SXDFC
ATR-72-600 Freighter?
Tue Apr 02, 2013 12:06 am
Hello All:
I am curious as to if its possible for ATR to offer the ATR-72-600 as a freighter? Would this A/C make for a better freighter vs the smaller ATR-42 and ATR-72-200 do to its longer size?
LimaFoxTango
RE: ATR-72-600 Freighter?
Tue Apr 02, 2013 1:24 am
The ATR 72-600 has the same fuselage length as the 72-200/500. The only difference the 72-600 has over previous versions is a higher MTOW and a glass cockpit. But to answer your question, I'm sure ATR does offer a freighter version. Not sure why one would want to buy a 600 just for cargo as there are many 200's/500's on the market for far less.
You are said to be a good pilot when your take-off's equal your landings.
SCAT15F
Tue Apr 02, 2013 5:25 am
Too small to be cost effective...
A400M based freighter? maybe.
AA737-823
Tue Apr 02, 2013 7:42 am
Quoting SCAT15F (Reply 2):
Really? Have you told that to FedEx Feeder carriers, which fly a fleet of Cessna 206 and ATR-42 aircraft?
Both those birds are smaller than the ATR-72 in question in this discussion...
Quoting LimaFoxTango (Reply 1):
I think that higher weight might just make the plane an attractive option. Attractive enough to buy new-build freighters? I don't know.
Tue Apr 02, 2013 11:04 am
When an ATR72-200 or -500 can be freighter converted at a cheaper rate.....why go in for a -600 freighter.
citationjet
Tue Apr 02, 2013 11:57 am
Quoting AA737-823 (Reply 3):
I think you mean 208 Caravans, not Cessna 206 ....
Photo © David Lednicer
Photo © Anna Sushkova
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
Viscount724
Tue Apr 02, 2013 9:23 pm
Not in certain parts of the world, such as this ATR-72-200 operating to many remote airports in Canada's arctic region.
Photo © Jason Pineau Photography
Same aircraft with original operator.
Photo © Frank C. Duarte Jr.
SXDFC
Wed Apr 03, 2013 12:54 am
Quoting HAWK21M (Reply 4):
I was always thought the -600 had a longer fuselage vs the older/ shorter -200s and -500s..
Could a cargo carrier use a CASA 295 as a freighter?
Polot
Wed Apr 03, 2013 1:36 am
Quoting SXDFC (Reply 7):
Nope, same fuselage
Waaaayyyy to expensive to buy and operate.
r2rho
Thu Apr 04, 2013 11:47 am
Exactly. While there is nothing really in the way of making a -600 freighter, there is a large used market for the older versions which make good freighter candidates, not absolutely no hurry for ATR to offer a -600F for the time being.
Nothing against that either, but the problem is that it is designed as a military cargo aircraft and therefore carries a lot of structural weight unneeded for civil ops (heavy landing gear for rough field ops, cargo ramp, etc). Unless you really need the cargo bay volume or the loading ramp, there is no reason for a civil operator to use it, and AFAIK no-one does. Same goes for its smaller brother the CN-235 (which did manage to have a very short life as an airliner however). But IIRC there are some civilian-use C-212 out there.
atct
Fri Apr 05, 2013 3:07 pm
Lots of C206's flown up here on cargo runs...just not for FedEx.
Id have the agree with HAWK21 that there are plenty of low time 200 and 500's floating around that can be converted to prevent a current push for -600 freighters.
atct
Trikes are for kids!
Users browsing this forum: gloom, masi1157, trav110 and 2 guests
