naruto38700
When Destination Airport Closes
Sat Jan 19, 2013 6:25 pm
I always think of this scenario, when I am flying for my holiday destination, I was told the airport is closed for terrorist bombing or something, what are the solutions? Does aircraft usually have enough fuel to fly to another airport to land?
To establish a topic, let's talk about Manchester Airport. If I am flying to MAN, was told the airport is closed, where will I be directed to?
bueb0g
RE: When Destination Airport Closes
Sat Jan 19, 2013 6:36 pm
Quoting naruto38700 (Thread starter):
Of course. On any commercial flight, the dispatchers, planners and pilots will have made sure that the aircraft has enough fuel to make it to the destination, make 2 or 3 approaches, and still be able to divert to an airport 30 - 40 mins away (plus holding time fuel and some contingency fuel, somewhere in the region of 5 - 10%). It would be hideously dangerous to only take the amount of fuel you needed to get to the destination - any number of things could happen that might force athe crew to divert (most common would be airport closure or bad weather).
This will vary depending on the airline, and the situation. But generally a major airport within 30 - 40 minutes of MAN. One of the London airports, Birmingham, Liverpool etc. Doesn't really matter as long as you get on the ground.
Roger roger, what's our vector, victor?
bmacleod
Sat Jan 19, 2013 6:37 pm
LBA most likely the closest major airport....
"What good are wings without the courage to fly?" - Atticus
qf002
Sat Jan 19, 2013 6:46 pm
LON most likely, or LPL for regional services. There are so many big major airports in the UK that are so close together that diversions are far easier than in other parts of the world where you might be faced with a considerable journey to a suitable alternate.
longhauler
Sat Jan 19, 2013 10:36 pm
With some guidelines, fuel for an alternate is not always carried. Rest assured, when that is the case, the airline, pilots and dispatchers are certain that the aircraft will arrive at the destination.
However, when an alternate is required, there are levels of plans depending on how likely the alternate is to be used. For example, is the weather is so questionable at the destination that the alternate will be used, it is one where the airline would like the airplane. Namely, there are facilities to handle the passengers and aircraft, as well as alternate transportation and crews should they be required. An example might be YOW as an alternate for YYZ.
When an alternate is required but not likely to be used, for example the weather at the destination is excellent, then fuel for a "technical alternate" is carried. It satisfies legal requirements, but is not likely to be used. Good examples for YYZ might be IAG or YTR.
But fuel is carried for just about any contingency.
Mr AirNZ
Sun Jan 20, 2013 12:00 am
Quoting bueb0g (Reply 1):
I disagree with the 2-3 approaches part. If things are tight payload wise, often I would have gas for one approach before diverting to an alternate. Where I work, the crew have final say on fuel loads but carrying excess fuel at the expensive of payload would lead to a 'please explain' from higher up the chain. The odd diversion that then actually happens because you only had one shot (and if you had had more gas you could have stuck around any maybe got in) is easily offset by the extra payload you have carried on the 99% of flights where you arrive with no issues.
JAGflyer
Sun Jan 20, 2013 2:59 am
Quoting longhauler (Reply 4):
I've never heard of a diversion to IAG for a YYZ-bound flight. The most common alternate for YYZ would be YHM and failing that YOW or YUL depending on the location of the plane when the choice to divert is made.
Support the beer and soda can industry, your recycle old airplanes!
longhauler
Sun Jan 20, 2013 3:40 am
Quoting JAGflyer (Reply 6):
The most common alternates for YYZ, when used, are YHM, IAG, BUF and YTR. These would be technical alternates. The only time YOW is carried is if the likelihood of actually diverting is high. YUL is only carried if YOW is not legal.
Depending on the weather, and where the "weather" is, I have also used YXU, YQG, DTW, PIT and YYB.
musang
Sun Jan 20, 2013 10:38 am
This is known as "Island Reserve" in some carriers, i.e. the specific set of rules/calculations/precautions/requiremnts to mitigate any risk inherent in going somewhere isolated. Mauritius, Galapagos etc.
Quoting Mr AirNZ (Reply 5):
I agree, no requirement for more than one shot at the destination, although one often finds one has enough fuel for a second go then divert.
For Manchester our technical alternate (i.e. when diversion considered unlikely) is for some reason nearly always Birmingham, although we can just about see Liverpool while on the approach to MAN! (BHX is more than twice as far away as LPL in a straight line, although diversion fuel requirements are planned on the worst case scenario SID* and STAR** for the runways anticipated to be in use). Other considerations for diversion selection include a company presence + good transport links + ability of the handling agency to accommodate a diversion etc.
* Standard Instrument Departure routing.
** Standard Arrival Routing.
Regards - musang
glen
Sun Jan 20, 2013 4:46 pm
Quoting musang (Reply 8):
According EU-OPS regulations a planning without alternate is also possible for "normal", not isolated destinations. Requirements are:
2 separate, usable runways with separate approach procedures based on separate navigation aids. (runway surfaces may be crossed, but in such a way that if one of the two runways is blocked, it will not prevent the planned operations on the other runway)
Weather: ceiling 2000ft or circling height +500ft, whichever is higher, visibility 5 km or more
no shallow fog, no thunderstorms, no heavy precipitation
(additional requirements regarding runway condition, braking action and wind)
In this case planning is allowed without destination alternate, but additional fuel of (only!) 15 minutes is required.
Not all airlines have incorporated this planning option. We have, but I know no captain who will take-off with only the legal minimum fuel, if planning is based on no alternate.
"The horizon of many people is a circle with zero radius which they call their point of view." - Albert Einstein
B6JFKH81
Sun Jan 20, 2013 5:07 pm
One of the nice things about WX diversions is that everyone has time to plan accordingly, and normally will route the aircraft to somewhere that the airline flies to and has staff to support the customers. My airline, for example, is based at JFK and also has flights to EWR, LGA and HPN in the NYC area. Often times all 3 major NYC airports will have problems with the same storm due to their proximity, airspace gets backed up really quickly so flights might divert to cities that we fly to accordingly. Ones already near NYC might divert to SWF, BDL, PIT, IAD and BOS. Ones further away may divert to RIC, CLT, ROC, BUF, SYR. All have our own crews for support. Every now and then you'll see us divert to ACY though, we don't have an operation there so no company support, but due to proximity to JFK/EWR/LGA, I'm sure they would get going fairly quickly once things open back up.
longhauler
Sun Jan 20, 2013 5:39 pm
Funny you should say this, as at AC, all "Island" destinations require an alternate, regardless of weather.
I was actually referring to this:
Quoting glen (Reply 9):
We just call it "No-Alternate IFR", and in Canada, the requirements are similar to what is stated above.
One of the big differences between Canadian No-Alternate IFR and what you state above is the "extra" fuel. We have to carry around 45 minutes extra, (sometimes more). Often No-Alternate IFR will carry more fuel than if an alternate is carried, if the alternate is close. Fore example, YMX for YUL, or OAK for SFO.
glen
Sun Jan 20, 2013 7:45 pm
Quoting longhauler (Reply 11):
That's what a lot of us would take as extra fuel usually, but for a destination where operation always run smoothly we sometimes take less. (Although the company encourages us to take as little fuel as possible in order to save weight, we are luckily free to take as much extra fuel as we think is necessary without having to justify it.)
Same with us. However, because it is an isolated destination it is a so called "Planning with predetermined point procedure". That means somewhere enroute you have a decision point where you have to decide about proceeding to the destination or to the alternate. And of course the required extra fuel is higher in this case.
AR385
Sun Jan 20, 2013 7:59 pm
When that AF A340 went off the runway at YYZ, a KLM behind it issued a PAN, PAN for minimum fuel and diverted to BUF, IIRC. He was offered YOW, but said he was going to BUF.
roseflyer
Sun Jan 20, 2013 8:36 pm
The reason for needing to divert when not planned is almost always weather. Weather got worse en route and the arrivals rate decreased at the destination. The results in some form of flow control.
When an airport in known to have bad weather the dispatcher or crew almost always loads extra fuel to allow some holding time. Extra fuel for an alternate with known acceptable weather is also loaded.
When something other than weather that can't be anticipated closes an airport such as an emergency response, things can get interesting. As mentioned earlier alternate fuel is not always loaded. You see this more on airplanes close to their max payload, but some airlines are very close on margins to save money since less fuel is less weight which saves total fuel burn.
When this happens there is almost always an en route airport that can be diverted to. There are some parts of the world where diversions can get challenging. BA is known to be very cautious. I have heard of BA 747s carrying enough fuel to use BOS or JFK as an alternate to LHR when the bad weather hits. I have also heard in the Indian fog season, carrying enough fuel to use BKK or DXB as alternates. It all depends on how much holding and wasted fuel they want to carry to prevent diversions.
Okie
Mon Jan 21, 2013 3:06 am
Tenerife always comes to mind when thinking of diversions.
Okie
cornutt
Tue Jan 22, 2013 1:07 am
I recall an evening about six years ago when the Atlanta area was beset by severe weather, and ATL and all of the other fields with long runways in the region were closed. Delta was stuffing aircraft into any airport with a long enough runway. They sent a lot of flights that were eastbound to ATL into HSV instead. Now, I happen to think HSV is a nice airport, but it only has 10 gates, and Delta dropped about 25 aircraft there. There were airplanes everywhere! I think they even parked a few of them at the cargo terminal. I was supposed to have a flight out that evening. I got to the gate area, looked out the window, and said "WTF!" Needless to say, my flight was cancelled. They were having to shuffle aircraft around in the ramp area so other airlines' flights could arrive and depart.
Cubsrule
Tue Jan 22, 2013 1:54 pm
Quoting cornutt (Reply 16):
Not all that uncommon. DL has a robust diversion plan, and if you look carefully at the DL ramp at airports like BNA, CAE or HSV, you can see "diversion carts" (that's what they call them) sitting waiting.
aklrno
Tue Jan 22, 2013 10:09 pm
I've been diverted several times flying WN into RNO. In the winter there are occasional snow and fog closures. Since the WN flights out of RNO are usually only an hour or so, the plane just continues to the next scheduled stop for that aircraft, something like LAX,OAK, Portland, Seattle. That way the minimum number of passengers are disrupted. Some were actually going to the diversion point anyway, and subsequent flights go on time. And since they are normal WN stations, they can often put me on a flight back the same day. My record is two diversions in one day. LAX, past RNO to PDX, then PDX past RNO to LAS. Next day LAS to RNO.
BoeingGuy
Wed Jan 23, 2013 1:10 am
Quoting AR385 (Reply 13):
Actually he went to SYR.
AR385
Wed Jan 23, 2013 2:30 am
Quoting BoeingGuy (Reply 19):
Yeah, I was wary of saying he went to BUF, but my memory is just not that good. What was the reason for going to SYR, instead of YOW? too much backtracking? What do you do with passengers that don´t have a US VISA?
BoeingGuy
Wed Jan 23, 2013 4:44 pm
Quoting AR385 (Reply 20):
IIRC, KLM was close to SYR. ATC offered him a Canadian alternate but the Captain elected to go to the nearest suitable airport. I don't think at that point he cared about Visa considerations. He apparently thought the safest choice under the circumstances was to land at SYR. That outweighs all other considerations.
However, you ask a good question. What does happen when an international flight diverts to another country in which passengers may not have a Visa, or there are no customs facilities? That happened a few years ago when AM diverted to PDX and customs was closed for the day so they didn't let anyone off the airplane.
Actually, AF358's alternate was YOW. We can play "armchair quarterback" all day, but obviously he should have gone to YOW. From what I've read (I've studied the accident), AF358 had enough fuel to divert back to YUL also if he had gone around at YYZ like he should have.
northstardc4m
Wed Jan 23, 2013 6:27 pm
Quoting BoeingGuy (Reply 21):
It happened several years ago with Skyservice diverted 2 flights into YYB when YYZ was closed, they could not be allowed out of the TINY secured lounge at YYB until the aircraft could be reboarded and left for YYZ, no customs at YYB... I forget why they offloaded them at all.
Uncomfortable for passengers, but it's a rare occurance.
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety.
n92r03
Thu Jan 24, 2013 2:23 am
Not exactly the same situation, but in '96, a Varig MD-11 was diverted to NAS Miramar as LAX and SAN were fogged in. I remember seeing it come through the fog just northwest of Miramar, was a very cool site. No one was allowed off the plane, they got some gas waited a couple hours and were off to LAX.
