celestar
B737-700 Series Tail Shape
Fri Apr 12, 2013 8:26 am
Boeing has done a great job at stretching the basic design of B737.
I was looking at the latest 737 family that are currently in service, the B737-800 and 900 series look proportionally correct, however, when I look at the -700 or -500 series, I can't help but think how disproportionally big the tail fin is! It looks way too big for the size of the fuselage. If you look at the AIRBUS A320 family, from A318/319/320/321, at least to the nake eyes, the tail fin is roughly about the same size, given the different length of the fuselarge. Question, why B737-500/700 series have such a large tail? Isn't that induces drag? Is there a reason, aside from commonality of parts (which I find that to be difficult to believe), that the tail fin has to be that big? I do see on the 747-SP tail vs regular 747-300/200/100, it is bigger in size, not to mention the SP has a different wing. Please shed some light. Thanks all.
travelavnut
RE: B737-700 Series Tail Shape
Fri Apr 12, 2013 8:35 am
Because of the short fuselage the tail fin has less authority, that's why it has to be bigger on shorter aircraft, especially in an engine-out scenario.
Live From Amsterdam!
Fri Apr 12, 2013 9:01 am
As travelavnut says.
For a similar reason the 330-200/300 has a taller fin than the 340-200/300. It's all about engine out rudder authority.
Quoting celestar (Thread starter):
The 318 has a tail that is 76cm taller than the 319 and 80cm taller than the 320/321.
If memory serves, the wing is the same apart from simpler flaps.
Polot
Fri Apr 12, 2013 3:29 pm
I thought the tail on the -700 was the same as the -800/900 (not sure about the -500 vs the rest of the classics or the -600). It just look larger because the fuselage is proportionally shorter (unlike the A318, which actually has a larger tail then the rest of its family).
AA737-823
Fri Apr 12, 2013 9:21 pm
Quoting Polot (Reply 3):
Indeed it is.
But it can't be made smaller than the -8/-9, because of the decreased moment arm on the shorter airplanes.
Viscount724
Fri Apr 12, 2013 11:02 pm
The size of the vertical stabilizer on all 737NG models from the -600 to the -900 is identical. If memory correct it's about 5 feet taller than on the classic models.
[Edited 2013-04-12 16:06:46]
Sat Apr 13, 2013 10:56 am
Isn't that a fact.......All were part of the B737NG series.I thought they were all the same.
LH707330
Sat Apr 13, 2013 6:35 pm
Quoting Starlionblue (Reply 2):
The 330/340s have 3 fins:
Short fin: 343, 333, 342
Tall fin: early 332
Medium height/longer chord fin: 345, 346, later 332s
I thought the 319/320/321 are all the same, the 318 being the oddball. Are you sure you're not quoting ground clearance?
Viscount724
Sat Apr 13, 2013 10:20 pm
Quoting LH707330 (Reply 7):
As far as I know the vertical stabilizers on the 319/320/321 are identical.
Sun Apr 14, 2013 1:08 am
I stand corrected. I just read height from the a.nut info pages so obviously ground clearance counts.
Users browsing this forum: Bing [Bot], jetblueguy22, netbucks, sambenedettese and 1 guest
