JAGflyer
Protrusion On A330 Freighter
Fri Apr 12, 2013 9:51 pm
Can anyone tell me what the small hump around the nose gear bay is for?
Photo © Dn280
Photo © John Richard Thomson
Support the beer and soda can industry, your recycle old airplanes!
beiaard
RE: Protrusion On A330 Freighter
Fri Apr 12, 2013 9:56 pm
If I recall, the NLG was lengthened on the A330 freighter, and the bump was needed to facilitate the retraction of the longer strut.
BONARUM ARTIUM RERUMQUE HUMANARUM AC DIVINARUM STUDIOSOS CONVOCAMUS
Polot
Fri Apr 12, 2013 9:59 pm
I can remembered if the NLG was lengthened or just mounted lower- but it is one of those. And to answer the inevitable question as to why: It is so the plane has a flat loading floor on the ground to make loading cargo easier (if you look at pax A332s on the ground you can see it has a nose down pitch).
oly720man
Fri Apr 12, 2013 10:06 pm
Quoting Polot (Reply 2):
mounted lower so the undercarriage leg was the same as on the pax versions to maintain commonality
http://www.flightglobal.com/news/art...loor-to-ease-cargo-loading-211629/
flyingturtle
Fri Apr 12, 2013 10:21 pm
Polot is right.
The pax version has a shorter nose gear - why? It saves weight. The passengers do not care if the aircraft is tilted forward by some 1 or 2 degrees.
But the freight version has some issues with pallets if the aircraft isn't exactly level.
David
Users browsing this forum: Yahoo [Bot] and 2 guests
