FlyboyOz
Flight Schedule - How Can It Be On Time?
Sat Apr 27, 2013 11:55 pm
Look at the airlines timetable and flight schedules. There is something missing about it. I do not understand "when" and "where" the actual time can be.
Departure:
The airlines timetable shows the plane's departure time is 9:00am from ABC to XYZ. Does it mean that the plane has to be take off at 9:00am or the gate must be closed at 9:00am sharp?
Arrival:
The plane arrives at 10am. Does it mean that the plane touched down at 10am on the runway or the plane stopped at the gate at 10am?
Add one more:-
Why does the airlines want the pax to be on the plane 30 mins earlier before departure time if the traffic isn't busy??? It's a bit too early.
[Edited 2013-04-27 17:40:53]
The Spirit of AustraliAN - Longreach
Okie
RE: Flight Schedule - How Can It Be On Time?
Sun Apr 28, 2013 12:00 am
Quoting FlyboyOz (Thread starter):
Departure:
Push back from the gate.
Arrival:
Gate arrival generally, but it is considered as arrived on time even if has to wait hours for the gate.
Okie
Sun Apr 28, 2013 12:01 am
There is more than one time figured. The acronym for the four times is OOOI, meaning Gate Out, Wheels Off, Wheels On, and Gate In. This is needed since taxi times are different at different airports.
As far as I know, published schedules are based on Gate Out and Gate In times as Wheels Off and Wheels On are only really relevant for flight crews, maintenance and dispatchers.
FlyboyOz
Sun Apr 28, 2013 12:41 am
Thanks mate
One more question: -
Sun Apr 28, 2013 1:11 am
Quoting FlyboyOz (Reply 3):
Murphy's Law. In most cases nothing goes wrong, but you have to plan for screwups. If nothing else, there will inevitably be pax who cut it fine and come along at the last minute. Better to tell everyone to get there early and have them wait a bit on the plane than to risk a delay due to missing the slot.
FlyASAGuy2005
Sun Apr 28, 2013 1:33 am
Quoting okie (Reply 1):
Unless i'm reading what you're saying wrong this would be incorrect. A flight being "on-time" is measured by their arrival time. The arrival time isn't time stamped until the plane is in the gate. So for example if you leave LAX right on schedule and take -off not too long after. Land at JFK about 10 minutes before your arrival time but sit around for a gate for 40 minutes the flight is late.
What gets measured gets done.
mmo
Sun Apr 28, 2013 5:34 am
Not correct. It is when the aircraft is at the gate, but it is also when the door is opened. The "event" is triggered by ACARS and the door open is one of the final requirements. If you sit at the gate waiting for an hour, that is not an "arrival" time. The meter is still running and the crew is still getting paid.
The airlines use the OOOI (out/off on/in) for times. As has been pointed out, the off and on times are used for maintenance to record the airframe time. The out/in time are used for the computation of the scheduled departure and arrival times.
rfields5421
Sun Apr 28, 2013 7:20 am
Add one more:-
Heck, when I started flying, you had to check in at the gate an hour before boarding time, or you could lose your seat.
The best/ fastest time I've ever seen was a start boarding to door closed and push back start for an AA B738 that took exactly 11 minutes. A full airplane. (We were already seven hours delayed by weather in the incoming flight arriving. The pilot told us before boarding that he guessed he had maybe 20 minutes to get the plane loaded, and taxi out to the active runway - otherwise the flight would be delayed at least three more hours with another line of thunderstorms coming in. As it turned out our BDL-DFW flight had to fly over Toronto, MSP and DEN to avoid weather that day to get to DFW.)
In reality, the average time it takes to board an airplane and get everyone in their seats is closer to 20-25 minutes for a narrowbody.
Getting everyone settled and all their junk stowed properly, making sure all the paperwork is right, making sure everything is right takes time. 30 minutes allows for the little things that happen too often, and still getting the plane out on time.
Woodreau
Sun Apr 28, 2013 12:25 pm
The triggering events are the release and setting of the parking brake.
For departure once the main cabin door is closed the parking brake must be released for ACARS to generate the OUT time. Once it's generated then the plane can sit there until eternity it is still considered departed.
On arrival the time the parking brake is set is the IN time. The plane taxis in and the brake is set. The IN time is recorded but ACARS does not transmit that IN time until a cabin door is opened.
Quoting rfields5421 (Reply 7):
When everything is setup and everyone is on the same page turnarounds can happen quickly.
The fastest I've seen from block in to block out is 1 minute.
The plane landed and blocked in one pax got off. Paperwork got handed to the CA who handed it right back out to the gate agent. The FO walked around the aircraft while one pax boarded. While the ramper took off the deplaning pax's bag and loaded the bags for the pax who got on. The FO got back in closed the door and the plane blocked out.
Faster than a NASCAR pitstop.
Tristarsteve
Sun Apr 28, 2013 2:20 pm
Quoting woodreau (Reply 8):
There are some newer aircraft that require a taxy speed from the IRU as well before setting an Out time. There were too many pilots releasing the brakes for an outf time!!!!
mmo
Sun Apr 28, 2013 4:04 pm
Not quite correct. Each airline can set up their own parameters to trigger an event. All the airlines I have worked for had the brakes and door open as the event for a IN event.
CrimsonNL
Sun Apr 28, 2013 4:52 pm
Quoting mmo (Reply 6):
There are still plenty of airlines out there that don't have ACARS equipped aircraft, and even if they do, ACARS is not always used for onblock/offblock times. Those airlines will have to rely on times send by the airport or handling agent which can be easily manipulated.
Martijn
mmo
Sun Apr 28, 2013 7:53 pm
Quoting CrimsonNL (Reply 11):
First of all, I never wrote ALL airlines have ACARS. If I did, please point it out and I will change it.
Secondly, If the regulatory bodies ever get wind of manipulation of OOOI times, I do not want to be there. The simple fact is falsifying records is a very serious issue.
FlyASAGuy2005
Mon Apr 29, 2013 3:34 am
Just for those that don't work for an airline understand..."OUT" and "IN" events are triggered in different ways even within the same company. Some airlines require all doors (including cargo doors) to be closed for an out event to trigger even if you pop the breaks. Some only require the boarding door to be closed and the beacon engaged.
Not all Delta a/c give a time-stamp for the bin doors closing while some do (all the 319s/320s has this ability). We have some 757s that can trigger an out event via ACARS (releasing the breaks) with passengers still boarding and some where it must be clean (cargo/cabin doors closed). It just depends.
Mon Apr 29, 2013 10:07 am
The Timings on the Airlines Schedule is the Chocks On & Chocks off time.......Not the Takeoff or Touchdown time, which is also recorded but for other purposes like TIA [Time in Air].
Okie
Mon Apr 29, 2013 4:06 pm
Quoting flyasaguy2005 (Reply 5):
Maybe for the airlines but for a passenger the board says arrived while it is sitting in line waiting for a gate so you can board it for your connection.
Okie
Users browsing this forum: Google [Bot], KanaHawaii, Starlionblue and 1 guest
