1337Delta764
Illuminated "Life Vest Under Seat" Signs On L-1011
Sun Apr 28, 2013 12:46 am
On every L-1011 I have flown on, one unique thing about them was the fact that they had illuminated "Life Vest Under Seat" signs in addition to the No Smoking and Fasten Seat Belt signs.
I wonder, what was the function of those signs? On every L-1011 flight I have been on (on DL and ATA), the signs turned on and off simultaneously with the Fasten Seat Belt signs. However, was it possible for the captain to turn them on/off separately? If so, what would be a situation where it would be turned on separately?
[Edited 2013-04-27 17:47:21]
PGNCS
RE: Illuminated "Life Vest Under Seat" Signs On L-1011
Sun Apr 28, 2013 12:59 am
Quoting 1337Delta764 (Thread starter):
No. The switch is on the overhead on the FO's side of the cockpit if you want to look for it in a photo. The signs would be turned on prior to any landing water or land; they are there simply to remind people where life vests are located if it happens to be a ditching. Thankfully no L-1011 ever had to ditch, though one almost did.
1337Delta764
Sun Apr 28, 2013 1:24 am
Quoting PGNCS (Reply 1):
I wonder why no other aircraft manufacturer incorporated such signs on their aircraft. Of course, with the shift from worded signs to pictograms on newer aircraft, I guess nobody was willing to come up with a pictogram for it.
PGNCS
Sun Apr 28, 2013 2:19 am
Quoting 1337Delta764 (Reply 2):
A fair question. One thing nobody can accuse the Lockheed engineers of is not trying to cover every reasonable contingency.
At any rate, I would like to see the pictogram for that.
1337Delta764
Sun Apr 28, 2013 2:30 am
Quoting PGNCS (Reply 3):
I know AC had pictogram signs on their L-1011s for the No Smoking and Fasten Seat Belt signs, however, the Life Vest Under Seat signs were still worded (in both English and French I believe).
1337Delta764
Sun Apr 28, 2013 5:12 am
Just for fun, how is this for a Life Vest Under Seat pictogram?
[Edited 2013-04-27 22:17:04]
AA737-823
Sun Apr 28, 2013 7:30 am
Quoting 1337Delta764 (Reply 5):
Fail.
That's either a "Life Vest Located at Left of Seat," or, "Put on Life Vest and then Sit Down."
jgarrido
Sun Apr 28, 2013 3:19 pm
Quoting AA737-823 (Reply 6):
Lion Air could probably use it as part of boarding
Viscount724
Sun Apr 28, 2013 11:02 pm
Probably because it wasn't required and it's one more thing that requires maintenance and resulting increased costs.
Users browsing this forum: WIederling and 1 guest
