DeltaXNA
Could There Ever Be A Twin-engined 747?
Sat Apr 20, 2013 6:00 am
Is it possibly? GE90's?
flyinggoat
RE: Could There Ever Be A Twin-engined 747?
Sat Apr 20, 2013 6:57 am
Nope. Max thrust on a 747 is roughly 60,000lbs per engine, give or take a bit depending on engine manufacture. Aircraft must be designed to take off with one engine out. Max engine thrust on a 747 with one engine out is around 180,000lbs. If you were to place two GE90s on a 747, your max engine thrust with an engine out would be 115,000lbs. This is no where near enough.
The 777-9X is pretty much a twin engine 747.
OldAeroGuy
Sat Apr 20, 2013 1:53 pm
The payload-range of the proposed 777-9X surpasses the 747-400. If built, it will be a twin-engine 747.
CXB77L
Sat Apr 20, 2013 3:51 pm
Quoting DeltaXNA (Thread starter):
If your question was whether the 747 can operate despite being equipped with only two engines, then the answer is no. The 747 is not designed as a twin.
The A330/A340 was unique in the sense that they were designed specifically as a twin and a quad. I could be wrong, but I do not believe that the same can be done with other aircraft families that are not designed specifically with this interchangeability. There cannot be a twin engine 747 any more than there can be a quad engined 767 (for example).
If your question was whether there can be a 747 sized twin, then the answer is yes. There already is one, the 777-300ER, and two more on the way: the A350-1000 and 777-9X.
Quoting OldAeroGuy (Reply 2):
The 777-300ER's payload-range already surpasses that of the 747-400.
Boeing 777 fanboy
7BOEING7
Sat Apr 20, 2013 6:15 pm
There could have been a twin engine 747 and almost was. In the mid to late 70's Boeing was looking at a twin 747SP with the expected increases in engine thrust coming. The original 747 only has about 46,000 pounds of thrust.
Devilfish
Sat Apr 20, 2013 8:07 pm
Truly a fascinating and engrossing topic...a quick glance at the bottom of the page shows four threads, no less.....
Twin Engined 747...is It Possible? (by Jcchristie Aug 3 2008 in Tech Ops)
Is It Possible To Make A Twin Engined B 747? (by United Airline Nov 17 2005 in Tech Ops)
Could The 747ADV Be A Twin? (by Tockeyhockey May 13 2005 in Tech Ops)
A Twin Engined 747? (by Trent_800 Jan 13 2002 in Tech Ops)
Doubtless we're in for many more.....
http://www.flightglobal.com/blogs/fl...hy-would-boeing-design-a-mid-.html
.....in various configurations.    ...not sure when it would cease being called a 747 though...    .
flyingturtle
Sat Apr 20, 2013 8:37 pm
Even if such engines could be built, the most striking argument...
Bigger engines need more ground clearance, which needs longer landing gear struts. Which needs a huge redesign.
And IMHO, the even more striking argument is that any real airliner should have four engines. Or at least three.
David
Buyantukhaa
Sat Apr 20, 2013 9:49 pm
Quoting FlyingGoat (Reply 1):
But seems to have been evolving in that direction
Photo © Ben Kings
I scratch my head, therefore I am.
PapaChuck
Sat Apr 20, 2013 11:31 pm
It could be done, but not in a way that would make any economical sense to any airline.
Start with a basic 747-8 so we can take advantage of the new wing. Let's assume that a GE-90 could be shoehorned under each wing and the ground clearance issues could be resolved without needing a complete wing or landing gear redesign. The rudder/vertical stabilizer would need modification as well to provide increased control authority in an engine-out scenario.
Now we have a basic airframe, but the weights are now going to work against us. Given the available thrust, let's assume that the MTOW would have to be restricted to the 777-300ER range, around 750,000 lbs. Boeing lists the OEW for the 777-300ER and the 747-8 as 370,000 lbs. and 434,600 lbs. respectively. Right away the 747 twin will have about 65,000 lbs. less useful load given a similar MTOW. Economically, that's enough to kill the project right there. The basic 747 airframe is just too beefy. I suppose you could do a fuselage shrink and find other ways to save weight, but it will always be heavier than the basic 777 airframe.
Back to the original question: could a 747 twin be built? Sure, but it would be a lame duck compared to the competition. The 747 was designed as a quad, and thus it shall always be.
PC
In-trail spacing is a team effort.
Sun Apr 21, 2013 1:15 am
Technically, a 747 sized twin is tricky. You'd need to have engines that produce 40%+ more thrust than the current largest engines.
The economical conundrum is that, the larger the engine (or aircraft for that market) the smaller the market but the larger the investment. Developing a GE90 is much bigger gamble than developing a CFM56. Look, for example, at the difficulties experienced by P&W when the JT9D was developed. Unless engine technology changes rather drastically, it does not make sense to invest in developing a 160000lb thrust engine.
This leads us to "what's the point?" There's nothing inherently evil about four engines. Yes, very large twins have in the past twenty years shown themselves remarkably economical. However plenty of first line airlines are very happy operating very large quads. There is a weight point at which even the economy of a twin doesn't enable the construction of a twin.
DarkSnowyNight
Mon Apr 22, 2013 2:04 pm
Quoting CXB77L (Reply 3):
Indeed, as the 779X will likely have the same relationship to the 748, especially once evolutional upgrades come online as well.
I think there could be; it would just be a question of how useful it is. Enough Boeing customers would really have to love that hump to make it worthwhile.
It would almost certainly need a new wing; not just to accommodate the engines, but as well the effected center of gravity. With two fewer engines, that wing box will either have to be set a good deal further aft, or airlines will just have to be ok with tail-standing their planes until fueled.
There would also have to be a pretty comprehensive materials and processing upgrade as well, along with whatever further lightening they could get away with in order to have it so that a variant of today's GE-90 could actually loft that thing. On the plus side, that and larger tires would probably also allow for a simpler, dual carriage, six wheel bogie set up instead of what's there now, so we'd see further weight savings there.
I really think that a 160,000lb engine being required is total nonsense, as enough structure redesign would be required to effectively void that anyway. And I also think that designing a 747(I guess 9) in this fashion is not only feasible, but likely less costly than the 380 was for Airbus, and the 787 was for Boeing.
It would even be totally worth a look into... If there were not going to be a 779 or A350.
And so... This topic is a very good and interesting one, as a thought exercise, but it does fall firmly under the "Well, if your aunt had balls, she'd be your uncle" category.
Be A Perfectionst, You're Nothing If You're Just Another; Something Material, This Isn't Personal...
mmo
Mon Apr 22, 2013 4:53 pm
There is another factor that has not been mentioned. The entire rudder would have to be redesigned to allow for control with one engine out. Currently the 744 can handle two out on one side with the existing rudder. However, with the thrust available you would need the rudder would have to be redesigned to allow for a reasonable VMCA.
Too expensive and market is not big enough given existing or even potential products.
deltal1011man
Tue Apr 23, 2013 9:48 am
Already have one. the 777-300ER is basically a 747. Sounds like a 777-9 will fully be able to do everything + what the 747-400 will do.
I guess I am a little confused at what you mean here.
2x GE90-115BL2=230,000lbs of thrust
4x PW4060=240,000lbs of thrust.
thats 10,000lbs of differences
be a good little boy and do as Demand Media tells you. sellouts.
Tue Apr 23, 2013 10:02 am
Quoting Deltal1011man (Reply 12):
You're calculating based on all engines running. You need to calculate based on one engine out while climbing out. In a worst case scenario, i.e. an engine out at V1, you will have three engines in a quad, but only one in a twin.
1x GE90-115BL2= 115,000lb of thrust.
3x PW4060= 180,000lb of thrust
With those numbers it is actually more like 56.5% than 40%, and that doesn't account for the extra drag of going sideways on one engine while climbing out. However I am willing to stipulate an airliner made of lighter materials than a 747-400, so I think the 40% number is reasonable.
[Edited 2013-04-23 03:03:46]
Quoting mmo (Reply 11):
I don't think a rudder redesign need be so dramatic. Besides, they have the 747SP fin and rudder as a starting point. The 747SP fin was taller and the rudder had a double hinge for more authority given the shorter moment arm.
[Edited 2013-04-23 03:10:28]
[Edited 2013-04-23 03:11:03]
deltal1011man
Tue Apr 23, 2013 10:33 am
Quoting Starlionblue (Reply 13):
ahh didn't even think about n engine out.
Tue Apr 23, 2013 10:37 am
Quoting Deltal1011man (Reply 14):
No worries. Most people don't. A twin has way more power than "needed" when all engines are running. That's why a 757, 330 or 777 can blast off from the runway compared to a 747 or 340. With an engine out it is another story. This is one of the reasons the 340 has been favored by airlines with lots of hot and high ops, for example SA out of JNB.
[Edited 2013-04-23 04:02:56]
mmo
Tue Apr 23, 2013 11:17 am
Actually, I think it would be quite a redesign. The SP rudder was for a much shorter body. The SP was shorter than the 100/200 while the 400 is longer and the -8 even longer. Most likely the redesign/production and certification would make it just too expensive when you have the 773ER and the 779X waiting in the wings. With over 10,000 hours in all models it is truly a great aircraft. However, it really can not compete with the 773ER.
Tue Apr 23, 2013 11:23 am
Quoting mmo (Reply 16):
The SP rudder and fin were indeed for a much shorter body. For this reason the fin was longer and the rudder had more authority than the ordinary 747 fin and rudder. A longer body means you can get away with a shorter fin and less powerful rudder. However given more powerful engines you need a longer fin and more powerful rudder.
I think the 747SP fin would do just fine, but I don't think Boeing would go for a 40 year old design. The 777-900X would be longer but have more powerful engines, design features that work in different directions with regards to fin and rudder. The current 777 fin/rudder design probably works, perhaps with a fin extension and worst case with a double hinged rudder.
[Edited 2013-04-23 04:25:09]
mmo
Tue Apr 23, 2013 12:08 pm
Quoting Starlionblue (Reply 17):
Not quite. The 779X will actually have a lower MTOW than the current 773ER, with less powerful engines than the current GE115s. However, on paper, it will have a better range/payload combination than the current 773ER.
Believe me, after flying the SP for about 450 hours, I know how it works. My point was the SP rudder is for that length body. More importantly, the adverse thrust and asymmetrical yaw would require a very robust rudder. The rudder for all of the various models was not designed for that type of situation.
Tue Apr 23, 2013 12:37 pm
Quoting mmo (Reply 18):
Fair enough. However my point was that Boeing have a lot of rudder design experience. If you say that the 779X will have less powerful engines than the 773ER then presumably the current 773ER rudder will be more than enough.
My 747SP comment was half in jest. Sorry that was not clear. Besides, this thread is about a twin 747, not the 777-900X. Two quite different beasts.
DarkSnowyNight
Tue Apr 23, 2013 1:54 pm
The 400 is not longer than the 100/200. It has the extended hump like the 300 & some 100s & 200s, but the aircraft is identical in length. For that, you will need the LCF or the 8.
mmo
Tue Apr 23, 2013 1:56 pm
Quoting Starlionblue (Reply 19):
I do realize that. However, the issue is the 779X will most likely cannibalize what little 747-8I sales are left. The economics on that aircraft will be just too hard to beat. In reality, almost anything can be done from an engineering perspective, but the economics just aren't there anymore. The 779X will, I am afraid, be the last nail in the coffin for the 747 family.
OldAeroGuy
Tue Apr 23, 2013 5:16 pm
Yes but with some 50 less seats, the 773ER could be argued as not quite a 744 replacement. Since the 779X and 744 seat counts are virtually identical, the 779X is more effectively a 744 replacement.
citationjet
Wed Apr 24, 2013 11:04 am
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
rwessel
Thu Apr 25, 2013 6:37 am
Certainly aircraft families have evolved different numbers of engines at times. The B-36, BN Islander, Hawker Trident and Sikorsky CH-53 are examples, and you might consider the An-124/An-225 another. And while never built, there was a proposal to re-engine B-52's with four modern turbofans (replacing the eight old TF-33s).
So while the A330/340 were certainly designed with both options from day one, it's not out of the realm of possibility that such a change could occur on a different aircraft.
ed: "An-123/An-224"?? Sheesh!
[Edited 2013-04-24 23:52:23]
Thu Apr 25, 2013 6:46 am
Quoting rwessel (Reply 24):
Certainly aircraft families have evolved different numbers of engines at times. The B-36, BN Islander, Hawker Trident and Sikorsky CH-53 are examples, and you might consider the An-123/An-224 another. And while never built, there was a proposal to re-engine B-52's with four modern turbofans (replacing the eight old TF-33s).
Absolutely agreed. However I think it might be simpler to start from the 777 than from the 747 if you need a 747-400 capacity twin. Perhaps a hybrid with 747 body plus 777 wings with a root insert?
If they really want to scare people, Boeing could go back to the Hunchback of Mukilteo design, adding a rear hump to the 777.
Viscount724
Thu Apr 25, 2013 9:12 pm
Quoting OldAeroGuy (Reply 22):
Depends on the configuration. KLM's 77Ws (10-abreast in Y) have 425 seats, 10 more than their all-passenger 744s. 7 fewer J seats but 17 more Y.
77W - 35J, 390Y (including 40 34-inch pitch "economy comfort", total 425.
744 - 42J, 373Y (including 36 35-inch pitch "economy comfort", total 415.
OldAeroGuy
Fri Apr 26, 2013 2:52 pm
Quoting Viscount724 (Reply 26):
Ah, the 10 ab 777, so dreaded by Anet readers combined with reduced seat pitch. Not a convincing argument for equivalent pax capacity between a 773ER and a 744.
DarkSnowyNight
Sun Apr 28, 2013 4:03 pm
Quoting OldAeroGuy (Reply 27):
How is it not convincing? More is more. There are quite a few 400+ 77Ws out there, and they all carry more cargo (and further) than any 744 can. I'd say that makes it an effective 'better' 744 as it stands.
If you were to say it's not as comfortable, I would have to agree with that (although KL's 744s are certainly nothing to write home about in Y; at least not any of the 74Ms I've been on). But, as a.net is all too happy to point out, comfort doesn't matter for paying PAX anymore. I guess...
Mon Apr 29, 2013 12:23 am
Quoting Darksnowynight (Reply 28):
Yes, it can carry more pax, but you can make a 744 just as dense and then it would carry more pax.
For an airline, numbers alone aren't enough. Airlines would be happy putting ten seats on a 744 if it made a better profit than one with 400 seats. You have to compare apples to apples, meaning a 744 and a 773 with the same class mix and seat size.
This is not true in East Asia. If comfort didn't matter, we would not have business class or economy plus.
Users browsing this forum: Google [Bot], TailDragging, vxg and 11 guests
