EIPremier
SEA Deicing Question
Mon Feb 18, 2013 12:03 am
Hey,
Just observed something at SEA today which struck me as curious, and was wondering if the tech/ops community had any insight. I was waiting at the C concourse around 11 am today (2/17), and I saw two planes being deiced at the gate prior to pushback. One was a 739 going to SJD and the other was a 738 going to GEG. The odd thing was both aircraft had come in from other cities, so they weren't RON aircraft. Furthermore, the outside temp was way above freezing (44 deg F according to wunderground), and the cloud deck was low, but no precip since the prev evening. Not that I'm questioning their decision to de-ice, but I just couldn't really figure out why it was needed. Anyone have any insight?
Okie
RE: SEA Deicing Question
Mon Feb 18, 2013 12:43 am
Quoting EIPremier (Thread starter):
There is your clue. They flew in from an altitude that was -44F and had cold soaked the plane, wings in particular.
With thousands of pounds of Aluminum and Fuel cold soaked to -44F then when sitting on the ramp the wing started to form frost.
I can not count the times that I have waited for de-icing on an aircraft but I would say 70% of the time was in conditions that you mentioned 40-45F and humid, night or cloudy.
Okie
roseflyer
Mon Feb 18, 2013 3:12 am
The airplane is extremely cold when landing. When there is high humidity, moisture condenses on the plane and then freezes which foreces the plane to deice.
mrcazzy
Mon Feb 18, 2013 3:56 pm
agree with okie, when flying at high altitudes it is considerably colder than on the ground, if there were any precip, clouds at those altitudes there could easily be freezing
