smartt1982
Dirty Exhaust From Engines, Just Old?
Sat Feb 09, 2013 3:03 pm
Anytime I see some of the older jets take off e.g. older MD 80 series etc. I notice a fiar amount of what I would describe as a very smokey oily exhaust trail.
Now I realise that the aircraft and engines are probably not the newest but is this just the way the engines are, even with the necessary and required maintenance these older engines will allows produce more a s smokey oily exhaust trail?
Polot
RE: Dirty Exhaust From Engines, Just Old?
Sat Feb 09, 2013 3:50 pm
Quoting smartt1982 (Thread starter):
Yes- because the smokey trails stem from design, not maintenance. They just don't burn as cleanly as newer engine designs, and no amount of maintenance can fix that.
rcair1
Crew
Sat Feb 09, 2013 4:55 pm
It is amazing how we have changed. I remember I used to like those trails - but now they look very dirty.
rcair1
srbmod
Sat Feb 09, 2013 6:10 pm
Quoting Polot (Reply 1):
Case in point:
Photo © Charlie Atterbury
Early jet engines at times required water injection in order to product the needed thrust for takeoff. As technology improved, the need for water injection was lessened as engines were able to produce the necessary thrust without having to use water injection.
The MD-80s are really the last of the "smoky" airliners as the engine tech has improved even further. The engines on the MD-80 are updated versions of the same engine they used on the DC-9 as well as the 727 and the 737-100 and 737-200.
Sat Feb 09, 2013 6:48 pm
Amazing Improvement with regards to sound and pollution.
From the turbojet age to the low bybass turbofan to the current high bypass turbofan.
fuelfool
Sat Feb 09, 2013 9:39 pm
Between the nasty exhaust of the huffer and the engines on the DC8, I used to feel like I could feel cancer cells forming in my body every time we fired one up.
I love the smell of jet fuel in the morning...Smells like victory!
jetstar
Mon Feb 11, 2013 9:30 pm
The black smoke you see coming from the exhaust of jet engines in carbon. One of the effects of these carbon particles was erosion of the turbine blades. The jet engine manufacturers redesigned the combustion chambers to burn up the carbon internally instead of it coming out of the exhaust and this basically eliminated exhaust blade erosion.
Many years ago when I was working on the turboprop Grumman Gulfstream 1, the RR Dart engines would build up a clump of carbon within the combustion chamber and when it grew large enough, it would let go and come out the exhaust pipe, you would see these on takeoff as a puff of black smoke. I believe the term RR used was clingers and it was causing erosion problems on the turbine blades, RR redesigned the combustion chamber and it solved the problem.
When I was flying the JetStar and ATC called out traffic and if the visibility was clear enough you could spot the airplane by the black smoke, especially if they were climbing out on takeoff.
It was in the late 1970’s or so when due to FAA, I believe under pressure from the EPA the engine manufacturers redesigned the combustion chambers and they had to be installed whenever the engine was overhauled.
JetStar
Aaron747
Tue Feb 12, 2013 4:17 am
Gotta love it. There just isn't enough smoke these days. For awhile longer we can enjoy these over on this side of the Pacific:
Photo © Ryotaro Shinozaki
bluejuice
Wed Feb 13, 2013 6:53 am
KELPkid
Wed Feb 13, 2013 7:05 am
Under certain conditions, the IAE V2500 gives off a little bit of smoke trail, guess it is the Pratt & Whitney heritage of the combustor showing through
LH707330
Thu Feb 14, 2013 6:14 am
Quoting KELPkid (Reply 9):
Often that's due to dirt in the combustor, I've seen CFM56s and other new engines do this as well.
bhill
Thu Feb 14, 2013 7:14 pm
Wow....wonder if pilots had to change regimes from VFR to IFR being behind a few of those birds after takeoff....
Carpe Pices
Users browsing this forum: boeing767322er and 1 guest
