Breather Port - RB211-535E4
Sat Apr 13, 2013 10:04 am
http://sphotos-d.ak.fbcdn.net/hphotos-ak-prn1/625577_10152762728955301_1669343527_n.jpg
The Breather port on the RR RB211-535E4 of the B752 has got small vortex generators on the lower end on either side and the bottom..
Anyone having any more data on this.
CCA
RE: Breather Port - RB211-535E4
Sat Apr 13, 2013 1:49 pm
I'd guess it causes a swirling motion to keep the oil mist off the cowling, the drain mast alone doesn't do the job adequately.
P1 in A330, A340, A346, B742, B744, B748.
oly720man
Sat Apr 13, 2013 2:19 pm
I'm inclined to say that the vgs are to generate a "layer" in the flow to stop the ejected flow from the mast from smearing along the nacelle. I can't imagine any aerodynamic reason related to the mast itself.
As for the perpendicular tab, it may just be to guide the flow.
Wed Apr 17, 2013 8:29 am
Makes sense....Anyone aware of the earlier breather ports not having these VGs and there after getting fitted on.
NDWDCPGUY
Thu Apr 18, 2013 12:07 am
Initially there was no vane. The oil/air mixture exited from a flush mounted grille on the cowl. Many of these cowls are still in use.
Thu Apr 18, 2013 10:33 am
Quoting NDWDCPGUY (Reply 4):
Do you have a reference to the concerned SB.
boeingfixer
Thu Apr 18, 2013 3:00 pm
Quoting HAWK21M (Reply 5):
The Rolls Royce SB is RB.211-71-9088 dated 17 Dec 93.
Quoting HAWK21M (Reply 3):
As NDWDCPGUY said, the original breather was a flush louver on the cowl panel. The SB introduced the extended breather mast to keep the oil streaking on the fan cowl to a minimum. The small vanes on this new mast have been there since day one.
John
Cheers, John YYC
Sat Apr 20, 2013 1:15 pm
Quoting boeingfixer (Reply 6):
Thanks...I'll check it out....
Users browsing this forum: bruno100300, JJV and 2 guests
