ecbomberman
Airbus Door Question
Sat Feb 16, 2013 5:27 am
Copied a discussion thread from the Civil Aviation forum with guys who seem to prefer to discuss the quality of journalism rather than the actual incident.
Emirates A380 Slow Cabin Decompression (by ek433 Feb 15 2013 in Civil Aviation)
AND the Daily Mail link:
http://www.dailymail.co.uk/news/arti...gged-gap-blankets-says-Briton.html
Just by looking at the picture....
What does the green indicator really mean? Does it mean the locking mechanism is off? I understand that the door would not open in mid-air due to pressure diff. but will it open when someone pushes the door?
Apparently there is a gap at the bottom of the door. Does that mean that the door has 'partially failed'? I.e.: The lower bit of the door has actually left the frame?
Many thanks for any input
VS343/346/744 CX744/L1101/343 MH332/333/733 BD32x/EMB 145 AK320 SQ310/77E/773/744 UA747SP/744 BA744 BI763ER/319 QF763ER
Pihero
RE: Airbus Door Question
Sat Feb 16, 2013 1:16 pm
Quoting ecbomberman (Thread starter):
It's an attention getter for the cabin crew : mainly for crew intercommunications and for emergency. Green means everything is OK... The name is AIP for "attendent information panel".
See above.
Let's put things in perspective : differential pressure will push the door to its cushions, even if the locking mechanism is off.
Considering that the door dimensions are some 84 by 50 inches and considering that the differential pressure is around 8 psi, 84 x 50 x 8 = 33,600 lbs ; That's the force applied on the door... some 15 tons... if you push, you add your weight to that force...
There is always a gap at the bottom of the door to allow it to get into the fuselage before it is forced to "unfold" into its seat. That gap is, for cosmetic reasons, covered by souple plastic.
There are ruber-compound seals, though, and one is probably leaking, making a sort of shuddering whistling noise, which can be rather loud. The cushions and blankets have been used by the cabin crew to partly mask that noise.
Much ado about nothing, or as we say in French :" beaucoup de bruit pour rien."
[Edited 2013-02-16 05:22:10]
[Edited 2013-02-16 05:27:14]
Contrail designer
Tristarsteve
Sat Feb 16, 2013 5:47 pm
When you close an Airbus door, the final movement is that the whole door lowers about 2 cm, and the seal at the bottom of the dor pushes against the door sill. Sometimes there is rubbish left here, maybe a swizzle stick or a stone from a passengers shoe. Then there can be a deformation of the seal, and some air can leak out of the cabin. As the hole is usually very small, the air will whistle as it leaves, and it can get very noisy. Pushing blankets up against the door can help. It is quite a common occurence.
soon7x7
Sun Feb 17, 2013 1:20 pm
WN takes paper towels and wets them into a globular matrix and rams it in the offending noisy area...fixed!...now can have my reduced size bag of peanuts?
VC-10
Tue Mar 05, 2013 12:11 am
Quoting soon7x7 (Reply 3):
or Tampons!
http://www.vc10.net/Memories/testing_earlydays.html#VIPTampax
Tue Mar 05, 2013 2:15 am
While I can understand her reaction, the F/A reacted in EXACTLY the wrong way. Ouch... And shouldn't flight attendants know about plug doors?
Quoting Pihero (Reply 1):
Apparently quite a bit of "bruit" then.
You have to admit the journalism is classic Daily Mail though.  Some of the comments are priceless as well.
[Edited 2013-03-04 18:19:30]
ecbomberman
Tue Mar 05, 2013 2:26 am
Quoting Starlionblue (Reply 5):
I enjoy it as well from time to time... Hence I usually read more 'up class' non-tabloid newspaper whenever possible
strfyr51
Tue Mar 05, 2013 4:06 am
I can assure you. The Door didn't come open. The Lower door seal blew out and that can happen if moisture freezes on the door sill or there's foreign object damage to the lower door seal. Had that door come open the seats ar the right of that picture would have departed the airplane and NO amount of tape would have covered it up. Trust me on this.
The passengers were in no danger. The repair once parts were available would be 6-12 hours
Users browsing this forum: KanaHawaii, Starlionblue and 1 guest
