mmedford
Pilots; SOP When LOC OTS?
Mon Apr 29, 2013 2:38 pm
Just want to confirm I'm not crazy; as far as I know...when the LOC is OTS, the whole ILS is considered OTS. (Also no LOC, no ident signal...flag doesn't get pulled back)
For the flight crews out here; when the LOC is OTS, What does Airline SOP tell you to do?
ILS = It'll Land Somewhere
mmo
RE: Pilots; SOP When LOC OTS?
Mon Apr 29, 2013 2:48 pm
Correct.
Only other options would be a VOR, or NDB, or RNAV/GNSS approach assuming one would be available and the weather minimums were sufficient.
If you had the minimums, you could also do a visual, if allowed under company SOP.
mmedford
Mon Apr 29, 2013 3:02 pm
Just checking; got into an argument last night. I was told the GS was needed for vertical guidance, when the LOC was OTS.
PGNCS
Mon Apr 29, 2013 3:25 pm
Quoting mmedford (Thread starter):
The GS by itself is not useful as there is no lateral guidance available if that's what you're getting at.
Quoting mmedford (Reply 2):
Stick to your guns on this one. What is your friend alleging you use for lateral guidance if the LOC is OTS?
Bottom line: you need another approach of some sort.
Mir
Mon Apr 29, 2013 5:47 pm
Correct.
Find another approach to fly.
Quoting PGNCS (Reply 3):
Well, theoretically it could be of some use if you were in VMC and could align yourself with the runway visually and then use the GS as advisory glidepath information. But even if the conditions were right for that, I'd be very wary about using it since who knows what errors might be present in the system.
-Mir
Alias1024
Mon Apr 29, 2013 6:20 pm
Quoting Mir (Reply 4):
Very true. Most airline SOPs include some sort of statement that visual approaches are to be backed up using electronic glideslope information when available, but I'd certainly be weary of its reliability if the localizer is out of service. Definitely backing that up with the PAPI, VASI, or if neither is available perhaps display VNAV guidance programmed into the FMS.
My vague memory has in the back of it that some aips state at night, when aligned with the runway visually you may descend below the msa if you have an electronic glide slope.
Also from memory, some types of aircraft allows one to intercept a glide slope without a valid loc signal or valid loc capture.
PGNCS
Tue Apr 30, 2013 3:41 pm
Quoting zeke (Reply 6):
Yes, there are aircraft that allow you to capture the GS without first capturing the LOC, though the automation doesn't evaluate the legality of doing so.
IAHFLYR
Fri May 10, 2013 4:30 pm
Just ask your pal why they NOTAM the ILS OTS when the localizer is OTS? In over 35 years of seeing ILS outage having a NOTAM applied to them I never saw one that was worded "LOC OTS, GS usable"!!
DualQual
Tue May 21, 2013 4:07 pm
Yup, you don't change your situation vertically, until you can verify your situation horizontally. Just like flying through the mountains, you don't descend off an airway unless you can assure terrain separation. Same principle here. You don't use suspect guidance to get closer to the ground without knowing where you are over that ground!
There's no known cure for stupid
fxra
Tue May 21, 2013 8:59 pm
From our side, an LOC out negates the ILS. I've never seen an instrument plate for a GS ONLY approach... If the LOC, and thus ILS is OTS, we try to find another instrument approach we can do with the wx. If, as occasionally happens, there are no available instrument approaches, we have a procedure for dispatch with just a visual approach available.
The crews are able to accept visual approaches but are told to back it up with an instrument approach when available. Due to the nature of our operation, we often operate in the middle of the night when towers are closed or maintenance is being performed on airport systems. It's amusing to being in a Heavy shooting a visual and doing callouts on CTAF... like back in the Cessna 152 days as a student.
Visualize Whirled Peas
Mir
Wed May 22, 2013 2:36 am
Quoting IAHFLYR (Reply 8):
I see "LLZ OTS" all the time - they don't say that the GS is usable, but they don't say it isn't, either (if they wanted to, they'd say "LLZ/GP OTS", which I do see as well from time to time).
-Mir
IAHFLYR
Wed May 22, 2013 6:30 pm
Quoting Mir (Reply 11):
Are you sure a GP is even associated with the procedure? Could be a BC or a LOC approach ya know.
Mir
Wed May 22, 2013 11:56 pm
Quoting IAHFLYR (Reply 12):
I don't think it is, but the next time I see one I'll check.
-Mir
mmedford
Thu May 23, 2013 5:01 pm
I think back-course approaches are a thing of the past and slowly fading away, if I am not mistaken the supplier for the V-ring antennas required for a BC LOC is no longer in existence.
IAHFLYR
Thu May 23, 2013 9:28 pm
Quoting mmedford (Reply 14):
That's a great thing!
Users browsing this forum: deltal1011man, UnitedIsBae and 1 guest
