dlramp4life
Draining Water Tanks
Wed Jan 16, 2013 6:59 am
Since the weather has gotton below freezing every night for the past week where I live, we have been instructed to drain water tanks on all aircraft that won't be sitting at a gate connected to power all night...
My question is if there is power from a GPU going into the aircraft, how the plane having power does prevent the water from freezing over in potable water tank?
SEA Ramp, wettest place on earth
Bartonsayswhat
RE: Draining Water Tanks
Wed Jan 16, 2013 9:23 am
Water tanks are heated. Our ground manual (CRJ200) tells us to to ensure RON aircraft are plugged in overnight, ground service switch is on, and that the water system power switches in the galley are on. This ensures the heater ribbons are turned on. SOP is to take a diesel GPU out to the plane and keep the heaters on rather than drain the system, as not all of the water from the lines will come out and cracking in the lines could occur.
Tristarsteve
Wed Jan 16, 2013 10:22 am
Quoting bartonsayswhat (Reply 1):
I see you live in Canada. Maybe your water tanks are heated. It is not normal.
Standard aircraft have no heating at all for the water system. Water line heating with electric ribbon heaters is an option that is only taken up by airliners in arctic regions. The rest of us drain the tanks.
I find that with an A320, putting a cabin heater on will keep the water flowing down to around Minus 20 degC overnight. Putting on ground power has no effect at all.
The rules here are, down to M5degC do nothing.
M5 down to M15 put on cabin heater
M15 down, drain water system.
dlramp4life
Wed Jan 16, 2013 8:46 pm
I find that interesting because we have a CRJ700/900 over night in my station daily and the regional airline policy states that we drain the tanks when the aircraft is a RON.
AA737-823
Thu Jan 17, 2013 10:47 pm
Quoting dlramp4life (Thread starter):
Even a powered airplane makes a bit of heat. We tried this approach once. Once.
No, not really. The water lines are optionally heated; the tank is not.
Exactly; the ribbons heat the lines, not the tank. I'm not aware of any aircraft that has optional tank heat.
Not if it's designed properly. When rampers drain the potable tank, they're not getting the water out of the system, sure. But when we mechanics do it, we know to open the OTHER drain valve, which lets the remainder of the water gravity feed out of the system's lowest point.
Quoting Tristarsteve (Reply 2):
I doubt it; here in Alaska, the 737 tanks aren't heated... just the lines.
After learning the hard way that forward lavatory lines are VERY HARD TO THAW, we leave heat on the planes, and drain the water anyway! If someone (ramp) leaves L1 cocked while they are servicing the cabin, the door hinge covers aren't sealed shut, and blow icy air straight into the forward lav cavity that houses the water line! Took us ages to figure that one out.
All of this is why I eagerly await the arrival of May, when temps no longer warrant potable water worries!
Tristarsteve
Fri Jan 18, 2013 7:56 am
Quoting AA737-823 (Reply 4):
Yes, the amount of problems drinking water supply on aircraft causes is amazing.
We need someone to invent an additive that stops water freezing, and can be drunk!
rwessel
Fri Jan 18, 2013 7:59 am
Quoting Tristarsteve (Reply 5):
100 proof vodka freezes at about -40 (F or C). And it can be drunk.
Bartonsayswhat
Fri Jan 18, 2013 9:21 am
Just look at the winter ops chapter in our ASM, and it only mentions to make sure the ribbons are just turned on, I guess I always just imagined them in the tank. It says water MUST be serviced full, as the lines on the CRJ don't completely drain. Also service lavs full with Type 1 glycol 100% and a cup of undiluted deodorant liquid, or 50-50 automotive anti freeze.
If it gets below -25 and the A/C RONs outside, then the covers go on, and a heater unit must be attached. If heater is unavailable, then the APU is run and the plane is babysat..
Users browsing this forum: 67ponajrad, longhauler, SAAFNAV and 2 guests
