mpdpilot
Hijacking Aircraft Computer Systems, Possible?
Thu Apr 11, 2013 1:24 pm
I found this article today, and I admit, I am a bit skeptical. With that in mind I am no expert on the matter and am curious what others think.
The article talks about how someone could hijack on board computer systems and take control of an airliner. It mentions that control could even be given to an app on an android phone. Read on to hear more about the details.
Hijacking Aircraft with an Android phone
One mile of highway gets you one mile, one mile of runway gets you anywhere.
bueb0g
RE: Hijacking Aircraft Computer Systems, Possible?
Thu Apr 11, 2013 3:40 pm
Possible, I guess... But screw around all you want with the FMS/ancilliary systems, the pilots can just turn the AP off and land at the nearest airport...
Roger roger, what's our vector, victor?
chuchoteur
Thu Apr 11, 2013 7:47 pm
he may have used bits of actual hardware, but on the software side he used a pc simulated environment, which isn't the same as an actual architecture. He got ripped to bits in other articles (on Forbes in particular) where he admitted that an actual architecture has added features that means his mode of hacking wouldn't work.
He's plugging a software tool he developed that scans code lines for vulnerabilities. It may be a good product, but I doubt that going on stage with a presentation like that will impress a lot of people in the security industry....
http://www.forbes.com/sites/andygree...s-in-airplanes-navigation-systems/
[Edited 2013-04-11 12:49:57]
KELPkid
Thu Apr 11, 2013 7:57 pm
The flaws I see here:
Sure, if you built a (highly illegal) transmitter, you *could* broadcast your own ADS-B misinformation. However, both the guys in the pointy end of the bird and the guys at the TRACON have good old fashioned technology that will reveal the truth about what's going on. And as long as the aircraft is in VMC, a quick peek out the cockpit windows can help sort out misinformation. As long as VHF voice communications exist, it is relatively easy to know the truth
I wasn't aware that ACARS could transmit messages to the FMS to cause alerts to go off? I thought ACARS was mostly for the aircraft self-reporting data back to the airline (like flight progress and equipment malfunctions)...I could see it used for things like automatically loading a flight plan from dispatch and transmitting that same flight plan to ATC...
flyingturtle
Thu Apr 11, 2013 10:19 pm
http://www.scifiworld.es/imagenes/fotos/14439747_CRM114_01.jpg
Airlines routinely encrypt such ACARS messages in order not to give the competitors any hints about enroute weather, fuel consumption and such things.
IMHO, this thing could be easily patched, for example by technique called one-time pad. At the briefing, the captain is given a slip of paper with a handful of codes on it, while the dispatcher keeps an identical slip. And then, messages will only be trusted and loaded into the FMS if the message contains one of the codes on the slip.
Not hackable in any way, except somebody knows how to cheat sheer luck - or steals the slip.
David
Thu Apr 11, 2013 11:32 pm
Quoting flyingturtle (Reply 4):
Paper? This is not the Napoleonic era.  Nowadays, one time pads are more easily implemented with electronic tokens that rotate codes.
rcair1
Crew
Fri Apr 12, 2013 12:01 am
Would the plane have the auto destruct button like the radio?
rcair1
roseflyer
Fri Apr 12, 2013 2:00 am
I don't quite understand what he is trying to do. He can hack into two transmitting functions of the airplane. Yes he can get transmitted messages such as acars, and then the flight parameters transmitted, but other than knowing where and what the p,and is doing, how does that help hijack an airplane. If he got into ARINC then he could do damage, but I am not sure what can be do e with ACARS.
rwessel
Fri Apr 12, 2013 6:34 am
And after the captain exchanges a handful of short messages with the dispatcher, and uses all of the OTP, what then? Can't talk anymore?
Quoting Starlionblue (Reply 5):
A security token is nothing at all like an OTP.
Fri Apr 12, 2013 6:47 am
Quoting rwessel (Reply 8):
The authentication principle is the same, exactly like a paper OTP since a security token generates One Time Pads. In printed form you choose the correct code as requested by the party you wish to authenticate with. Security tokens come in various guises but for the simple one in the picture a new code is generated at set intervals. The server end knows the code that will be generated on the token at the time of authentication and can thus verify that the user has the correct token. This is know as a "time-synchronized OTP".
[Edited 2013-04-11 23:48:22]
[Edited 2013-04-11 23:48:56]
[Edited 2013-04-11 23:51:19]
flyingturtle
Fri Apr 12, 2013 8:43 am
Quoting rcair1 (Reply 6):
Of course. We're talking about modern aviation.
Depends on how many critical messages have to exchanged - they're not in the range of ten or twenty per flight. Basically, there are zero critical messages because the crew can always ask on HF or satellite phone for a confirmation if the new routing is dubious. And ATC will ask anyway when the routing looks strange.
But the principle stands that OTP is an extremely simple method to defeat such hacking attempts.
David
Fri Apr 12, 2013 8:51 am
Quoting flyingturtle (Reply 10):
Indeed, and since it can be integrated into the systems it can be made completely transparent to the user.
With electronic authentication, there is no limitation in practice.
Also:
[Edited 2013-04-12 01:53:15]
MD11Engineer
Fri Apr 12, 2013 9:02 am
Actually many airlines don´t worry too much about the competition getting those messages, but about pimply spotters or the press receiving ACARS messages and publishing them out of context.
The picture shows an old military IFF transponder. These things often contained selfdestruct charges, which would explode or burn oif somebody unauthorised opened the housing to destroy critical compenents responsible for coding. The charge could also be activated by the pilot if he was forced to land or crash in enemy territory.
Jan
airmagnac
Fri Apr 12, 2013 9:40 am
Quoting MD11Engineer (Reply 12):
Actually, I believe it's a CRM-114, or How I learned to stop worrying and love communication systems
My goal as an engineer is to fill my soul with coffee and become immortal
flyingturtle
Fri Apr 12, 2013 10:52 am
It's not an IFF transponder. Though very credible, it was invented for a certain film airmagnac is referring to. In that Cold War satire, one central topic is how to authenticate messages sent to B-52 bombers. If somebody could fake them, one could start the end of the world with the push of a button.
Wikipedia:
"Lacking cooperation from the Pentagon in the making of the film, the set designers reconstructed the aircraft cockpit to the best of their ability by comparing the cockpit of a B-29 Superfortress and a single photograph of the cockpit of a B-52, and relating this to the geometry of the B-52's fuselage. The B-52 was state-of-the-art in the 1960s, and its cockpit was off-limits to the film crew. When some United States Air Force personnel were invited to view the reconstructed B-52 cockpit, they said that "it was absolutely correct, even to the little black box which was the CRM." It was so accurate that Kubrick was concerned whether Ken Adam's production design team had done all of their research legally, fearing a possible investigation by the FBI."
Are any B-52 air crew around here? I might have a few questions concerning this very thread.
David
rwessel
Sun Apr 14, 2013 7:36 am
The use of an uncommon acronym (outside of marketing) and an the incorrect definition for the acronym (although the correct definition for the *common* use of the acronym), threw me.
Almost always, an OTP is a One Time *Pad*, which is a special type of cipher which has the interesting property that it's provably secure. It also has certain disadvantages, namely that no key material can ever be reused, all bits of the key are fully independent, and that the key has to be as long as the messaged being encoded. And in general authentication requires something in addition to the OTP.
A One Time *Password* is something rather different, and nobody technical in the industry uses the acronym OTP for that, since it has a much more common definition. marketing departments go their own way, however. Probably the (false) association with the unbreakable one-time-pad is "good" thing for marketing. In any event, while the traditional paper based one-time-password, when combined with fully independent passwords and no password reuse can manage a few of the same properties, although authentication is still probabilistic. Nor does any electronic security token implement the "fully independent" criteria (one could, by simply storing a large about of properly generated key material, and then emitting it a bit at a time, but I know of none that do - all of the ones out there are based on a cryptographically secure pseudo random number generator of some sort). Nor does a security token generate anything that could be remotely considered a one-time-*pad*.
A security token plus a password can provide a reasonable level of security, although passwords are compromised constantly (should this become common practice I guarantee we'll see passwords on a post-it on the panels of half the airliners out there), and several of the security tokens have been broken as well.
But yes, a password, plus a token, plus some certificate based authentication, if done properly, should be adequate. OTOH, given the dismal record of security on SCADA and similar systems, I'm not holding my breath for the "done properly" part.
At the end of the day, there are no authentication protocols that *prove* identity, although you can make it arbitrarily hard (or improbably) to fake an identity.
MD11Engineer
Sun Apr 14, 2013 8:19 pm
Quoting flyingturtle (Reply 14):
Wikipedia:
David
My mistake. I worked on a T-33 and still have the manuals around. There the old maintenance manuals from the 1950s warned the mechanics from working on the IFF unless certain procedures have been carried out to prevent the selfdestruct charge in the IFF encoder from firing. E.g. the guys were not allowed to open the box.
Jan
[Edited 2013-04-14 13:22:46]
flyingturtle
Mon Apr 15, 2013 9:02 am
Quoting MD11Engineer (Reply 16):
No problem, Sir.
The T-33 is my favourite aircraft in FlightGear.
David
Users browsing this forum: iuwnaa and 1 guest
