Tod
A330 Cargo Linings
Fri Apr 12, 2013 2:03 pm
Anybody know of any used A330 cargo linings for sale?
Preferably in the USA, but open to other ideas too.
I need one for some urgent flammibility testing.
Tod
airportugal310
RE: A330 Cargo Linings
Sun Apr 14, 2013 4:29 am
Wouldn't the manufacturer(s) of these already have that data?
I sell airplanes and airplane accessories
Wed Apr 17, 2013 8:36 am
I guess tod wants to use it on something else and needs to test it when installed.
bikerthai
Wed Apr 17, 2013 6:36 pm
If you know what material the cargo liners are made off, you can get a samples from the supplier.
Typically the cargo liner is a glass reinforced phenolic or polyester sheet (various thickness).
One supplier is M.C. Gill corporation. They may be able to give you some small samples 38 cm X 38 cm (approx).
Otherwise, they come in large sheets.
bt
[Edited 2013-04-17 11:36:57]
Tod
Sun Apr 21, 2013 2:41 am
Quoting airportugal310 (Reply 1):
Airbus will not let them share the data.
Tod
Sun Apr 21, 2013 2:48 am
Quoting HAWK21M (Reply 2):
Actually its an A330-200
Quoting bikerthai (Reply 3):
Correct and since the construction is Airbus proprietary, they are only allowed to sell it by Airbus part number.
We got two panels on order, but since there are lead time issues I was hoping to find some identical contruction on the used market.
Getting an FAA STC on an Airbus aircraft can be significantly different that a Boeing aircraft.
