less. Don't think the fuel savings are that great. And if you have to roll down the runway a ways you might as well coast.
If memory serves reversers are optional on the ERJ.
bond007
Wed Jan 09, 2013 1:42 am
Quoting Starlionblue (Reply 1):
Most likely the correct answer.
On a dry runway, there is a negligible reduction in stopping distance when using anything but idle reverse.
Jimbo
mke717spotter
Wed Jan 09, 2013 3:03 am
What exactly is idle reverse?
bond007
Wed Jan 09, 2013 3:12 am
Quoting mke717spotter (Reply 3):
The thrust reversers are activated, but engine is left at idle. This has the effect of eliminating the residual thrust from the idle engines - the engines will always be providing a small amount of forward thrust at idle otherwise, so the effect is to kill all forward thrust.
It is also very quiet
edited: Presumably, depending on the type of thrust reversers, there is also a small drag component added.
Jimbo
[Edited 2013-01-08 19:15:02]
prebennorholm
Wed Jan 09, 2013 3:18 am
Quoting mke717spotter (Thread starter):
In Europe this has been common practice during the last 20-25 years. In many airports use of reversers is prohibited in order to reduce noise (except in case of emergencies of course).
Reversers are engaged, and often the engines are spooled up to slightly above idle. That doesn't actually perform any meaningful brake action, but it reduces spool up time significantly in case of failure on the wheel brakes.
In many cases I think that the wear of the brakes is more costly than the fuel saving on not using the reversers. At least I have noticed that SK sometimes use reversers on remote combined military airfields, where noise doesn't really matter, even when the runway is twice as long as needed for landing the MD-80. But when reversers are banned, they have no choice.
vikkyvik
Wed Jan 09, 2013 3:59 am
Quoting bond007 (Reply 2):
Is that what you meant to say? Makes it sound like idle reverse has a more-than-negligible reduction in stopping distance.
Quoting bond007 (Reply 4):
Just a note - this might be true on airplanes with clamshell-style reversers (which I think the MD-80 has) that reverse the bypass and core flow, but on most modern turbofans, the reversers only affect the bypass flow. So there is still some forward thrust, even if it's a small percentage of the overall thrust on high-bypass engines.
Quoting prebennorholm (Reply 5):
Isn't part of the reasoning that it's better to use newer carbon brakes more, as they're more efficient heated up? Not an expert in that myself.
longhauler
Wed Jan 09, 2013 4:59 am
Not if the airline leases the brakes on a "per landing" basis. Then the pilots are encouraged, where safe, to use idle reverse and moderate wheel braking.
Airlines leasing brakes, are a lot more common than one would imagine.
freeze3192
Wed Jan 09, 2013 7:57 am
IIRC the policy at Eagle is that reversers are only to be used on runways less than 7000 ft, when the runway is contaminated or if the PIC deems it necessary.
At ExpressJet, on the ERJ fleet their policy is different. Reversers almost all the time.
"A passenger bets his life that his pilot is a worthy heir to an ancient tradition of excellence and professionalism."
tdscanuck
Wed Jan 09, 2013 8:04 am
Quoting vikkyvik (Reply 6):
Steel brakes wear in proportion to the amount of energy absorbed. Carbon brakes wear in proportion to the number of applications, and they have better performance when they're warm. As a result, carbon brakes don't really care if you brake hard or soft so you might as well brake hard to warm them up. Your brake wear is no worse and you reduce engine/reverser wear.
Tom.
KC135Hydraulics
Wed Jan 09, 2013 9:32 am
We have carbon brakes on the KC-135 and they are excellent. The aircraft has no thrust reverses. Brakes can stay on the aircraft for several years depending on aircraft utilization. They are changed more for cracked heat shields rather than wear from what I have seen working in the back shop.
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
bond007
Wed Jan 09, 2013 12:20 pm
It is what I meant to say, but not what I meant it to sound like
What I meant, is that on a dry, uncontaminated runway, the reduction in stopping distance using reverse thrust for most airliners, is a few hundred feet ....even on full reverse thrust!
On contaminated runways it is significant, but there are few advantages to using full reverse thrust on a dry runway.
Jimbo
MesaFlyGuy
Thu Jan 10, 2013 6:47 am
Quoting freeze3192 (Reply 8):
So they don't use them at LGA? I thought I saw one or two ERJs (both 145s) use reverse thrusters when they landed a few weeks ago, but I could be wrong.
The views I express are my own and do not reflect the views and opinions of my company.
Thu Jan 10, 2013 6:50 am
Quoting mesaflyguy (Reply 12):
LGA has 7000 foot runways so there should be no need. Company SOP dictates.
BTW "reverse thrusters" are for the Starship Enterprise. "Thrust reversers" are for airliners".
MesaFlyGuy
Thu Jan 10, 2013 7:04 am
Quoting Starlionblue (Reply 13):
Really? Wow I've been saying it wrong for a long time! I've said Reverse Thrusters since the day I got into Aviation.
Either way, thanks for the information. The plane went by quick so I didn't get an excellent view of the THRUST REVERSERS.
Thu Jan 10, 2013 10:39 am
Quoting mesaflyguy (Reply 14):
Hehe.
You have to look at the what is a noun and what is an adjective. "Reverse thrusters" are "thruster" gizmos that thrust in a reverse direction, like on the Starship Enterprise or the Space Shuttle. "Thrust reverser" is a "reverser" gizmo that reverses the thrust of another gizmo.
[Edited 2013-01-10 02:43:05]
MesaFlyGuy
Thu Jan 10, 2013 1:28 pm
Now I see that. Thrist Reverser makes a lot more sense.
Thu Jan 10, 2013 2:51 pm
Quoting mesaflyguy (Reply 16):
Yeah but let's face it. Reverse thrusters are cooler.
vikkyvik
Thu Jan 10, 2013 4:53 pm
I'd wager that they still open the reversers, but just leave them at idle thrust. It's a good idea, just in case you need to stop quickly.
But I don't know their procedures.
Max Q
Thu Jan 10, 2013 5:28 pm
I can't think of a single airport in Europe that 'prohibits' reverse.
They may request the minimal use of and / or idle reverse unless necessary.
But there is no prohibition I know of.
It makes a lot more noise to run off a wet / contaminated runway because you don't use it !
RussianJet
Thu Jan 10, 2013 6:32 pm
Quoting Starlionblue (Reply 17):
Thanks for making an otherwise very dry discussion really quite funny, guys!
✈ Every strike of the hammer is a blow against the enemy. ✈
737tdi
Thu Jan 10, 2013 8:12 pm
Very curious?? I fly almost weekly on my companies aircraft, alot of it in the cockpit and I can't ever remember the driver NOT using full reverse thrust. Even on long runways they use the reversers at power.
prebennorholm
Fri Jan 11, 2013 3:23 am
Quoting Max Q (Reply 19):
I would assume that "prohibit" and "request minimal use" is the same thing in ordinary life.
Fact is that I read in a local aviation magazine some 20-25 years ago that now was the end of reverser use at CPH, like it had already been ruled at several other major airports. The NYMBYs had fought a long war and won the battle. And since that day the wonderful roar of the reverser of the SK DC-9s ended, something which I at that time enjoyed very frequently, often from the rear end of the cabin.
And I have since noticed zero use of more than slightly above idle reverse at CPH during a few hundred landings with well over a dozen airline companies. And very little use elsewhere around Europe.
On the other hand I have noticed the same airlines use reversers constantly at places like KRP and KEF, and never at CPH. KRP and KEF have fully as long runways, but they are places out in the wilderness where nobody cared about noise. And BTW, if they noticed any noise, then it was more likely the afterburners of F-15 and F-16 fighters taking off. Or in the old days, even worse, SAAB Drakens or F-104 Starfighters taking off.
You must have very good eyes. Because the only way to see it is looking at the trust levers in the cockpit.
It's much easier to use the ears.
highflyer9790
Fri Jan 11, 2013 6:42 pm
i use reverse thrust on every landing i perform. rarely, rarely do i use total idle reverse. i spool them up each time. no matter what, IF you had a brake failure right then and there, having the reversers already spooled and at max reverse will help more than if they were stowed. end of story.
To all those people that dont like me using reverse because they live in a noise sensitive area, too bad. you moved next to the airport, the airport didnt move next to you. Im the one slowing my airliner so it doesnt end up in your back yard, and i will decelerate as i see fit. Unless my FOM tells me otherwise, those reversers are always popped for me!
It is standard procedure at my airline per our landing profile regardless of type aircraft to deploy the reversers. from our FOM:
"The thrust reversers are intended for use during full stop landings."
"Reverse thrust reduces the airplane’s stopping distance compared to using brakes alone. Reverse thrust is most effective at high speeds."
highflyer
[Edited 2013-01-11 10:55:31]
121
MesaFlyGuy
Fri Jan 11, 2013 8:01 pm
Quoting RussianJet (Reply 20):
LOL We're happy to assist!
Quoting prebennorholm (Reply 22):
Don't the E-145s have visible thrust reversers? I thought they had the mini clamshell-like ones.
(BTW, I used Thrust Reversers right this time! )
[Edited 2013-01-11 12:03:24]
[Edited 2013-01-11 12:04:10]
Max Q
Sat Jan 12, 2013 2:07 am
No, not at all, in fact that makes no sense.
I have been into CPH a few times and certainly used more than idle reverse.
Quoting highflyer9790 (Reply 23):
highflyer
Well said.
tdscanuck
Sat Jan 12, 2013 5:23 am
Quoting bond007 (Reply 11):
Keep in mind that, on many large aircraft, autobrakes control on deceleration. As a result, they'll give almost exactly the same stopping distance whether reverse thrust is used or not because the airplane will just modulate the brakes to "take up the slack" from what the reversers aren't doing. As long as the brakes have excess capability (as they do on a dry uncontaminated runway) there will be no meaningful difference.
If the brakes saturate and the anti-skid starts to operate, as happens with a wet runway, the reversers will significantly improve the stopping distance because they can still provide full power.
Tom.
twincommander
Sat Jan 12, 2013 11:07 am
if they arnt deployed on landing, they are most likely locked out for an MEL.
most of the time at PDX, if its a landing on the long runway, its idle reverse, and maybe a touch of throttle to make the easy turn to the gate, if they are on the shorter runway, they kinda pile the power on.
cornutt
Tue Jan 29, 2013 10:08 pm
At HSV, we've got RJs landing on 10,000+ ft runways, so they don't really even need to decelerate all that much. Particularly when landing on 36L -- the concourse is at the north end of the airport, so you just let it roll out. A touch of brake where you turn off for the ramp, and that's pretty much it.
pilotpip
Fri Feb 01, 2013 2:39 am
Quoting mesaflyguy (Reply 24):
(BTW, I used Thrust Reversers right this time!&nbsp Wink
Not all of them. TSA has a number of former crossair birds that do not have them.
DMI
Users browsing this forum: codc10, CRJ900, kalvado, Scinfaxi, StereoTechque and 23 guests
