igorland
Boeing 747-400 (pax) Load And Trim Sheet
Sat Apr 20, 2013 3:30 am
Hello, everyone.
My hobby is aviation and programming and I am developing a small application for the X-Plane simulator that should help load a Boeing 747-400 and calculate CG, trim, fuel, and time for a selected simulated flight. This will be for the passenger version of the plane.
I am trying to code a Load and Trim Sheet and, unfortunately, I cannot find any good example on Internet. I could locate one for 767, Airbuses, but not 747-400. I have found a Load and Trim Sheet for a cargo 747 that includes the appropriate indexes for cargo and fuel. However, there is no DOI for the reference and I can only arbitrarily use one (say, DOI of 55-60).
Can someone please help and share a copy of the filled Load and Trim Sheet for 747-400 that I could use in the application to simulate CG and trim?
Your help is much much appreciated!
Best.
Igor
BravoOne
RE: Boeing 747-400 (pax) Load And Trim Sheet
Sat Apr 20, 2013 2:30 pm
You might find what your looking for if you Google a KAL 747-400F incidnet on takeoff from I believe Oslo. It's a complete incident report with graphics covering the load manifiest. There was a significant CG probem as I recall.
Good luck!
Sun Apr 21, 2013 1:19 am
Quoting BravoOne (Reply 1):
http://www.skybrary.aero/bookshelf/books/617.pdf
There are indeed several. Not the clearest scans unfortunately.
igorland
Mon Apr 22, 2013 11:34 am
Thank you so much, BravoOne and Starlionblue!!! I really appreciate it.
The document includes the Index-%MAC chart that is identical to the other document I have (with detailed indexes). It means that both sheets probably have the same way of calculating indexes from weight. And the document that you provided includes DOI (68.8) -- exactly what I was looking for.
Cheers!
Mon Apr 22, 2013 11:46 am
Quoting igorland (Reply 3):
Cheers!
BravoOne should have all the credit. I only googled after he mentioned the incident.
airtran737
Mon Apr 22, 2013 1:57 pm
PM me your email. I can send you a great sheet for a 747-400BDSF
Nice Trip Report!!! Great Pics, thanks for posting!!!! B747Forever
igorland
Tue Apr 23, 2013 12:13 am
Many thanks, airtran737! Just did. Best.
igorland
Fri May 17, 2013 1:29 am
Hi. May I ask one more question? Does anyone know usual CG (in ft, inches or %MAC) of a passenger 747-400 at dry operating weight?
Many thanks!
CCA
Mon May 20, 2013 3:57 pm
DOI between 510-560.
P1 in A330, A340, A346, B742, B744, B748.
