smartt1982
727 Approach And Keeping The Engines Spooled Up
Sat Feb 09, 2013 3:02 pm
Was recently watching a clip of an approach on a 727, looked like everything was ok but the captain had to prompt the FO to keep the no 1 and 3 engines spooled up and that the FO could bring back thrust on the No2 to control the speed.
On the ground the captain stated this it was necessary to keep No1 and No 3 spooled up in case of a go around. Anyone heard of this before, is this a normal requirement on the 727 or any three engine jets?
I know that it is essential to have engines spooled up in case of a go around but what I am wondering is if it is common for the 727 to able to keep the required approach speed with engines idle or very close to idle normally on the approach?
[Edited 2013-02-09 07:48:38]
LimaFoxTango
RE: 727 Approach And Keeping The Engines Spooled Up
Sat Feb 09, 2013 4:02 pm
Unlike newer engines of today, older type engines take longer to spool up from idle. Keeping thrust just above idle shortens that time. There have been cases where the mains actually touch ground during a go-around although it was commenced as high as 100ft AGL (which could even lead to a tail strike). Another important reason for that "positive climb" call.
You are said to be a good pilot when your take-off's equal your landings.
rcair1
Crew
Sat Feb 09, 2013 4:04 pm
How old is the video?
About a year after intro, the 727 suffered a number of crashes short of the runway. There were a number of factors identified - primarily related to high sink rate and transition of pilots from prop to jet. It also had to do with the limited navigation aids at airports at that time. Part of the design criterion for the 727 was short field operations - so it had the ability, inherent in the design, for steep descent. Couple that with a lot of pilots transitioning from prop/turboprop to jet and you ended up with a situation where the aircraft could be at a high sink rate if at a low power setting. In addition - the response of the engines to throttle up was very slow - when compared to conventional prop driven a/c many of these pilots were transitioning from - which is nearly instantaneous. One more factor - the "jets" were fast and really needed pilots to fly "by the numbers" - much more so than slower prop driven planes. The 727 was so responsive and such a nice plane to fly that pilots often did not realize this and were more lax than they should have been.
Keeping the engines spooled up - where they responded quickly to throttle demands was one approach to help with this transition. The procedure noted was one approach used. In addition - some operators limited flap setting - not allowing full 40 degree flaps which added drag, but not much lift.
So - I think the procedure you noted is the result of a number of factors, one being the response to throttle up compared to props.
BTW - the source of most of this is a book I just finished - older - but interesting - called "Loud and Clear". There is another one specifically about the 727, but I've not been able to find a copy.
rcair1
tb727
Sat Feb 09, 2013 6:32 pm
Quoting smartt1982 (Thread starter):
Quoting rcair1 (Reply 2):
Yes it does help keep them spooled up but you normally would never really have them at idle in the 727 anyways when landing until within 10 feet of the ground otherwise you're gonna get a stinger of a landing. I start slowly bringing all of them them back at about 10 or so feet, some people cut number 2 to idle and then milk 1&3 back the last 10 feet.
Using #2 to control speed is a technique that is taught to keep from jockeying 3 engine controls around while on approach. #2 is centerline thrust, when you are flying an ILS and you get close to your targeted speed, you can use #2 to adjust without messing with any asymmetric thrust from 1 or 3 because they are off centerline. It's not much of an effect if 1 or 3 get out of whack but it's nice to just use one thrust lever after setting the other 2 and not touching them. Having all 3 levers lined up doesn't necessarily mean they are all putting out the same N1/EPR, they can be off upwards of an inch or so, I can't remember if we even have a limit published in our book but they never match exactly, at NW they could be up to 1 inch off. In addition you might not need the thrust you're going to get from 3 engines, one is enough to "fine tune" it.
It's also nice to have them spooled up late in the approach because when you close them, touchdown, then activate reverse thrust, the engine doesn't have time to spool all the way down and you almost immediately have good reverse thrust with not much delay for spool-up. Again, just one of the many little techniques and quirks that pilots have come up with the last 50 years now the airplane has flown.
113312
Sat Feb 09, 2013 9:34 pm
In the 727, you would never have a stabilized approach with engine thrust near idle. Normally, thrust adjustments to control airspeed would be made with all three engines together. However, in icing conditions with both engine and wing anti-ice systems ON, a minimum amount of engine RPM is necessary to produce sufficient hot bleed air for the ice protection to be effective. It could be that this was the case in this video. Engine 1 & 3 are producing the bleed air for the wing anti-ice. In this situation, the technique of only adjusting #2 could be used when the need arises to decelerate to adjust speed or extend additional flaps. Once the next target speed was achieved, the thrust could than be matched and sufficient to maintain the desired speed AND bleed air requirement.
flight152
Sat Feb 09, 2013 10:08 pm
Quoting 113312 (Reply 4):
Or any other transport category aircraft. When in a normal landing configuration, the drag created by the landing gear/flaps creates a need for a large amount of thrust in order to stay on the glideslope at Vref.
goboeing
Sat Feb 09, 2013 10:32 pm
Just out of curiosity, do you have a link to the video?
stratosphere
Sat Feb 09, 2013 10:43 pm
At FedEx the valsan mod 727 the # 1 and # 3 engines are a JT-8-217 they have an approach idle feature that keeps #1 and #3 spooled higher after the gear comes down then after touchdown there is a 5 sec delay built in in case of a go around then it reverts back to low idle setting.
speedbird128
Sun Feb 10, 2013 1:23 pm
Just out of interest, why was short-field ability coupled with steep descent?
A306, A313, A319, A320, A321, A332, A343, A345, A346 A388, AC90, B06, B722, B732, B733, B735, B738, B744, B762, B772, B7
rcair1
Crew
Sun Feb 10, 2013 2:19 pm
Quoting Speedbird128 (Reply 8):
I don't think the requirement was for a steep descent - but that the ability to do a steep descent - or get into one, was an artifact of the short field capability. I'm sure a 727 driver out there could comment better than I. My source is just reading about the design and some of the problems. The 727 was intended to get in and out of fields that other jets of the time could not. You could achieve a 1000-1500 ground roll on a landing in a loaded 727. Take-off - no so much I think.
Keep in mind - 'short field' was relative to the 707 and it's ilk.
rcair1
speedbird128
Sun Feb 10, 2013 2:38 pm
Quoting rcair1 (Reply 9):
Quite. I once witnessed a 727-100 departing out of JNB... it *just* cleared the LLZ antenna departing off 03L. If it made a couple hundred feet of climb a minute I would have been surprised. The B722 for me as an ATC was the worst climber ever, rating right up there with the BA11.
However, when inbound, the 727 was an approach-control-friendly plane...
tb727
Mon Feb 11, 2013 1:00 am
They eat up runway on takeoff, that's for sure. As far as that short of a ground roll, maybe 1500 with nosewheel brakes but those disappeared for the most part long ago. It will stop pretty quick and I am very impressed with the anti-skid braking on wet and snowy runways, best brakes I have flown so far in my career.
As far as the "crow bar arrival" or a steep descent, if you can see it in the window, you can land on it. The toughest thing to get in your mind at first is to get it as slow as you can then you can drop it, trying to make the field from 5-6000' and 10 miles at 250 knots isn't gonna happen. I like to throw the gear to slow down if I have to, I hate it when guys want to use flaps to slow.
Viscount724
Mon Feb 11, 2013 1:57 am
Quoting tb727 (Reply 11):
727s regularly operated from 5,000 ft. gravel (and often snow-covered) runways in the Canadian north for some years.
Pacific Western 721 combi here in the mid-1970s at Resolute Bay (YRB) at about 74 deg. N. Temperature probably around -40 (same in F and C) when that photo was taken.
Current weather:
http://www.weatheroffice.gc.ca/city/pages/nu-27_metric_e.html
http://www.pwareunion.com/images/aircraft/B727-YRB.jpg
Max Q
Mon Feb 11, 2013 8:12 am
Seven years on the B727 and I never had an issue with not having enough power on approach for bleed air /engine and or wing anti-ice.
Not an issue, using #2 to control speed with 1 and 3 at a stable setting was something I very rarely saw, I don't see a problem with it though.
There really isn't that much thrust asymmetry with the outboard engines.
You absolutely must be spooled up on approach by 1000agl, 500 at the very latest, having said that the spool up time
on those JT8D's was not slow at all, they come up pretty quick, a LOT quicker than the MD80 and many other bigger fans.
rwessel
Mon Feb 11, 2013 8:52 am
Quoting Max Q (Reply 13):
I think the point is that compared to the pistons that many 727 pilots had been flying earlier, the spool up time was *very* slow.
AA737-823
Mon Feb 11, 2013 8:55 am
Quoting LimaFoxTango (Reply 1):
That is utterly false.
The JT-8D maximum spool time from idle to target (varies by temperature, and can be found in several dozens of charts in the engine maintenance manual) is specified at 6 seconds. A healthy engine will do it in less than four.
On a CFM56? Good luck with that.
And engine with a larger diameter fan has greater rotational inertia than one with a smaller diameter fan.
Have you ever taxied a 737-NG? It's a wearisome experience, waiting on engines to spool up to get you across an active runway. For this reason, many pilots won't pull the engines back to idle, unless they anticipate sitting still for a while.
Max Q
Mon Feb 11, 2013 9:12 am
Quoting AA737-823 (Reply 15):
:31 your local time (15 minutes 18 secs ago) and read 7 times:
Well said.
b767
Mon Feb 11, 2013 5:12 pm
Seems to remember reading somwhere that Pratt and Whitney modified the JT8D to have a shorter spool up time as a resault of the early accidents.Is this correct?
rcair1
Crew
Mon Feb 11, 2013 10:22 pm
Quoting rwessel (Reply 14):
That is correct - the comparison to other jets is not the issue - it was compared to that big radial hanging out there.
rcair1
Pihero
Mon Feb 11, 2013 10:49 pm
Quoting rcair1 (Reply 18):
that's not the reason the 727 was difdferent from earlier prop types that used to fly and that the 727 replaced : The main difference pilots had to cope with was the immediate tift one got from the propwash over the wing : instant lift, lift that you could only get on a jet with increased speed.
Most of the times, those JT-8s were at 60 - 70% N2, so that spool-up to go-around RPM wasn't really an issue. (the main instrument is an EPR indicator that doesn't give one the rotation of the engine )
Thanks. It's eight seconds from idle. Did it for tyhe past eighteen years.
[Edited 2013-02-11 14:50:52]
Contrail designer
Max Q
Tue Feb 12, 2013 1:29 am
Quoting Pihero (Reply 19):
That's a very good point Pihero and well explained.
Another factor with the early high sink rate 727 accidents was the use of speed brakes with landing gear and flaps extended, this made for an extremely high sink rare and was later prohibited.
Pihero, did you fly the B727 ? best wishes.
Pihero
Tue Feb 12, 2013 10:39 am
Quoting Max Q (Reply 20):
Alas, no.
I had to make a choice between it and the DC-4. I chose the latter for I thought that was the last chance to fly a daddy's plane, thinking there would be other opportunities. I was wrong ... because when I had a command slot, the 320 was there and that time I made a choice for the newest technology.
A lot of my friends flew it and loved it but a pilot needed - needs - to be ten miles ahead of it : it had superb aerodynamics for its time but, as one of my classmates used to say : you fly in fact two airplanes : one with fighter performance when clean and one very draggy beast with flaps down in which you wouldn't want to be on the low side of the thrust/drag curve.
Contrail designer
rcair1
Crew
Tue Feb 12, 2013 2:25 pm
Doh. I knew that. Just forgot it (seems to come with age...) Thanks Pihero!
rcair1
rcair1
Crew
Tue Feb 12, 2013 2:26 pm
Quoting Pihero (Reply 21):
Very nicely said.
rcair1
Max Q
Tue Feb 12, 2013 11:25 pm
Alas, no.
Yes, it was a great Aircraft, it could be unforgiving as you say and you had to stay ahead of it but it was the most enjoyable aircraft I have flown.
but I do envy you flying the DC4. That must have been a very rewarding experience from a very different generation
Users browsing this forum: KAUSpilot, Raventech, Starlionblue and 1 guest
