LH707330
Engine Placement Along Wing On Quads
Sat Apr 13, 2013 7:15 pm
I've noticed quite a lot of variation in engine placements along the wing (how far outboard) on quad-jet airliners, and I'd like to understand more about what design considerations determine where exactly they end up. On the first 707s and DC-8s, they seemed to be placed such that the length from wingtip to engine 1 (segment A), between engines 1 and 2 (segment B), and between #2 and the fuselage (segment C) is pretty equidistant:
The 707-300 engines were really far outboard, but this was largely because they added the root insert to add span and fuel:
Then came the 747 with reasonably equal A, B, and C sections:
In the 90s we got the A340 and the IL-96. The 340 has a slightly larger B segment than A segment, and a small C segment, while the IL-96 has a huge section A and the engines bunched together:
What explanations exist for this variation in relative placement of the engines, especially between the IL-96 and A340? I'm aware that placing them further out provides bending relief, but what about the inboard engine? Do the A340s have the inboard engine so close because of the shared architecture with the A330?
Edit: were taxiways in the USSR narrower when they designed the IL86, thus necessitating inboard placement of #1 and #4 and a compensatory outboard movement of #2 and #3?
[Edited 2013-04-13 12:17:27]
RE: Engine Placement Along Wing On Quads
Sun Apr 14, 2013 1:06 am
I can think of a few reasons for engine placement:
- Wing bending relief. The more evenly distributed the better. However there is more lift inboard so there will be inboard bias.
- Placement of control surfaces.
- As you say plugs and wingtip extensions on later versoins have an effect.
- FOD avoidance.
The 340 is a bit of a special case since the inboards are in the same place as on the 330. They are pretty much the same airplane after all.
rwessel
Sun Apr 14, 2013 7:56 am
Quoting Starlionblue (Reply 1):
And much of the structure for the outboard engine mounts is still there on the A330. The A330 tanker mounts the wing refueling pods on the hardpoints for the A340's outboard engines. Fuel, power and whatnot are easily routed there as well.
LH707330
Mon Apr 15, 2013 6:19 am
Do the A340 and IL-96 have radically different high-lift systems? It seems weird that they have such different engine placements. Although the 340 shares the wing with the 330, it still looks more similar to other quads than the IL-96 does.
Viscount724
Tue Apr 16, 2013 7:36 pm
If memory correct the Convair 990 engines were moved slightly further outboard than in the original design to help reduce drag.
Users browsing this forum: Crosswind and 2 guests
