peh
Questions Re: Squawk 7600
Mon Feb 11, 2013 2:54 am
QFA93 just squawked 7600 (radio/communication failure) and then disappeared from the screen.
Q1) Is it possible that the communication failure related to the transponder and that's why the plane is no longer visible?
Q2) What's the procedure following a 7600 squawk? Does the plane have to make an immediate landing or can it continue to its destination?
Thanks in advance for the info!
Flown: ATR72, DASH 8, 737, 747, 767, 777, A300, A320, A321, A330, A340, MD80
wilco737
RE: Questions Re: Squawk 7600
Mon Feb 11, 2013 10:18 am
Quoting peh (Thread starter):
The official procedure is generally spoken: Continue on your flight plan to your destination and follow the flight plan as closely as possible.
But if this would be done in real life is another question. I am not sure if I want to fly from FRA to the US without a clearance for the NAT or flying eastbound over Afganistan, Iran, Iraq without entry clearance...
wilco737
jgarrido
Mon Feb 11, 2013 11:19 am
If i were to guess I would say that the comm failure is possibly part of a larger problem, electric/electronic in nature, which caused the transponder to stop operating.
CosmicCruiser
Mon Feb 11, 2013 1:31 pm
most airliners have 2 transponders
Mon Feb 11, 2013 3:50 pm
Quoting wilco737 (Reply 1):
IFR rules in the US are as follows.
Altitude should be the highest of:
- Assigned Altitude
- Expected Altitude
- Minimum Enroute/Safe Altitude
Route in descending order of priority:
- Assigned
- Vectored
- Expected
- Filed
Leaving the clearance limit:
- Plan to leave the clearance limit of the IAF at the time in your flight plan.
- If you arrive at the clearance limit before then, hold there until that expected arrival time.
As you say. In ALL cases, make decisions in accordance with safety, as that is your primary concern. The rules don't absolve you from using your brain to make sound decisions.
KELPkid
Mon Feb 11, 2013 4:39 pm
Quoting Starlionblue (Reply 4):
Exactly. If I ever found myself in a lost comms situation, and if I encountered decent VFR conditions, I would probably just land at an uncontrolled field (one with decent repair facilities) and phone the Flight Service Station to report being safely down and to cancel IFR
NWADC9
Mon Feb 11, 2013 5:21 pm
If VFR: Remain VFR and land as soon as practical.
If IFR: The MEA AVEF rule applies as mentioned earlier.
I convert Jet A and 100LL into noise.
113312
Wed Feb 13, 2013 8:11 pm
You said that the flight disappeared from the screen; which screen? Flightaware, ATC display? Different sources drive different displays with respect to ATC or publicly available internet sources. Internet tracking usually involves a feed from an ATC that might be based on transponders or ADS sources. ATC can also filter what is fed out to internet sources.
This original post does not provide sufficient information to give an accurate answer.
Mir
Thu Feb 14, 2013 12:48 am
A good summary, but you forgot the first one: if you're in VMC, continue the flight under VFR and land as soon as practical.
Since you're rarely going to be in IMC for an entire flight, that's likely going to apply to you at some point.
-Mir
Thu Feb 14, 2013 1:07 am
Quoting Mir (Reply 8):
Fair point. I guess I took it for granted. Big grin
[Edited 2013-02-13 17:08:44]
SPREE34
Thu Feb 14, 2013 4:54 am
Quoting 113312 (Reply 7):
^^^^^This.
I don't understand everything I don't know about this.
Mir
Thu Feb 14, 2013 5:51 am
You wouldn't be the first. When I was helping people prepare for their instrument checkrides, I'd ask them what would happen if their radio failed and 90% of them went straight to what course they'd fly, what altitude they'd fly, etc. Which is all well and good, but if you start going through all that when it's severe clear outside, you're missing the forest for the trees.
-Mir
Thu Feb 14, 2013 8:34 am
Quoting Mir (Reply 11):
Thankfully my examiner didn't ask me then! She was focused more on things like tailplane icing on approach-  Wow!
Pihero
Thu Feb 14, 2013 12:42 pm
Nice discussion.
A modern airliner is equipped with
- 3 VHF sets
- 1 ACARS
- 1 SatCom
- 2 transponders
If a long haul airliner, it will have furthermore
- 2 HF sets
all on different buses.
So, a complete radio failure is sometrhing which is at the very least very remote... so that if it happened, you'd have a lot more on your hand than just lack of communications : In this respect, the first item of the loss of communication procedure, after A7600, is to establish a two-way link with someone with all the means available... then, and only then, we'd start following the official loss of com procedures... which vary from one place to another, one flight condition to another, one area to another... all are published in the local AIP.
Contrail designer
jbcarioca
Tue Feb 26, 2013 4:06 pm
Seems very likely that a modern airliner encountering a total communications failure probably would be inclined to squawk 7700 rather than 7600 because there would be many, many things going very wrong. 7600 can easily happen with small aircraft that do not have backup systems but that would be vanishingly rare in a modern airliner.
PITrules
Sun Mar 03, 2013 2:12 pm
From an ATC perspective, they have no idea when a flight may encounter VMC conditions. There is expectation bias on their part as to what the flight will do. An IFR flight starting a 360 spiral just to stay VMC at a moments notice might not be the best idea. I have met many controllers who said they would just prefer a flight continue on its flight planned (and expected) route. They have the route cleared to destination.
Quoting Starlionblue (Reply 12):
Thankfully, your examiner has a big picture, and focused on things which are really critical to safety.
[Edited 2013-03-03 06:21:28]
FLYi
atct
Sun Mar 03, 2013 9:24 pm
Usually when an airliner goes nordo, its just for a few minutes. Due to somebody bumping a switch, headset unplugged, etc. I cant think of the last time someone went nordo for more than 10 minutes. (Except those guys in Hawaii and Northwest at MSP...different circumstance).
If you were using a third party software to see the flight, it probably disappeared because its transponder code switched to a non-discreet code that it didnt recognize. On my scope, if someone squawks 7600, a little red "RF" appears above their tag and an audible alarm goes off. The tag still shows the previous code's information, but im not using third party software
atct
Trikes are for kids!
