jodoloy
Reversers On Taxiway
Sat Jan 12, 2013 8:42 pm
The other day as I was doing my Pre-flight, I noticed an Allegiant MD-80 using its reversers to slow down on the taxiway. I have never noticed this before. Is this something unique, or does it occur everyday?
longhauler
RE: Reversers On Taxiway
Sat Jan 12, 2013 9:31 pm
I used to do it on the B737-200. The idle thrust of the -17 engines was pretty high, it was an effective way to keep the brakes cool.
In fact, when the airplane was light, I used to taxi with one in idle reverse, it kept the speed slow. You have no idea how many times the airplane behind us warned us that we might not know one was in reverse.
goboeing
Sun Jan 13, 2013 4:45 am
On the ERJ-135/145 series, a technique was to not just use the reverse thrust to prevent the brakes from heating up, but to actually cool the brakes. The airflow when the buckets are deployed would conveniently blast down on the brakes and cool them off a little. Saw a captain do this once or twice following a quick turn while the brakes were still hot from the arrival as we taxiied out for departure.
N243NW
Sun Jan 13, 2013 6:05 am
Quoting longhauler (Reply 1):
Gotta love unsolicited "advice" from other pilots. One of our MD-80s rejected takeoff at more than 100 knots the other week when a nearby pilot reported that the plane had a piece of FOD attached to the nose gear.
It was the spray deflector.
Sun Jan 13, 2013 6:52 am
Some Airlines have issued SOPs to their Flight crew to reduce brake usage to save on the brake overhaul frequency.
This is to use the full length of the runway post touchdown & minimum use of brakes.in such cases one might see the T/Rs being used instead.
atct
Sun Jan 13, 2013 7:18 am
In the King Air / MU2 we would use beta frequently while taxiing as at idle she'll scoot pretty quick down the taxiway. My buddy flies Lear 60's and GV's and they frequently taxi with one bucket open at idle thrust. The other engine at idle provides the perfect amount of thrust for a nice, steady taxi.
atct
Trikes are for kids!
Tristarsteve
Sun Jan 13, 2013 4:26 pm
Quoting HAWK21M (Reply 4):
Yes, the airframe guys get onto Flt Ops about brake usage and get the Engines used for slowing down.
A year later the engine guys notice and make a case to Flt Ops to get it reversed.
And so it goes on.
Brakes are cheaper than engines!
m1m2
Sun Jan 13, 2013 6:02 pm
The Dash 8 also likes to taxi way too fast if the props are in flight idle. I use beta while taxiing. The CRJ 100/200 also likes to taxi rather rapidly if one thrust reverser isn't opened.
AA737-823
Sun Jan 13, 2013 10:46 pm
The F-100 aircraft do this frequently as well (and, I assume, F-70s). Those Tays make a good bit of push on the small airframe.
For maintenance on 737-200s, I sometimes do it during taxi, as we're taxying an empty airplane, and it'll build up speed, even on an uphill taxiway. Otherwise, you're forced to apply brakes, release them, apply them, release them, and so on, which is uncomfortable and awkward. The brakes on a -200 aren't very..... linear. They're more like ON or OFF!!!
Quoting Tristarsteve (Reply 6):
But at idle reverse, it's a moot point. Idle is idle.
Quoting atct (Reply 5):
I've noticed that quite a lot, in multiple bizjet types.
glen
Mon Jan 14, 2013 7:20 am
Quoting AA737-823 (Reply 8):
But reverse at low speed increases the risk of FOD.
"The horizon of many people is a circle with zero radius which they call their point of view." - Albert Einstein
tb727
Mon Jan 14, 2013 3:58 pm
Quoting glen (Reply 9):
Which is true. In the Lear 25 we could only pop them on taxi during the first flight of the day for the TR check and we would make it quick. When you did it, even at idle, you would sometimes see dust fly up almost to the nose of the plane if you were looking outside!
The only engine we are allowed to intentionally reverse on the ground is the #2 engine on the 727 because the thrust is diverted to the sides instead of up and down like the pods. A popular thing to do after landing and cool down is to kill #2 (some guys call it OJ'ing it, twisted I know). This is my first winter taxiing the 727 so I prefer to keep #2 running in case I need to pop it if it's icy or I need to slow down so I tend to cage #3 if I am going to shut one down.
When we have a large load of horses on board to keep the cool air flowing from the packs it is also possible to push #1&3 up a little and pop #2 while taxiing on a really hot day. That way we keep the temperature in the cabin under control and we don't drag the brakes while trying not to hit SWA taxi speeds
IAHFLYR
Tue Jan 15, 2013 12:13 am
Quoting N243NW (Reply 3):
   yep gotta love the help....glad it wasn't serious though.
Years back I heard some Gulfstream pilot tell the ground controller when they were asked about a reverser being deployed during taxi , "its deployed to keep the wind from blowing out the fire in the engine" as they motored downwind on the taxiway during the strong north wind. Not sure about that one but guess it could be...............    I'm not sure the controller is right to this day.
AA737-823
Tue Jan 15, 2013 12:22 am
Yeah, but don't tell KLM that, as I've found a photo to back up what I said earlier about it on the Fokkers:
Photo © Tomas Lauer
Quoting IAHFLYR (Reply 11):
Some engines, believe it or not, are actually pretty sensitive to tailwinds. Even the mighty CFM56 has it's limits.
Tue Jan 15, 2013 1:50 pm
And so it goes on.
What transpires if one is Airframe & Engine qualified
On a serious note.... whats the case for Engine damage if RT is used for slowing down.
m1m2
Tue Jan 15, 2013 10:32 pm
Just that it's work that can be done by the brakes rather than adding extra wear to the engines and burning more fuel. I think that's what you are asking about?
Using them at slow speeds has the potential to blow debris into the air in front of the engine which can subsequently be ingested by the engine. We all know what this would do.
longhauler
Tue Jan 15, 2013 11:38 pm
Quoting m1m2 (Reply 14):
Normally when taxiing, nothing more than idle reverse is used. This is used less to slow down, than more to harness the excess thrust. Being at idle, no extra fuel is burned than if the engine remained in forward thrust. Also, brake temperature is often an issue when taxiing out, idle reverse can control that.
Most B737-200s, (and DC-9s) have the reverser buckets rotated out of centre line. This puts the area of thrust ground contact outside of the engine intake, instead of directly under it. While not entirely effective, this does reduce FOD ingestion.
For example:
Photo © Andrés Contador - AirTeamImages
freeze3192
Wed Jan 16, 2013 2:40 am
Popping a reverser during taxi is (or was last time I checked) an approved procedure for the ERJ side of XJT.
"A passenger bets his life that his pilot is a worthy heir to an ancient tradition of excellence and professionalism."
GlobalMoose
Thu Jan 17, 2013 2:39 am
We throw out the TRs all of the time while taxiing. We generally put them out on 2 & 3 to help balance the forward thrust from 1 & 4 when we are at lighter weights. It gets really annoying to have to either ride the brakes (not recommended) or constantly speeding up and slowing down...
Other times, when we are really heavy, I'll use all four in reverse idle to help slow down as required (at 20 kts or so and taxiing along a downslope). A large part of our TOLD is based upon brake temps (two speeds are given on takeoff and landing - one where if we get on the brakes above a given speed, the fuse plugs melt and another, higher speed that is the maximum energy absorption capability of the brakes).
I'll try and keep the brakes under 50 C - it is amazing how much the temps can rise when you are taxing a 500,000 lb aircraft around a large airport!
When it absolutely positively has to be there ... at some point.
AA737-823
Thu Jan 17, 2013 10:40 pm
Quoting GlobalMoose (Reply 17):
We
Who?
While taxying what? I gather a four-engined aircraft... more specifically?
You say 500k.... I've certainly never seen a 747 taxi around with #2 and #3 in reverse, and given the translating cowl-style reverser, those engines are particularly prone to FOD damage while in reverse, so I'm having a hard time with that policy at your company!
Quoting longhauler (Reply 15):
Just to pick at nits (and to provide bemusing anecdotal information), a JT8-D is prone to stall if left at idle in reverse; consequently, when you enter Detent 1 on the reverser handle, the FCU spools the engine up JUST a hair, to provide a little more motivation to get the exhaust out of the tailpipe!
Engines that reverse only the bypass flow are obviously not prone to this issue, as the core can still breathe just fine in reverse.
longhauler
Thu Jan 17, 2013 10:52 pm
Quoting AA737-823 (Reply 18):
I never noticed that! And ... I have over 5000 hours on the B737-200. (as I always say, its a bad day you don't learn something!) Is that all of them? As I noticed that the idle is quite a bit higher on the -15, or -17, over the -9s. So I never taxied with the -9s in reverse, just the -17s.
Yes, but usually those engines have a minimum recommended airspeed for reverse. The airplane I fly now, recommends 70 knots minimum for max reverse, and 50 knots for idle reverse. That being said though, an F/O recently asked why my hand was on the reverse levers as we entered the gate area, "you just never know" I replied, "you never know"!
GlobalMoose
Fri Jan 18, 2013 4:43 am
C-17A.
Yikes!
Tue Jan 22, 2013 3:36 am
I have been away from this forum for a number of years.
I used idle reverse on the 763 while taxiing in after landing many, many times but never while taxiing out for takeoff. It was a very effective and safe method to control taxi speeds on an aircraft that was typically light weight at destination.
AA737-823
Wed Jan 23, 2013 11:09 am
Quoting longhauler (Reply 19):
It's very subtle; we mechs have to be watching the EPR and N2 gages closely; my ear is pretty good, but the increase in fan noise is drowned out by the scream of the diverted airflow!
As to whether it's all of them, I can only testify to the -17A.
Indeed; here in slick, slick, slick Anchorage, I've watched pilots taxi into position (and also at the hangar) using differential reverse thrust to steer the airplane. You'll see the nosewheel turn a bit, then a bit more, then FULL deflection with no effect on aircraft heading... that's when you put your hood up over your head, because you know that the inboard engine is about to go into reverse!
Quoting GlobalMoose (Reply 20):
C-17A.
Aah, a truly unique airframe indeed! And, with high-mount engines, you have a LOT of freedoms that FOD suckers don't enjoy.
Woodreau
Wed Jan 23, 2013 2:21 pm
Quoting freeze3192 (Reply 16):
At least someone is sane. Thrust reverser use at another American major ERJ-145 operator is prohibited when landing on dry runways, for taxi, and a whole lot of other reasons - basically you're not allowed to use them at all - all to save on maintenance costs related to maintaining thrust reversers. The only time the thrust reversers are allowed to be used is to prevent a runway excursion, as a last ditch method to keep from going past the end of the runway- which doesn't make a whole lot of sense as you know reversers work better at high speeds, brakes better at low speeds.
Sat Jan 26, 2013 7:11 am
Quoting woodreau (Reply 23):
Wouldn't a circular be accompanied by the reasoning too.
jetstar
Mon Jan 28, 2013 2:37 pm
On the Lockheed JetStar, for the first flight of the day we would deploy and test the reversers during taxi, it was part of our taxi checklist. If we did a battery start we would normally start the 2 inboard engines #2 and 3 and taxi out on them because these engines had the hydraulic pumps.
If we used a ground power cart, usually at our home base then we would start all 4 engines if we knew we would not have a long ground delay, if so then we would just start 2 engines. On 2 engines we had to use some power to start from a dead stop but the residual thrust at idle was not enough to get us moving too fast requiring brakes to control our speed. Taxing with 4 engines we would need to use a little braking to keep our taxi speeds down, but not enough to get the brakes to hot.
Same here
On the JetStar, the APU exhaust door was above the #3 engine near the top of the fuselage. Since the P&W engines on the JetStar did not generate enough bleed air at idle to adequately cool the cabin on a hot day taxing on 2 engines we would leave the APU running until we stated the remaining 2 engines to help cool the cabin and also help recharge the batteries for starting the other 2 engines. One we got the remaining engines running we would shut off the bleed air and turn off the generator but let the APU run for another minute or so to cool down before we shut it down, and then we would leave the door open to help cool the exhaust pipe for another minute or so before we would turn off the APU master switch which automatically closed the door.
The APU door opened outward and it was quite visible, so sometimes the tower or another airplane would let us know while taxing that they see a door open so we would tell them what it was and we will be shutting it
If the pilots forgot to shut down the APU or turn off the master switch to close the door, the circuit ran through the nose gear squat switch so upon rotation the APU would shut down and the door would automatically close, but the airflow over the door at that speed would warp the door slightly requiring replacing the APU exhaust door. I always kept a spare door in stock because at least one a year I would have to change one because some of our pilots, usually the Chief Pilot when he would swap seats with our other Captain which they did every leg forgot to close the door. It was whoever was in the co-pilots seat to manage the APU because the APU controls were on the far right side of the overhead panel slightly behind their head, there was no warning light on our master control warning system, you had to look up at the APU control panel to see if the red power light was out confirming the APU door was closed.
JetStar
DashTrash
Wed Apr 24, 2013 3:05 pm
I used to do it in the Citation X. We weren't allowed to single engine taxi and both motors going is just too much push even at idle when the airplane is light. I can't remember which engine it was, but one of the deflected the exhaust right into the cabin intakes. If you popped that one it wouldn't take long before you're sniffing kerosene fumes.
The X also has a high idle switch used for touch and goes. At lights weights I'd select high idle to get the airplane moving, then back to normal to keep it going. Taxi never using the thrust levers (throttles in a Cessna).
Kaiarahi
Wed Apr 24, 2013 3:45 pm
Would that be the operator that's twice overrun 07 at YOW?
Empty vessels make the most noise.
roseflyer
Wed Apr 24, 2013 5:48 pm
On airplanes with carbon fiber brakes (MD80 isn’t one of them), braking at taxi speed actually causes more wear to the brakes than landing. The reason is because the brake is designed to work in a high temperature environment with continuous applicable. Frequent applications at low temperature cause increased brake wear.
Here’s a great article on brake wear.
http://www.boeing.com/commercial/aer...ticles/qtr_03_09/article_05_1.html
Because the wear mechanisms are different between carbon and steel brakes, different taxi braking techniques are recommended for carbon brakes in order to maximize brake life.
Steel brake wear is directly proportional to the kinetic energy absorbed by the brakes. Maximum steel brake life can be achieved during taxi by using a large number of small, light brake applications, allowing some time for brake cooling between applications. High airplane gross weights and high brake application speeds tend to reduce steel brake life because they require the brakes to absorb a large amount of kinetic energy.
Carbon brake wear is primarily dependent on the total number of brake applications — one firm brake application causes less wear than several light applications. Maximum carbon brake life can be achieved during taxi by using a small number of long, moderately firm brake applications instead of numerous light brake applications. This can be achieved by allowing taxi speed to increase from below target speed to above target speed, then using a single firm brake application to reduce speed below the target and repeating if required, rather than maintaining a constant taxi speed using numerous brake applications. Carbon brake wear is much less sensitive to airplane weight and speed than steel brake wear.
N353SK
Thu Apr 25, 2013 5:53 am
Quoting Kaiarahi (Reply 27):
No ... the airline you're thinking of is so cheap that some of their ERJs aren't even equipped with thrust reversers.
airportugal310
Thu Apr 25, 2013 7:37 am
Quoting N353SK (Reply 29):
UAX right?
I sell airplanes and airplane accessories
N353SK
Thu Apr 25, 2013 9:46 pm
Quoting airportugal310 (Reply 30):
UAX right?
Yes.. Trans States
FlyboyOz
Sat Apr 27, 2013 11:17 pm
Didn't a 737-200 use reversers all the time after touching down on the runway?
The Spirit of AustraliAN - Longreach
Mon Apr 29, 2013 10:09 am
Quoting FlyboyOz (Reply 32):
Unless you have one INOP & Deffered under MEL.
Also depends on the Runway length.
slimshady
Thu May 30, 2013 10:18 pm
C-17A.
C-17 is different than airliners with regard to thrust reverse..
Clamshell reversers on planes like the MD-80 deflect ALL thrust.
Translating sleeves like on the 737-NG & Classics, 757, 747, 767, 777, 787 deflect fan bypass air only. The thrust from the hot section is not reversed. All airbus are the same except the CFM56-5 uses blocker doors as opposed to a translating sleeve, but it still does not block the hot section exhaust.
C-17 is different as it uses both Fan Reversers and Thrust Reversers, deflecing both hot and cold air. Its the only aircraft I can think of being manufactured today in this configuration but I could be wrong. I think some early 747 variants made use of both thrust and fan reversers..
Sorry if I went off on a tangent.
BTW, the flight department I worked at, it was in our SOP to pop #1TR during taxi on our Citation X's
Acey559
Wed Jun 05, 2013 10:26 pm
We can't do it at Eagle, our limitations prohibit reverser use during taxi except for emergencies.
Thu Jun 13, 2013 10:35 am
Quoting Acey559 (Reply 35):
Why is it not decibal restricted rather than non use of TRs, some Aircraft would be less noisy than others.
evil8er2006
Fri Jun 14, 2013 8:46 am
When I flew C-17s, I rarely taxied with 2 & 3 in Idle Rev and I rarely flew with folks who did. Yes, I used the brakes a little more, but I felt it didn't make a huge difference brake temp-wise to tap them every now and then. Sure, it may have slowed the cooling process if you were doing a four stop in the box, but most times, I didn't think it was a huge issue. Also, it looks silly to be taxiing along with 2 & 3 in reverse and your spoilers deployed (if the Spoiler switch is Armed). Sure, it's a great way to demonstrate to new copilots how the rejected takeoff logic works for the spoiler system, but other than that, I saw no need to test it day in and day out. Technique only...
mhkansan
Mon Jun 17, 2013 4:09 am
Some of the ex-ATR pilots at Eagle do it all the time. Some guys use the TR to corner better, some don't touch it and burn up the whole runway on landing.
Users browsing this forum: BobleBrave, Channex757, kurtverbose and 8 guests
