cobra27
Foldable/No Vertical Tail On Airliners?
Tue May 07, 2013 9:24 am
Idea is to reduce drag (double digit percent improvement). Vertical tail is almost the size of wing on some airliners.
I am more in favour of foldable tail (like F-14 Tomcat wing), which would be used in TO/LDG. In cruise it would partially or completely fold into the fuselage.
The tailless airplane like B-2 bomber seem to work.
Also the horizontal tail could be tweaked, but with less drag reduction
What do you think, could it work? Would there be stability issues?
RE: Foldable/No Vertical Tail On Airliners?
Tue May 07, 2013 9:53 am
Quoting cobra27 (Thread starter):
If there was a double digit percentage point reduction to be had without an equivalent rise in some other negative factor, I guarantee we would be flying tail-less airliners today. There are always trade-offs and compromises, and this case is no different.
Name one...
Too much weight added with current materials.
It does work. It also requires a lot of fancy software in the flight control systems. The pilots have ejection seats. Nowhere near safe enough for commercial use.
Yes, very much so.
[Edited 2013-05-07 03:00:03]
cobra27
Tue May 07, 2013 10:08 am
Quoting Starlionblue (Reply 1):
Name one...
737
OK, maybe not the size of full wing but close (surely more than half)
Tmuch weight added with current materials.
Current materials are no problem, especially carbon fibres. Weight is a penalty but drag reduction offsets it
Tue May 07, 2013 10:44 am
Quoting cobra27 (Reply 2):
Name one...
737
Not even close. 737NG figures:
- Wing area 124.58 square meters
- Fin area 26.44 meters
- Wing span 34.32 meters
- Fin height 7.16 meters
Again, name one.
Carbon fiber is not the issue. The weight and complexity of the folding mechanism is, regardless what material it is made of.
cobra27
Tue May 07, 2013 12:07 pm
Quoting Starlionblue (Reply 3):
F-111, F-14, SU-24 all have working folding wings, I think that folding tail should be easier, since it doesn't carry so much load as wing. Dependns how you design it. Also tilting mechanism could be used, which wuld tilt the tail backwards and reduce cross section.
In my opinion there is bigger problem in stability in turbulence for example.
Tue May 07, 2013 12:12 pm
Quoting cobra27 (Reply 4):
Those are all military design, and thus accept a much higher cost of operation and construction than airliners. I'll also add that they are all old designs. Variable geometry is no longer the go-to solution even among fighter planes.
[Edited 2013-05-07 05:15:34]
David L
Tue May 07, 2013 12:28 pm
As Starlionblue says, those are not exactly economically efficient examples. And how many of their replacements have variable sweep wings?
ptrjong
Tue May 07, 2013 12:34 pm
The B-2 only works because it has little side area.
Tue May 07, 2013 1:04 pm
I just want to make it clear that I am not negative to your ideas because I am conservative in my thinking, cobra27. In fact forward, creative thinking is just what any industry needs. However airplane designers are quite clever and have thought these things out. If there was a double digit efficiency gain to be had, there would be blood in the water. Heck, a 2% total fuel burn improvement is cause for massive investments.
Variable geometry is an elegant solution on paper, and leads to quite big efficiency gains in one area. Unfortunately weight, maintenance and reliability are gigantic issues that negate the efficiency gains. With some sort of "smart" pliable material that could change shape reliably without actuators and massive hydraulics, it would be another story, but with current technology variable geometry is limited to things like flaps.
Quoting ptrjong (Reply 7):
And because it costs a trillion dollars per plane.
[Edited 2013-05-07 06:18:22]
cobra27
Tue May 07, 2013 1:53 pm
Am sure it is more than 9% improvement. Blended wing is a more aerodynamic wing, it also gets less drag since it has no vertical tail and no separate elevator is. You probabaly know that separate elevator makes negative lift for stability
Quoting Starlionblue (Reply 5):
I don't think they are old designs. I think that commercial airliners pick from military airplanes but at least a decade later.
And I don't think it is so expensive
Horstroad
Tue May 07, 2013 4:52 pm
I don't think that reliability or maintenance costs are an issue.
look at the horizontal stab trim. take the hinge and the big screw and let it work horizontally... not much different...
the span of the A380 horizontal stabilizer is 30.37m... I think you can call it a wing
rfields5421
Tue May 07, 2013 5:27 pm
We had folding vertical stabilizers on the A-3 Skywarrior in my first USN squadron back 40+ years ago. The wing tips also folded so that the aircraft was about 25% less wide. The folded tail and wings made it possible to fit the plane into a carrier hanger deck, but no one wanted to do so if possible to avoid.
Of course the folding tail wasn't meant to be used in flight.
There was at least one aircraft loss, along with the crew, during the USN usage of the aircraft due to the locking mechanism on the vertical fin failing (no ejection seats).
It was a major maintenance factor. If there was any indication of a leak - the plane was grounded. It added weight and complexity to the aircraft.
What direction are you going to fold the vertical stabilizer? There isn't enough fuselage to just fold it down with one fold point.
Every fold point is going to increase the weight of the vertical stabilizer probably 100%. If you fold it four times - that's a 400% increase in weight - right on the very back of the aircraft. COG has to be redesigned.
I think the added weight and the added maintenance and construction complexity would offset any fuel savings quickly. I think it would increase the cost of acquisition and the cost of operation much more than any fuel savings could ever hope to pay back.
cobra27
Tue May 07, 2013 5:38 pm
W
Quoting rfields5421 (Reply 11):
I should say hinge or something. You didn't get my point. The crossarea should be reduced so there is not so much drag
mandala499
Tue May 07, 2013 5:45 pm
Quoting cobra27 (Reply 9):
If military combat aircraft are bound by the same constraints as airliner operating economics, military aviation would be extremely boring.
Those military planes are smaller and lighter yet costs the same if not more to operate and maintain per hour than your average narrowbody airliner... at least in terms of per ton gross weight if not also in absolute terms...
And blended wing body airliners have not been put into production due to...well, not aerodynamical and construction issues, but infrastructure issues, imagine the modifications to put into airports around the world...yikes.
roseflyer
Tue May 07, 2013 5:48 pm
The failure modes of a hinged rudder & vertical fin are not very appealing. I have no doubt it could be made to work, but the redundancy required and complexity of moving actuators & hydraulic plumbing just to save drag would way far too much to ever make it worthwhile. Folding a wingtip with no control surfaces on the ground to fit into smaller gates on the 777 is enough of a challenge. Folding the entire fin in flight sounds extremely challenging.
If they really want to reduce vertical fin size, they can increase rudder authority with a dual hinge rudder tab. The A320 & 737NG probably could get away with a vertical fin shrink by eliminating the smallest 737-600 & A318 body lengths which decrease the amount of rudder authority needed.
I can think of much better ways to spend tens of millions of development dollars than to hinge the vertical fin to save on drag.
[Edited 2013-05-07 10:49:43]
cobra27
Tue May 07, 2013 8:03 pm
OK, If I remember correctly, the vertical fin on Cessna 152 has around 3% better range than swept back tail. This is quite a lot for only small angle of sweep
Mooneys have also non swept fins to increase speed.
Stitch
Tue May 07, 2013 11:10 pm
The Boeing 377 Stratocruiser had a foldable vertical stabilizer, but that was just so it could fit in short hangars.
Tue May 07, 2013 11:39 pm
Quoting horstroad (Reply 10):
Heh. Well sure but I was using 737NG numbers. The wingspan of an A380 is almost 80 meters, and the wing area is multiple times the tail area. In other words same story there. Fins are not "half the wing".
Quoting cobra27 (Reply 15):
Could you clarify this? I don't quite understand what you mean. AFAIK all 152s have swept tails.
I get the impression that Mooneys have that particular tail shape because it is distinctive.   Jokes aside, you're talking a plane that does under 200 knots. The aerodynamics change considerably one you start on the transonic speed range.
Quoting mandala499 (Reply 13):
thegeek
Wed May 08, 2013 12:51 am
I don't understand the drag reduction claimed.
rfields5421
Wed May 08, 2013 1:57 am
Quoting cobra27 (Reply 12):
I understand your idea, but you also need to consider the adverse factors.
Where are you going to put the folded segment to minimize frontal cross area?
The fuselage isn't tall enough in the empennage area to hold a 1/2 fold or even 1/6 fold vertical stabilizer.
Only a unit which telescoped into itself would hold the areas you wanted to get out of the air flow, however, you have to increase the cross section by a factor of at least two to create a telescoping mechanism and have it strong enough to withstand the unidirectional air flow and rudder movements. The end result will be MORE drag and more weight.
Any way you do folds, you are going to greatly increase the weight hanging on the very back of the plane. The fold mechanism and extra strengthening needed to support the weight at an unusual angle is a significant weight penalty in carrier aircraft.
Anything which folded the fin to a side by side configuration would increase the drag even with the same frontal surface area because of turbulent airflow between the side by side sections.
You are saying you want to reduce the frontal drag area of the vertical stabilizer and possibly horizontal stabilizer.
Fine.
But where do you propose to put the frontal area you take out of the wind?
The idea was interesting, but I can't get past the physics and the engineering requirements.
Wed May 08, 2013 2:27 am
Quoting thegeek (Reply 18):
The full size of the fin and rudder are only needed at low speed with an engine out. At cruise speed the fin and rudder can be much smaller. A variable geometry fin which shrinks at high speed would reduce drag.
Quoting rfields5421 (Reply 19):
The only way I think this is feasible is with some sort of pliable material that does not need actuators and hydraulics. A bit like an inflatable structure.
[Edited 2013-05-07 19:28:10]
thegeek
Wed May 08, 2013 3:33 am
Quoting Starlionblue (Reply 20):
Hmm, I think I get it now.
Why not just have a rudder with a longer chord and not quite as high? The savings involved in this idea seem pretty minimal and I'm not at all sure where the OP got their double digit savings idea from.
Or an all moving vertical tail, similar to all moving stabilisers on supersonic planes? I'm guessing that it's too heavy and doesn't save enough drag to bother.
rfields5421
Wed May 08, 2013 3:41 am
That was my thought also, but I dismissed it because I can't thing of a current material which would sustain the loads.
Having spent a lot of time around Naval Aviation - the only reason that foldable wings/ tails are used is to make the aircraft fit into smaller deck space or the hanger height requirements.
They are a mechanical liability and weight liability. If the US Navy could avoid them, they would.
Looking back over this - are you talking about a variable geometry tail, not a foldable tail?
One which would pivot back to take much of the frontal area out of the forward wind resistance, and put it in the trailing wind turbulence?
There have been several aircraft with variable geometry wings. The F-111, the F-14, the B-1, the Panavia Tornado, the MiG-23, the MiG-27, the Su-17, the Su-24, the Tu-22M and the Tu-160.
The one thing all have in common is a need to have a steeply swept wing for supersonic flight, and used a forward wing position for landing, slow speed flight.
There was also one aircraft which folded the outer sections of the wing down for an increase in lift during supersonic flight - the XB-70. The purpose was to increase 'compression lift' during supersonic flight. http://upload.wikimedia.org/wikipedi...ican_XB-70_in_Flight_EC68-2131.jpg
The variable geometry wing itself is very complex with the sweep mechanism. Again - a large weight penalty, and reduced ability to use movable conrol surfaces on the swept portion of the wing. The cross section would also likely have to be more than current vertical stabilizer designs.
Such a tail device has probably been studied by NASA and others - but I can't find any reference to any studies.
mandala499
Wed May 08, 2013 5:28 am
Quoting rfields5421 (Reply 22):
Just to prove your point... The US Navy did avoid it for the A-4 Skyhawk as it specified simplicity and lightweight as a major requirement... folding wings don't go well with those two factors as we know.
And high subsonic / transonic low level flight.
Wed May 08, 2013 6:03 am
Quoting thegeek (Reply 21):
I think that gives you more drag in total for the same amount of authority.
cobra27
Wed May 08, 2013 10:06 am
Yes, that was thought also, increase the rudder and reduce the tail. All movable is the best idea. And it is easier to fold or change geometry.
Basically I am looking to reduce drag no matter which solution.
Conventional tail (both vertical and horizontal surfaces) are good for controlability but less good aerodynamically
I got a feeling if Boeing made a working example other would follow
oly720man
Wed May 08, 2013 11:23 am
Quoting Starlionblue (Reply 24):
I'd have thought you'd need the height of the fin so that some effectiveness was maintained at the higher incidences/pitch angles. A smaller fin may be wholly in any separated flow around the fuselage. Also, if the fin was longer the centre of lift would move forwards unless the fuselage was made longer. And a longer fin would need to be thicker to maintain any thickness to chord ratio as constant, for aerodynamic reasons.
cobra27
Wed May 08, 2013 11:37 am
Quoting Starlionblue (Reply 17):
It could have been Cessna 150, I don't remember exactly. Majority of customer choose swept tail because of look.
And I don't think Mooney straight tail is for distinct look only.
Take a look at this airplane Pipistrel Virus
http://en.wikipedia.org/wiki/Pipistrel_Virus
http://www.pipistrel.si/plane/virus-sw/overview
It has a small rudder, again for better aerodynamics. But is harder to fly coordinated turns, you have to use rudder pedals really hard
Wed May 08, 2013 11:47 am
Quoting cobra27 (Reply 27):
Umm, no. They chose the swept tail because that's what was offered by Cessna.
You are seriously overestimating the aerodynamic impact of a swept tail on a light piston.
CaptCufflinks
Wed May 08, 2013 12:00 pm
They're effectively the same aeroplane, a few differences but nothing that major.
I'm almost 3,000% sure he was joking with you.
ptrjong
Wed May 08, 2013 6:23 pm
Quoting cobra27 (Reply 25):
Yes, early 150s had a straight tailfin. Early 172s, too.
Photo © Peter De Jong
Photo © Peter de Jong
And you're saying this fin has better... range? Please clarify.
[Edited 2013-05-08 11:24:09]
cobra27
Wed May 08, 2013 6:46 pm
On some versions it is even more straighter.
ptrjong
Wed May 08, 2013 7:15 pm
Oh, so what?
filler blah blah
boeingfixer
Wed May 08, 2013 11:26 pm
Where do you come up with this information? It's just making me scratch my head.
The 152 has always had the same swept back tail as the 150, except for those 150's built prior to 1966 with the straight tails. If you're comparing range between the straight tail 150 and a swept tail 152, there are a few variables to decrease the range of the 152 without taking the straight tail into account. First is the larger engine on the 152 and secondly is the higher empty and gross weights of the 152. The 152 has an almost 10% higher empty weight and an engine with 8 more horsepower than the 150. to loose only 3% in range is testament to the swept back tail and overall design improvements.
As far as the Mooney is concerned, do you have any verifiable data that the Mooney would be slower with a swept fin? The overall design of the distinctive Mooney tail has it's genesis with the Mite. The design incorporated an entire movable tail, for pitch trim, which actually changed the sweep of the vertical fin.
Quoting cobra27 (Reply 31):
If this is a comment regarding the Cessna straight tails on the 150 and 172's all I have to say is, Huh!? Really, no, Really..... you need to do some serious research before you blurt out random thoughts as fact.
John
Cheers, John YYC
TSS
Thu May 09, 2013 5:27 am
I assumed that was what he was talking about from the beginning, and I dismissed the idea as impractical for the reasons you've listed in your post.
That being said, I'd think a V-tail configuration would be a much more reasonable way to reduce the drag caused by having three stabilizers on the rear of a conventional aircraft, but I'm not familiar enough with the drawbacks of the V-tail configuration to know if it would work on an airliner or even if it has been considered for that role.
Thu May 09, 2013 5:58 am
Quoting TSS (Reply 34):
There's an idea. It certainly decreases drag. The extra complexity of control input vs surface output should not be a big issue on a FBW airliner.
I think pitch trim would be a problem. Any pitch trim movement of the entire surface would entail added drag as the surfaces converge and diverge along the yaw control direction.
cobra27
Thu May 09, 2013 9:13 am
V-tail seems workable
Quoting boeingfixer (Reply 33):
No I have no data, its no brainer.
On jets like 737 you need swept wing, because of higher speed. But am not 100% on it
Thu May 09, 2013 9:33 am
Quoting cobra27 (Reply 36):
How is it a no brainer? Please explain.
Technically you don't need a swept wing but it is a very good idea. It has to do with delaying shockwave formation at transonic speeds.
rfields5421
Thu May 09, 2013 11:58 am
The Mooney forward swept tail fin is a marketing device. Pure and simple.
rfields5421
Thu May 09, 2013 1:13 pm
I guess my years in the US Navy made me focused on the word "fold" which has a very different meaning than the F-14 swept wings.
cobra27
Thu May 09, 2013 2:20 pm
We love to fly. Fast.!!!
May I propose a question:
How much of the total drag does 737 or A320 goes to tail?
roseflyer
Thu May 09, 2013 3:24 pm
Quoting cobra27 (Reply 40):
Are you talking about the verticial stabilizer? If so, very little because there is no induced drag in cruise. There is only parasite drag. The horizontal stabilizer produces far more drag since it produces induced drag as well. I gave you an idea about that, but you seemed to ignore it.
Viscount724
Thu May 09, 2013 7:43 pm
Why don't they design the vertical stabilizer so the entire stabilizer can pivot around a central point, similar to the way the entire horizontal stabilizer on most larger aircraft can pivot around a central axis. It seems to me that if the vertical stabilizer could pivot the same way (and not just the rudder) it would permit a smaller vertical stabilizer. It wouldn't have to be used very often, but for example in the event of an engine failure on takeoff, if the stabilizer could pivot in addition to the rudder, it would provide enough side force to keep straight without the need for a very tall stabilizer as on aircraft like the A380 and 747SP.
Quoting Stitch (Reply 16):
Photo:
http://www.ovi.ch/b377/articles/speedbird/hangar.jpg
thegeek
Thu May 09, 2013 11:29 pm
Presumably, or they'd be doing it.
Quoting Starlionblue (Reply 35):
Interesting thoughts. Indeed the entire negative lift required from the stabiliser would have a self cancelling component so you would have a loss there. I don't see where the benefit comes in, actually, except shorter total protrusion. I doubt that would cancel out the aforementioned loss.
cobra27
Fri May 10, 2013 9:00 am
Quoting rfields5421 (Reply 38):
Am a little confused with the terminology used. Is it really forwardly swept? Looking at the pictures is straight - perpendicular to the airflow. If you make it that way, you can have a smaller fin
[Edited 2013-05-10 02:00:51]
Fri May 10, 2013 10:52 am
Quoting cobra27 (Reply 44):
The leading edge is perpendicular to airflow. The trailing edge is forward swept.
I still don't understand how you can make a smaller fin that way...
rfields5421
Fri May 10, 2013 1:05 pm
The forward edge is vertical, the rudder side is forward swept.
Mooney photography for their website and brochures is shot at an angle to make the optical illusion that the stabilizer is forward swept to enhance the impression of speed.
Mooney sells their aircraft based on the marketing of the aircraft speed, not fuel economy.
Klaus
Fri May 10, 2013 3:02 pm
Quoting Viscount724 (Reply 42):
You'd need a rather massive hinge mechanism for that, even more massive than the one for the horizontal stabilizer (which is already substantial), because that one is symmetrical which keeps the resulting bending moment on the hinge at balance because the entire horizontal stabilizer is just one single piece with an integral beam running through the fuselage, linked to a common hinge and a motor-driven trim screw.
An all-moving vertical fin would concentrate a very large asymmetrical bending moment (not least because of the long, single moment arm) in the hinge assembly as a single point of failure, which would also require substantial structural support to transfer those loads safely to the fuselage.
There are fighter jets with such all-moving fins as far as I'm aware, but they are geared for performance first and foremost, with economy (=range) as secondary concerns. Plus, their pilots have ejection seats.
The conventional static fin bolted to the fuselage in multiple places (thus distributing the load) and with split rudders for increased redundancy looks like a pretty good idea for airliners which need to be safe and efficient above all else.
[Edited 2013-05-10 09:02:15]
cobra27
Fri May 10, 2013 6:14 pm
Quoting Klaus (Reply 47):
Which one? Almost all fighter have horizontal moving fins, but what about vertical?
Klaus
Fri May 10, 2013 7:24 pm
