novice
What Factors Affect The Range Of HF Communications
Sun Jan 20, 2013 12:03 am
"The following factors affect the range of HF communication:
1. Transmitter power
2. Frequency
3. Time of the day
4. Season
5. Location
6. Disturbance of the ionosphere"
Why is it the lower the frequency the further they travel, is are am i right here?
'Location'? would that be to do with the ionospheres lengths being different i.e. getting smaller towards the poles?
As with 'disturbance of the ionosphere' i take it the following wiki abstract is what they it is referring to;
"A sudden ionospheric disturbance (SID) is an abnormally high ionization/plasma density in the D region of the ionosphere caused by a solar flare. The SID results in a sudden increase in radio-wave absorption that is most severe in the upper medium frequency (MF) and lower high frequency (HF) ranges, and as a result often interrupts or interferes with telecommunications systems."
From that i don't understand why an increase causes it to absorb the radio wave? as i thought it was this increase in the ions that created the D region, which enabled radio waves or sky waves to reflect from
rfields5421
RE: What Factors Affect The Range Of HF Communications
Sun Jan 20, 2013 1:57 am
You are really going beyond the scope of an aviation forum.
This is a good basic discussion
http://ecjones.org/propag.html
Some of these images can help understand how it works.
http://www.google.com/search?q=hf+ra...HgBw&ved=0CFMQsAQ&biw=1193&bih=639
This video is also pretty good
http://www.youtube.com/watch?v=YgmvPWRYw3I
This PDF of a presentation is also pretty good
http://www.google.com/url?sa=t&rct=j...QNjxch0G_90A&bvm=bv.41248874,d.b2I
Woodreau
Sun Jan 20, 2013 12:42 pm
Here's another document discussing radio wave propagation. It's what I used in my former career as a navigator.
http://msi.nga.mil/MSISiteContent/St...ticFiles/NAV_PUBS/APN/Chapt-10.pdf
If the link doesn't work, you can google Pub 9 American Practical Navigator then select Chapter 10 or the whole manual.
[Edited 2013-01-20 04:44:04]
novice
Tue Jan 22, 2013 4:43 pm
Thanks for the links guys a lot of helpful information in them
apodino
Wed Jan 23, 2013 4:37 pm
As an Amateur Radio Operator, I have had to learn a lot about this because we do a lot of stuff on HF in the hobby. I could be here all day writing, but I encourage you to check out ARRL.ORG, which is one of the national associations that deals with Amateur Radio. There are a lot of good resources there that should help answer your questions.
txjim
Thu Jan 24, 2013 4:51 pm
I would also refer you to an old Collins Radio publication, "The Fundamentals of Single Sideband" available here:
http://www.collinsradio.org/cca-coll...s/fundamentals-of-single-side-band
Chapter 11 specifically discuss radio wave propagation
Users browsing this forum: barney captain, Bing [Bot], Guillaume787, StTim and 18 guests
