gulfstream650
Grounded 787 Pilots
Tue Jan 29, 2013 4:08 pm
Although of course they are probably rated on other types (and I may have answered my own question) but based on my knowledge of pilots being paid by the flying hour, how are 787 pilots earning a living at the moment?
I don't proclaim to be the best pilot in the world but I'm safe
doug_or
RE: Grounded 787 Pilots
Tue Jan 29, 2013 4:20 pm
At most airlines after completing training on a new type you are no longer considered qualified to fly the old one. The FAA (or local authority) may still see them as properly rated pilot, but they could most likely not go right back to their old equipment. Most airlines have a minimum hourly guarantee, so the pilots not flying will probably be paid this.
When in doubt, one B pump off
777ord
They get paid their "guarentee" per month as this situation does not fall under them. They MAY have some administrative duties to perform, not likely.. So, it's literally free money.
If the 787 is grounded for a signifcant amont of time. Say 6mo-1yr. They'll go back to the 777 or 756 they previously were on.
FlyHossD
Tue Jan 29, 2013 4:30 pm
I've heard through my grapevine that UA has cancelled future 787 training; those already in training will finish. Of course, this is NOT official.
Quoting 777ord (Reply 2):
There's probably a contractual limitation, too. That is, a pilot would have to bid a different position, too - he or she can't just bump another pilot out of his/her position (without an awarded position).
aeroblogger
Tue Jan 29, 2013 4:33 pm
AI is sending all ex-777 pilots back to the 777, as it's only a single day conversion process, and the 787 is expected to be down for at least a month or 2.
Pilots from the 747 or A330 fleet will remain on the 787, as it's more expensive to retrain them.
Airports 2012: IXE HYD DEL BLR BOM CCU KNU KTM BKK SIN ICN LAX BUR SFO PHX IAH ORD EWR PHL PVD BOS FRA MUC IST
bthebest
Tue Jan 29, 2013 4:57 pm
Quoting FlyHossD (Reply 3):
Of course, if they're replacing the services with other aircraft, other pilot's wouldn't be scheduled so wouldn't be as big a deal. I would guess it all depends on the airline/authority's training regulations.
LO231
Tue Jan 29, 2013 6:46 pm
I think LO's pilots are 767 men...
Got both LO 788 frames already, next LO E95 and 734 BRU-WAW-BRU
777ord
Tue Jan 29, 2013 7:31 pm
Quoting LO231 (Reply 6):
and that beautiful plane is still sitting next to T-5/ORD at a remote stand!
dkny
Tue Jan 29, 2013 7:37 pm
ET 787 pilots are rated for both the 787 and the 777 so no worries there
SCL767
Tue Jan 29, 2013 7:44 pm
LAN's 787 pilots are rated on the 767 and some are rated on the A340. The 787 pilots are currently flying 767 operated flights throughout LA's network.
LO231
Tue Jan 29, 2013 8:08 pm
Quoting 777ord (Reply 7):
Which one is it, -LRA or -LRB? I flew on both already, so got lucky, yay. Just curious...
Passedv1
Tue Jan 29, 2013 9:47 pm
Quoting gulfstream650 (Thread starter):
I don't know what the rules are for the various overseas carriers. I can tell you exactly what is happening at United...
They are getting paid 70 hours of flight pay (monthly minimum contractually at United) and they are off.
If United wants to get the 787 pilots back to other airplanes, they would have to close the 787 positions. When that happens, a displacement bid (or whatever United calls it) would have to be posted where 787 pilots could BUMP to ANY position in the system that their seniority could hold. It could be something that they have been trained in before, or it could be something completely different. Those pilots bumped by the 787 pilots could then bump anywhere, etc. until you get to the end. It would remain to be seen if United furloughed an equivilant number of junior pilots or created positions for them to be displaced to.
When it's time to put the 787 back in the air, they would have to put a bid out again for all pilots to bid on. It is a certainty that the "new" 787 will not be exactly the same pilots as the ones that are currently on the 787. In fact, United has the added twist that the current 787 pilots are all really CAL pilots. When a new bid comes out, the seniority list in use at the time will probably be the combined list (CAL/UAL) which gurantees that the new 787 pilots won't be the same.
Start counting training cycles, and you start to see why that unless the grounding is going to be at LEAST a year or more I think it is very unlikely that these pilots will be returned to the line sans some LOA with the union.
787CA displaces to 777CA who displaces a 767CA ->737CA -> 787FO -> 777FO -> 767FO -> 737FO -> Furlough?
And that's not eve considering the relative seniority of the domiciles.
Then in reverse when it's time to put the pieces back together.
blueflyer
Tue Jan 29, 2013 10:26 pm
I'm sure 787 pilots have all the time in the world to hit the flight simulator now, but at some point aren't they required to fly "real hours" to remain current on type?
Democracy 2016: 3 million California votes < 100,000 Midwest votes.
MD88Captain
Tue Jan 29, 2013 10:30 pm
No. Simulator time is sufficient to stay current. Otherwise, they stay at home and collect a check. Better than going to work to fly a plane with fire issues.
dairy
Tue Jan 29, 2013 10:49 pm
Quoting LO231 (Reply 10):
it's LRA!
A318/A319/A320/A321 AB3/A306/A310/A333/A343/A346 732/733/735/736/744/752/763/764/772/773 DH3 F70 F100 CR2 CR1 CR7 ATR42
bueb0g
Tue Jan 29, 2013 10:54 pm
Well a lot will be on annual salaries anyway so it doesn't matter how much they fly, and for those being paid by the hour, they generally get a monthly guarantee of 60 - 70 hrs.
Roger roger, what's our vector, victor?
Aaron747
Tue Jan 29, 2013 11:22 pm
I'm not sure about JAL, but at ANA they are on a straight salary system. Also things being what they are in Japan, most likely the grounded 787 pilots are being given mundane administrative duties. Even if they are contractually unable to assign these duties, most likely the pilots have volunteered or made oral agreements with management to do so. There is basically no concept of getting paid for nothing in this country.
Wed Jan 30, 2013 4:39 am
Quoting blueflyer (Reply 12):
As Md88Captain says, the simulator is enough. Most new airline pilots nowadays have never flown the real aircraft until the first time they fly in the right seat, on the line, with passengers. The plane is waaaaay too expensive to use as a training device when the simulator is so accurate.
Users browsing this forum: Woodreau and 19 guests
