1337Delta764
Cockpits With A Step Up Or Down From The Door
Fri Apr 12, 2013 4:36 am
I wonder, what particular aircraft types have a step up or down from the cockpit door? I know the 757 has a step down, while the 767, DC-10, MD-11, and ERJ-135/140/145 have a step up. The 717, 737, 747, A320 family, DC-9, MD-80/90, and CRJ family do not have a step.
So, what about the 707, 727, 777, 787, A300, A310, A330, A340, A380, L-1011, DC-8, and E-jets?
[Edited 2013-04-11 21:38:08]
RE: Cockpits With A Step Up Or Down From The Door
Fri Apr 12, 2013 5:02 am
A380 has both, as it is between the main decks.
MANfan
Fri Apr 12, 2013 11:44 am
No step on the L1011 TriStar, but plenty of "mushrooms" to trip over !
As the 707, 727 and 737 shared a common fuselage, I'd suggest neither the 707 or 727 had a step.
[Edited 2013-04-12 04:46:51]
Fri Apr 12, 2013 11:58 am
Quoting MANfan (Reply 2):
If memory serves they shared a common cross-section and upper lobe, but the lower lobe was not common.
[Edited 2013-04-12 04:58:59]
DarkSnowyNight
Fri Apr 12, 2013 12:53 pm
The 777 has a step up, but not a very big one. In fact, it's small enough that it's easy to forget it's there the 1st few times and often gets stumbled on on the way out of the flight deck.
Quoting Starlionblue (Reply 1):
I certainly see what you're saying, but I don't often approach from the upper deck, so it's always been four steps up for me. Although, can we really count that since the steps also lead to the pilot's lav and crew rest (at least on CZ) first, and eventually then to the flight deck...
Much like a GE90, I'm a huge fan of Big Twins...
DashTrash
Fri Apr 12, 2013 2:02 pm
Dash 8 has a step up.
longhauler
Fri Apr 12, 2013 2:03 pm
The E170-195 have a step up.
LH707330
Sat Apr 13, 2013 6:17 pm
IIRC the 757 and 767 steps were put in place so they could share a similar cockpit geometry for the cross-rating. As to the 707, it was straight in (I'm building a model of one) like the 727/737. Starlionblue is right, the lower lobe on the 707 is about a foot deeper than on the 727 and 737. I also think the 757 has a different lower lobe, but I'm not exactly sure about the size difference.
TUNisia
Sun Apr 14, 2013 2:23 am
The Shorts 330 & Shorts 360 series of commuter aircraft.
Sun Apr 14, 2013 4:03 am
Quoting TUNisia (Reply 8):
And a horrible little jump seat.
tb727
Sun Apr 14, 2013 6:27 pm
Quoting 1337Delta764 (Thread starter):
The 727 has like 1"-1.5" step, not much.
deltal1011man
Sun Apr 14, 2013 10:17 pm
727
maybe a little bump but IIRC it was pretty much straight in ie the 737
777
little bit of a step up i think it is.
A330
IIRC straight in. Have only been in the cockpit like twice
L-1011
no step
I don't understand why this site even has moderators anymore.
jetmatt777
Crew
Sun Apr 14, 2013 11:58 pm
E135/145 have a step-up. Around 10 inches.
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
1337Delta764
Mon Apr 15, 2013 5:21 am
Quoting Deltal1011man (Reply 11):
The same probably goes for the A340 as well.
737tdi
Tue Apr 16, 2013 4:56 am
DC8 has a small step down, at least the 60 and 70 series. Those are the two types I worked years ago.
Users browsing this forum: 747classic, B6JFKH81, dassal, FGITD, Google Adsense [Bot] and 1 guest
