trex8
A340 Nose Down Also Like A330?
Mon Feb 04, 2013 2:56 pm
I've always assumed the A340s had the same nose down angle like the A330s but I was skimming some old Flight Intl mags this weekend and somewhere it said a freighter A340 wouldn't be an issue. The A332F needs that weird nose gear blister change and I've seen reports that P2F conversions will need a jack but wouldn't the A340s also need this too? Also the proposed LCF conversion doesn';t mention anything about having to change the height of the nose gear.http://www.lcfconversions.com/a340.html. Thoughts?
LH707330
RE: A340 Nose Down Also Like A330?
Mon Feb 04, 2013 5:13 pm
The A340-300 and 330-300 have the same nose-down angle on the ground, so the A340 freighter would need a similar system to stay level or close to it.
Thu Feb 07, 2013 5:08 am
Surprisingly the link does not speak of the NLG & its raising mod.
Maybe they did not want to get technical and specific.
MIAspotter
Thu Feb 07, 2013 10:04 am
An A340 Freighter? now that would be a fun thing to see, trying to get off the ground fully loaded with cargo.
MIAspotter
Nos vamos de Vueling?
Thu Feb 07, 2013 10:59 am
Quoting MIAspotter (Reply 3):
MIAspotter
As has been repeatedly explained on this board, the Airbus 340 performs just fine and well within safety and regulatory limits.
MIAspotter
Thu Feb 07, 2013 2:59 pm
Quoting Starlionblue (Reply 4):
Yes I am aware of that thank you very much, but we also agree is not exactly a rocket and carrying PAX fuel and cargo might not be the same as carrying lots of cargo and fuel...
But is it really viable? isn´t it just better to offer just the A330F (both -200 and -300) you know... 2 engines, less fuel, less costs.
My 2 cents
MIAspotter
Thu Feb 07, 2013 3:20 pm
Quoting MIAspotter (Reply 5):
It is a fallacy that the 330 is always better than the 340. If that were the case, Airbus wouldn't have kept selling 340s until a few years ago. The 340 does have its place, as evidenced by the many first line carriers still using it. Over long routes and in hot and high environments, the 340 is a great performer economically. Airlines don't care about it being a rocket. They care about return.
You're also assuming that cargo is necessarily denser than pax. That's not necessarily the case.
If you want a definitely better option, that would be a 350F.
trex8
Thu Feb 07, 2013 6:58 pm
They load underfloor cargo without a "levelling" issue now so why is it an issue when its main deck cargo? Just having heavier loads on the pallets???
With the LCF conversion since the pallets cant be bigger/higher than what goes in the belly maybe thats why they don't worry about the angulation of the planes deck???
Viscount724
Fri Feb 08, 2013 12:10 am
DC-8s and 707s operated just fine as freighters for decades (and a few DC-8s still do). In most cases I believe the A340 performs better than a heavily-loaded 707 or DC-8.
Stitch
Fri Feb 08, 2013 3:33 am
Quoting Viscount724 (Reply 8):
I don't have 707 numbers, but based on what Airbus have projected for an A340-300P2F, compared to a DC-8-63(C)F or DC-8-73(C)F, the A340 offers about 200 more cubic meters of volume, will lift about 10 tons more payload weight and offer thousands of more kilometers of range. And since they're both using CFM56-based engines, fuel burn is probably not too disparate between them.
rwessel
Fri Feb 08, 2013 10:35 am
Quoting trex8 (Reply 7):
If nothing else the lower deck is two much shorter segments, each with their own door. You'd at least not have to run a pallet of container nearly as far up (or down) hill.
LH707330
Fri Feb 08, 2013 7:35 pm
Off the runway, certainly. The early quad-jets were real dogs because of their low bypass engines (think starting your car from a light in 2nd gear). Once at higher altitudes, I bet a 707 could outclimb a 340.
Quoting Stitch (Reply 9):
The two engines are substantially different, the CFM56-2 makes 22klb and has a smaller fan and fewer stages than the -5C on the 340. Add to it that the 340s are heavier, and the 340 will burn substantially more. Per unit cargo, though, it will be less.
I think it's a problem because it's awkward to load long things from a truck into a sloped aircraft.
trex8
Sat Feb 09, 2013 1:57 am
Quoting rwessel (Reply 10):
Interesting point, may also be why the LCF idea does not need to address the slope as with one entry point to each underfloor hold and then up to the main cabin the distance any pallet will travel will be at most under half the cabin length.
Sat Feb 09, 2013 11:09 am
Why not consider Main deck Power driven units [PDUs], taking into account the added weight though.
AY-MD11
Sat Feb 16, 2013 3:17 pm
there is the slope in the A300 too and not seem to be a problem. I remember pushing 5000kg pallets to "uphill" in summer +30c with no aircon in the plane..with 3 rampers still hard work. What makes the A330/340 different to have mod in front gear?
LH707330
Wed Feb 27, 2013 3:42 am
Quoting AY-MD11 (Reply 14):
It's more slant on the 330/340.
VC-10
Tue Mar 05, 2013 12:02 am
???? - Why would carrying cargo and fuel be different to carrying pax etc? It is just payload.
The advantages of cargo are
1) It doesn't need feeding, watering and storage of the waste products that this produces.
2) It doesn't need to be sold duty free's.
3) You know exactly the weight going on board as against the SLF coming in all shapes & sizes with the variable weight of hand baggage
4) You don't need cabin crew
Cargo seems to have a lot going for it.
Users browsing this forum: jnev3289 and 2 guests
