JAGflyer
Wear And Tear On A Plane
Sat Jan 19, 2013 4:56 am
Besides being operated by a carrier like Hawaiian or Aloha (RIP) which flies the sh*t out of their short haul fleet (island hopping all day) which racks up cycles, what other types of operator would put heavier wear on a plane? I think of it like a car that drives 40,000 miles on the highway every year vs. 40,000 miles delivering parcels in the city every year. I'm not referring specifically to cycles/hours but just the general condition of the plane inside/out. At the moment I work for a charter airline who's planes generally do 4 flights daily ex-YYZ. The planes leave YYZ around 0600, fly down to the Caribbean, fly back up and arrive back in YYZ around 14-1500. During the turn, some maintenance items may be done but most are left till RON. They then leave again around 1600. Their flying day finishes when they come back to YYZ between 2300 and 0200. The planes get a 4-5 hour rest and regular maintenance is performed (wheel changes, LRU changes, etc). The interiors begin to look worn quite quickly and we seem to be replacing seat parts regularly (if the plane is full every flight, about 700-800 pax have been on it within 24 hours).
Thankfully we have a very good maintenance team and the planes are very well taken care of. The same can't be said for the other carriers we've leased planes from (duct taped armrests x 10, broken recline cables, worn seat covers, and that's just the inside!). I don't have experience with other operators but I'd think a plane like a 777 which flies longer flights endures less wear than an A320 which does four, 3 hour flights daily. Certainly the wheels and brakes would not need changing so often. I remember when I used to work in stores I used to dread hearing mtce call for main wheels but it would happen at least once every night shift. They're heavy and incredibly dirty parts to deal with! At least the worn ones were able to stand up without falling over on their side!
[Edited 2013-01-18 21:03:23]
[Edited 2013-01-18 21:23:46]
If you flew today, thank a Flight Dispatcher!
RE: Wear And Tear On A Plane
Sat Jan 19, 2013 5:14 am
I think there's a line in the sand that needs to be drawn here between two types of wear.
- "Cosmetic" wear and tear. Chipped and worn, oil streaks, worn upholstery, etc. All that stuff will eventually lead to more maintenance but in the main it serves to make the plane look good and has little or no impact on airworthiness.
- "Operational" wear and tear. Corrosion of structural bits, inop navigational equipment, tires worn just a bit more than they should be before replacement. This stuff will kill you.
Some operators keep their planes spotless. Cathay Pacific and Singapore Airlines come to mind. Others are fine with wear and tear but still safe, say Air France. And at the low end you have Central African Republic Revolutionary Army Airways (and Surf Shack)...
I'd say if you want to see planes that are cosmetically worn, go to your local flight school!
JAGflyer
Sat Jan 19, 2013 5:21 am
Quoting Starlionblue (Reply 1):
Oh yes, my first job was at an FBO and those planes were vintage. I once flew a 172 built in the 70s that had ashtray one of which had an old cigarette butt in it. Not to mention the smell of dozens of students who decided to eat a large meal before their first flight
Sat Jan 19, 2013 5:30 am
Quoting JAGflyer (Reply 2):
I was very lucky with my flight school (or maybe I just chose wisely). Immaculate planes. One of the chief instructors would do a line check twice daily. Even a sunshade not in place would be fixed (well, the guilty student would be told to fix it!). The planes were washed and detailed every week. Squawks were resolved promptly. Maintenance was carried out just a touch earlier than needed. Sure, they cost a bit more, but you very seldom had issues with planes not being available. It saved me a lot of time to always have some airworthy plane.
This is of course rather unusual. When I did my multi rating at another school, and it was certainly a good one, my wrists were always filthy from rubbing the greasy sides of the fuel sumping hatches. Behind the rear seat of the plane was a (broken) sunshade, several empty bottles of engine oil, old approach plates. It amazed me that something that takes very little time to fix and can be mostly delegated onto students in the after shutdown checklist was completely disregarded. The planes were not unsafe but it seemed so unprofessional to me.
Sat Jan 19, 2013 6:37 am
Not to mention the type of terrain the Aircraft operates in ie climatic conditionwise also contributes to rapid or less wear overall.
Are you saying students ate inside the Aircraft or you mean Students after eating sat in the aircraft with the food aroma.
Exactly....
Quoting Starlionblue (Reply 3):
In addition to cleaning the dust on the exterior, it also improves the Airframe performance when cleaned.
Sat Jan 19, 2013 6:42 am
Quoting HAWK21M (Reply 4):
Yes.
Have seen both happen.
rwessel
Sat Jan 19, 2013 7:41 am
Heavy meal, maneuvering, turbulence, inexperienced flier...
Sat Jan 19, 2013 8:42 am
Quoting rwessel (Reply 6):
Breakfast burritos and their aftermath...
Sat Jan 19, 2013 9:07 am
Quoting Starlionblue (Reply 5):
I can understand the latter not in the control of the Training school, but eating inside the Aircraft can def be forbidden.
Sat Jan 19, 2013 9:16 am
Quoting HAWK21M (Reply 8):
I don't think that is really necessary. We were often doing 3-5 hour cross countries. Once I did 11 hours with two stops. A snack can be pretty essential when you're tited and landing in the dark after a long trek.
What should be demanded is that students tidy up any wrappers and discarded note paper etc. If there's a mess, clean it up!
JAGflyer
Sat Jan 19, 2013 4:01 pm
You missed the joke. First time fliers in a small plane, large meal, motion sickness = nausea and the associated transfer of stomach contents out of the body into (if we're lucky) a small bag.
Fabo
Sat Jan 19, 2013 5:29 pm
Quoting JAGflyer (Thread starter):
I think I know who you work for and I think I know whose planes you refer to
This is all about money - if your (lessee) airline does not specify that aircraft are to be in spotless condition on beginning of the lease, the lessor airline might just defer it so as to save money. Hell, the Canadians might even end up changing this on their own dime!
Didnt you get a brand new plane from this very airline last winter btw? Diverted from BFI after a wind event (IIRC) grounded one of other leased planes.
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
JAGflyer
Sun Jan 20, 2013 1:07 am
Quoting Fabo (Reply 11):
Yes, you are on the right track. I remember going to see the new plane before it entered pax service and the smell of the interior was just like a new car.
[Edited 2013-01-19 17:14:53]
KC135Hydraulics
Sun Jan 20, 2013 1:49 am
Think also about wear and tear as a function of age. The planes I work on were built in the 50s and 60s, and I find all sorts of incredible things inside of them. In wing dry bays where we have our hydraulic reservoirs for example, I'm finding archaeic FOD that has likely been flying around in there for 50 years. Also, I find it astonishing, for example, when I'm pulling and replacing components that were original to the jet. For example, I recently removed a hydraulic flow regulator that was bad, and after looking over the part I found the original cure date and assembly stamps dated from 1961. It was obvious that the part had not been disturbed/removed/overhauled since then given its deteriorization. When you're holding a part like that in your hands it makes you wonder about the people that were around when they made that part, and who it might have been when they installed it. Where are they now, and what would they think if you told them this part they made/installed 50 years ago survived and operated well into 2013? There's not a lot of anything these days that can work for 50 years. Amazing!
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
JAGflyer
Sun Jan 20, 2013 3:03 am
Quoting KC135Hydraulics (Reply 13):
Any original parts on a 50 year old aircraft surprise me, especially ones that endure high pressure and intensive use such as something in the hydraulic system. What would be more interesting to me would be finding things from the 60s that were forgotten about back then. Stuff like newspapers, soda cans, etc.
Sun Jan 20, 2013 8:18 am
Restricting the type of food will help.
Quoting JAGflyer (Reply 10):
a small bag.
Ok.Understood....
DarkSnowyNight
Sun Jan 20, 2013 12:19 pm
I used to do Transit checks on BA 744s, and no, they were not in much better shape. In fact, most of the time, there were at least seven to nine open entries in the cabin log upon arrival. It seemed as though there was just about the same amount of cabin rash on these as any of the Super 80s or 737s we worked. And a lot of powerplant and airframe squawks too, of course.
Well, you could always change places and actually R&R the damned things. I'm pretty sure MX will do what they can to not call you for that one.
Much like a GE90, I'm a huge fan of Big Twins...
Users browsing this forum: airxliban, N415XJ and 1 guest
