cobra27
One Engine Cruise
Tue May 07, 2013 10:20 am
Idea is to reduce drag (the same as my previous topic    )
More than 90% commercial airplanes are twin engines because of efficiency not only fuel but also maintenance and purchase cost.
Two engines, like todays aircraft would be used for TO, LDG and Climb. When the plane reaches crusing altitude, one engine stops and folds into the fuselage. Engines should be placed in tail like MD-11, 727, DC-10 not like 737 pr A320
The cruising engine would be more powerfull than comparable engine on classic 2 engine aircraft, because only one engine would have power the aircraft.
I also have one question: if you place engines in the tail, do you get drag reduction (because jet exhaust goes into wake of the plane), or is it better to place them under wing?
Your thoughts?
RE: One Engine Cruise
Tue May 07, 2013 10:39 am
Quoting cobra27 (Thread starter):
Any savings would be eaten by the extra weight and complexity of this solution.
Advantages and disadvantages. Disadvantages prevail. The exhaust mixing with the wake is not an issue in any case.
mandala499
Tue May 07, 2013 11:06 am
1. Maintenance:
That retraction and extension mechanism is going to be a nightmare to do, add weight, complexities, hence: more maintenance costs from that system.
2. Engine wear and tear:
The remaining engine would have its life used up pretty quickly... and that engine would run at higher cruise settings, adding to the wear and tear.
3. Waste of space:
Where are you going to put the engine when folded? Into space that would otherwise be usable for revenue generation purposes.
Add 1, 2 and 3... the savings go up in smoke pretty quickly.
A less complex method have been used in the past, that is to use booster engines for take off. The Trident had some versions with a 4th jet used for take off only... well... they don't use that method anymore for a reason. Some of the Antonov-2* series also had that additional jet option to augment the turboprops... the P-3 Orions had those too. Once more powerful engines became available (with the benefits of lower maintenance & fuel for lower thrust use), the augmented engines quickly became history.
There is a reason why those methods aren't used anymore.
Have you seen the single engine cruise performance tables of modern day twins? Lose an engine, you'll end up cruising at lower altitude and at higher power... and negates any fuel savings gained from shutting that engine down.
On the off note, it is probably going to be lighter to put an aerodynamic cone extension/retraction capability for such a system instead of retracting the whole engine into the fuselage... and if the system fails, take out hydraulic/pneumatic power, releases the locks, and the cone slides back leaving the engine intake open like in normal operations.
And the only airplanes I know that regularly shut down engines in-flight are the RAF Nimrods (thanks to the in-wing engines), where for low-level patrol speeds, they shut 2 engines down and fly on the remaining 2... and when they want to go back to base, they relight the 2 engines and go back to base on 4 engines.
Mandala499
cobra27
Tue May 07, 2013 12:01 pm
Quoting mandala499 (Reply 2):
It would be a more powerful engine, so there wouldn't be high cruise setting. Bigger turbofans have lower specific fuel consumption (SFC) Altough the number of cycles on a helper engine would be lower, thats for sure
Quoting Starlionblue (Reply 1):
it would only be small increase in weight, and not more complex, a folding mechanism a nightmare, why? Compared to hydraulics and piping in the engines?
Some howitzer shell have a much more range when they use gas at the end to reduce drag.
Tue May 07, 2013 12:13 pm
Quoting cobra27 (Reply 3):
Apples and oranges. Howitzer shells are not self propelled.
Way more complex.
mmo
Tue May 07, 2013 12:26 pm
Your thoughts?
1) What would you do in case of an engine failure in cruise? I can picture it now, an aircraft descending with no engine running, no cabin pressure somewhat out of control. Having the one "helper" engine would not solve any problems. It would have large enough to sustain flight on one engine.
2) Twin engine ops are there for a reason.
3) Can't see it because of the complexity and redundancy that would be needed in the setup.
4) Are you taking two engines on the centerline? Otherwise you will have drag from the asymmetrical thrust and resultant rudder required for coordinated flight.
Just some quick thoughts.
cobra27
Tue May 07, 2013 2:00 pm
Close to centerline, like 727.
And 2 engines would there be for redundancy
Quoting Starlionblue (Reply 4):
Some have gas at the end to reduce drag.
My point if engine in wing reduce drag, or is it the same as under the wing
mmo
Tue May 07, 2013 2:20 pm
Quoting cobra27 (Reply 6):
Then I have to ask, why not just have two engines to begin with? Much simpler and easier.
Close to centerline will mean adverse yaw which means rudder which means increased drag. Again, why not just two engines as it exists not?
cobra27
Tue May 07, 2013 4:39 pm
That is the reason that most airplane are 2-engine and not four engine.
Somehow I think a single engine would reduce fuel consumption and increase range of the aircraft. On longer flights you burn fuel just to carry the fuel, not short hops.
I think 767/787/A330 would be ideally suited.
Two engines compared to one engine has more frontal area
mandala499
Tue May 07, 2013 5:33 pm
I dunno if this is bad news... but...
2x 30,000lbs engines at cruise will burn about 2.5 tons an hour using current technology... hauling 70 tons of aircraft.
2x 60,000lbs engines at cruise will burn about 5 tons an hour using current technology... hauling about 140 tons of aircraft...
sure, looks good for your argument... But... lose one engine on that widebody, you'll have to go down 15,000ft from your cruise altitude, burn 5.5 tons of fuel an hour, and go 80 knots slower.
The sad truth is, 2 engines will burn less than one the same engine taking the burden of 2 engines.
Besides, look at it again... 2x30,000lbs burns 2.5 tons an hour... so what happens if you replace those two engines with 1x60,000lbs engine at cruise... you'd still burn 2.5 tons, but now have extra weight to carry (you still got that one other 60,000lbs engine folded somewhere remember), you'd end up burning MORE than 2.5 tons.
And those numbers are from actual performance numbers, not some SFC number...
1. Engines are not light... they are certainly heavier than landing gears... now see how much work goes into the landing gear, how beefed up the thing is... etc etc etc...
2. The mounts retracting and extending, the whole mechanism has to be able to support the engine thrust pulling the aircraft along... certainly gotta have to be way beefier than landing gears...
3. Plumbing? Bleeds? Electricals? Hydraulics? etc etc...
Close to centerline? Like 727? OK, how are you going to do it?
1. High Bypass turbofans need clean airflow coming into the fan... put it near the body and you'd start having aerodynamic challenges... otherwise, throw out the fuel economy.
2. Mounting hi-bypass engines on the tail is a LOT more complex than low-bypass... that's why we don't see widebody twins with tailmounted engines. The DC-10 and MD-11 was a structural nightmare. The Tristar, well, the center engine can't behave as reactive as the wing engines due to the S-duct...
3. How are you going to fold an efficient high bypass engine into a smaller than the usual cross section part of the plane?
Are you going to put the engines left and right of the rear body, and then fold one in during cruise? Will you have the option of folding either of the two engines, or just one side gets folded in? And then there's lateral structural loads on the vertical fin when cruising with one engine folded... and then... trim drag...
How do you keep the aircraft flying pressurized and with electrical and hydraulic power should that cruise engine decide to go and have an uncontained engine failure or just simply... fail...?
How long would it take to flip out the other engine and start it up?
What are you going to use to start that engine up?
Bleed? Well, where's the source going to come from? The failed engine? Won't work...
Electrical? Well main AC power would lose it's main source... DC will drain the battery too... and RAT will only generate enough for critical systems (and HYD too).
APU?    Is the airplane in the APU starting envelope or not? Will the APU at that altitude be able to generate Bleed and ELEC or only one of the two? Not all APUs today can start at 35,000ft and provide Bleed and ELEC at that altitude.
And then... after all that... the other engine that you now want to start, is out of it's starting envelope... so you have to drift down to its starting envelope altitude and speed before starting it and restore power, elec, bleed, etc...
Drifting down... consumes the battery power too... will you have battery power by the time you enter the starting envelope?
Engines IN wing has less drag than engines under wing.
Engines IN wing is structurally more complex than engines under wing.
Engines IN wing has critical systems and structure damage risk when the engine goes kaboom or catches fire, than engines under wing.
Quoting cobra27 (Reply 8):
But as you see above... for the same weight, having 1 bigger engine instead of 2 smaller engines, burns more for the same engine technology generation.
cobra27
Tue May 07, 2013 8:17 pm
Wow what a long reply!
Quoting mandala499 (Reply 9):
Off the topic, but
numbers of fuel burn seem a little low esecially if you take for example A320 which has less powerful engine and runs at nearly maxi weight. I think 3 tonnes at that weight would be more appropriate.
Anyway it is just a discussion, I didn't consider all the possibilities.
Engine failure would be probably the biggest obstacle. More powerful APU would solve the electrics and pressurisation
But to show what was my point:
747 or A380 could do perfectly well or better with 3 engines in cruise
I am not proposing building a single engine airliner, just one engine for cruise
mmo
Tue May 07, 2013 8:32 pm
Quoting cobra27 (Reply 10):
I know of no APU that can supply bleed air for pressurization and complete electrics at altitude. In addition to bleed air for pressurization, you will need bleed for engine start.
I feel as if this keeps coming back to the same issues, which you seem to just gloss over.
In reality you are!
Viscount724
Tue May 07, 2013 8:45 pm
I can't see any certification authority ever certifying an airliner designed to carry a few hundred passengers that could potentially become a glider if the one operating engine failed.
mandala499
Tue May 07, 2013 9:12 pm
3 tons for a 1 hour flight yes, but we're talking about cruise fuel burn, not trip burn. An A320 at 70tons landing weight flying for 375NM will burn about 3tons for the trip at 0.78mach cruise... which takes 1Hr02mins.
Those numbers I picked are from operational performance manuals for A320 with CFM56-5B engines for the narrowbody, and 767-300 (PW4060) for the widebody.
I know
But I did those numbers just to give a little dose of reality to the idea...
One major obstacle to your idea would be certification of redundant system requirements... You can kiss ETOPS goodbye with your idea, not only because of the "single active engine and the other stowed", but also due to requirements for requiring 2 separate generators from 2 powerplant sources to be online on the ETOPS portion of the flight, plus numerous other redundancy requirements... usually dependent on having 2 engines for the electrics and hydraulics. So your idea unfortunately will not be allowed for flying more than 60mins from a suitable airport.
roseflyer
Tue May 07, 2013 10:15 pm
Airplanes cruise at about 80-90% N1. At altitude the amount of thrust available is only 30-40% of what is available in denser air near the ground. If a twin engine airplane loses an engine in cruise, it usually drifts down 10,000ft or so (depends on airplane) due to its inability to remain in level cruise in the thin air above 30,000ft. In order to be able to cruise at conventional altitudes, you are going to have to drastically increase the size of your one primary engine. Your second backup engine won’t be able to shrink because the plane has to be able to take off if you lose your primary engine. All that one engine cruise did is forced you to put a larger engine on the airplane and probably made fuel burn worse.
cobra27
Wed May 08, 2013 9:56 am
Quoting Roseflyer (Reply 14):
I think 757 engine size would work on A320 size platform.
I think that if you have optimal engine specially designed for cruise (not overbuilt), you got lower consumption.
[Edited 2013-05-08 03:09:41]
roseflyer
Wed May 08, 2013 3:15 pm
Quoting cobra27 (Reply 15):
It's an interesting concept, but one engine working harder is not necessarily better. For example, in a L1011, if the center engine was shutdown in cruise, overall fuel burn goes up. And I don't think a retractable engine is possible.
Also, engines are already optimized for cruise.
cobra27
Wed May 08, 2013 5:32 pm
Quoting Roseflyer (Reply 16):
Yes because not working engine has the highest drag, because it has a hole, it has real bad aerodynamics.
Engines aren't optimized for cruise. They have to provide take off thrust which is around 4 times higher than cruise thrust
KC135Hydraulics
Wed May 08, 2013 6:37 pm
Quoting cobra27 (Reply 17):
People here have already demonstrated numerous reasons why this concept is not economically feasible but you continue to argue the point despite it, so why even bother asking for our thoughts? Move forward with your concept and we'll see how far it gets. I'm sure if it was a viable plan it would have already been attempted
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
roseflyer
Wed May 08, 2013 6:44 pm
Cobra,
I appreciate you coming up with clever ideas to reduce drag. Innovation is a great thing, but I don't think you are on the wright track.
One thing that Boeing has played around with in the past and has a lot of opportunity to reduce drag is to replace the horizontal stabilizer with a lifting canard. With a canard, you can have the canard and wing both producing positive lift during climb and cruise. With a tail mounted horizontal stabilizer, the elevator creating downward lift relative to the wing, which requires the main wing to get even more lift during climb and nose up attitudes. If you put a canard in the front with the elevators forward of the wing, both lifting surfaces are positive and induced drag drops dramatically. A lifting-canard generates an upload, in contrast to a conventional aft-tail which generates negative lift that must be counteracted by extra lift on the main wing. As the canard lift appears to increase the overall lift capability of the aircraft, this may appear to unambiguously favor the canard layout.
The problem with a canard is stall recovery and stability. The downwash has a negative effect on the main wing as well. These problems can be solved. A lifting canard configuration is inherently unstable unlike a rear stabilizer which is inherently stable, so you have to over come this with the control system. With the latest fly by wire software, commercial airplanes are moving away from being inherently stable throughout their entire flight envelope. The canard also has to be designed to stall before the main wing as well, which requires some creative engineering. In general it is really hard to do, but possible and would greatly reduce induced drag. I think it is a much better idea than retractable engines, vertical stabilizers or other control surfaces.
It sounds like you have an underlying assumption that airplanes have excess power at altitude and aren't optimized for cruise. In reality they don't have excess power. They may take 4 times more power at takeoff, but that's also because the denser air and slower speed allows much more thrust. At altitude an engine is only capable of about 30-40% of the thrust that it is on the ground. At cruise engines are running at 80-90% of available power. If you push the engine harder, then you are going to tear it up and require more frequent overhauls.
Your one engine idea either requires a much larger engine (75% more powerful), which is going to add a lot of weight and kill any efficiency gains or forces an airplane to cruise in the 20,000ft range with the turboprops which is not ideal cruising altitude for drag.
[Edited 2013-05-08 11:55:08]
oly720man
Wed May 08, 2013 10:37 pm
They are optimized for cruise (just like the wings are optimized for cruise). That's what they spend 80% of their life doing. What that means is the performance is less efficient at take off it doesn't mean they can't achieve take off thrust.
cobra27
Thu May 09, 2013 9:07 am
I had something different in mind.
Bigger fan that has fewer and more aerodynamic blades. Possibly geared turbofan. I think slower rotating fan has advantages
And that engines exhaust that exits in the wake of the plane (in the tail).
Thu May 09, 2013 9:09 am
Quoting cobra27 (Reply 21):
What's up with the perceived need to put the exhaust in the wake of the plane?
Slcpilot
Thu May 09, 2013 1:36 pm
This has been an interesting thread with most replies being in the "con" area. There are two examples; however, that suggest the idea might not be as outlandish as many suggest.
It is my understanding Boeing considered a thrusting APU for the 777-200LR in early iterations. Now this obviously didn't happen for engineering/economic reasons, but it was studied enough to make it into the public domain. Most of
us here aren't privy as to how close that trade off study was.
Another non-121 solution that involved an engine being shutdown was the Voyager flight in 1986. While I agree, single engine Part 121 turbine flight is unlikely now, who is to say a 3 engine solution defaulting to 2 engine cruise won't ever work? Most would agree the Voyager was very optimized for efficient flight, which is what we're all after, right?
Thoughts?
SLCPilot
I don't like to be fueled by anger, I don't like to be fooled by lust...
cobra27
Thu May 09, 2013 2:11 pm
Quoting Starlionblue (Reply 22):
In the wake of wings, but that seems impossible. The wake of the body more likely.
Like cyclists in peloton . The driver behind gets up 40 % less drag, am not sure but front driver also benefits from it but not as much.
Quoting Slcpilot (Reply 23):
naysayers
26point2
Thu May 09, 2013 2:47 pm
A folding vertical stab with attached engine sounds like a mechanical nightmare.
Here's mine.....we know fuel can be close to half the total weight of a long range airliner at takeoff. Huge amounts of fuel are used to lift more fuel. Why not takeoff with minimum fuel and incorporate mid-air refueling? This could allow the use of smaller and more efficient engines saving even more fuel.
Edit: spelling
[Edited 2013-05-09 07:49:33]
7BOEING7
Thu May 09, 2013 4:04 pm
Actually the P-2 Neptune which had 2 recips was equipped with 2 jets, the P-3 had 4 turboprops and didn't need the jets.
Quoting mmo (Reply 11):
Quoting cobra27 (Reply 10):More powerful APU would solve the electrics and pressurisation
Inflight starts do not use the APU if there is sufficient airspeed for a windmill start which is normally the case.
If they wanted to fly at a lower less efficient altitude. One of the airplanes that flies this way is the P-3 Orion which will "loiter" with either #1 or #4 or both shutdown. However when they do this they are interested in staying airborne longer not getting from A to B -- they are at a very low airspeed and a much lower altitude. This is an efficiency that works with a turboprop but not a pure jet.
mandala499
Thu May 09, 2013 5:03 pm
Good luck to that. The A320 engines are physically capable of producing 33,000lbs at take off (and used as such on the A321), the 757 engines are 40,000lbs take off thrust range...
So how and where are you going to fold that engine into again?
On the efficiency front, the primary criteria IS cruise efficiency. On the power front, the primary criteria is take off thrust.
Quoting 7BOEING7 (Reply 26):
D'oh! Silly me! Yes! the Neptune! Why I typed P-3 I dunno!
That makes it the Nimrod and P-3 then...
If you're outside the windmilling in-flight start envelope, then you'd need either a motor start or a bleed start...
cobra27
Thu May 09, 2013 5:42 pm
Quoting mandala499 (Reply 27):
I didn't know they are so powerful, real Hulks.
Quoting 26point2 (Reply 25):
It has been discussed a lot. Also a fuel stop uses less fuel than lets sen 8000nm trip. But the hole process of inflight refuelling is kind dangerous
mmo
Thu May 09, 2013 6:48 pm
Really???? Then perhaps you could tell me why both Boeing and Airbus have that applicable section in their QRHs?
I guess the reference to APU bleed is something to be disregarded...................
Please note the qualifier you have written ....IF
7BOEING7
Thu May 09, 2013 8:02 pm
Quoting mmo (Reply 29):
Quoting 7BOEING7 (Reply 26):Inflight starts do not use the APU if there is sufficient airspeed for a windmill start which is normally the case.
Chill out.
Since you can dispatch with an inoperative APU and the 747 APU can't be started in flight, I was just pointing out that in flight if you needed to relight the engine you always had the ability to due a windmill start. That's why there's an "IF" there. In fact faced with an in flight start requirement (very unlikely these days) most crews would already have the airspeed required for a windmill start or would accelerate to get it rather than wait to descend to a much lower altitude when the APU finally becomes available for a cross bleed start. The times an in flight start has been accomplished through either method are rare and generally have something to do with a volcano.
Thu May 09, 2013 11:14 pm
As mentioned above, it has been discussed at length on this forum. In flight refueling is expensive (gotta send up that other plane) and risky.
Quoting cobra27 (Reply 24):
Sorry but I still don't understand what you are trying to say. Do you mean that an engine in the tail is less draggy because of some sort of interaction with the exhaust?
Mir
Fri May 10, 2013 12:50 am
That's why people have talked about formation flights, but that wouldn't help a single airplane. An airplane's exhaust is going to be caught up in its wake anyway, since the wake is at least as wide as the wingspan.
-Mir
thegeek
Fri May 10, 2013 1:15 am
You'll have a friend in keesje in this one, who is a fan of a thrusting APU as a third engine. That no manufacturer has gone with that idea tells you something.
mandala499
Fri May 10, 2013 3:32 am
For 777 & 787 (GE & RR): The QRH does also say for dual ENG fail (which would be applicable in this topic's discussion), "IF" APU available, then start it... However since the 777 APU cannot supply bleed below FL220 (and for 787 doesn't use bleed air start), I guess they put APU start in DUAL ENG FAIL checklist for ELEC needs. For both 777 & 787, GE needs 270KIAS prior to windmill start, and RR needs 250KIAS).
For 320/330/340, in the DUAL ENG FAIL (Fuel Remaning), the APU is stated "WHEN BELOW FL250, APU (if operative...START)".
At high altitudes, yes, Bleed for start is to be disregarded.
And for Cobra27... The inflight start can take longer than 2 minutes per engine...
naysayers
Not naysayers, but economics. We didn't have Tristars, DC-10s, MD-11s, Tridents, 727s and Tu154s shutting down the middle engines in cruise...(yea yea yea, we know about the "draggy hole"). The nearest to this is the Super 727, with the bigger 1&3 engines, keeping the #2 original engine and used more as a boost engine... (but even that's not shut down in flight AFAIK).
In the wake of the wing is not impossible... have an in-wing engine.
You want the engine intake or exhaust in the wake ?
For efficient operations, you want the engine intake not in the wake of anything... the exhaust don't really matter.
With your idea of having only 1 engine running and the other is folded in... you want the engine to be in clean airflow to reduce risks of compressor stalls and surges (which leads to engine failures).
Pihero
Fri May 10, 2013 8:59 am
Quoting Roseflyer (Reply 19):
I love it ! You made my day !
To be serious again, the **only** airliner I know wich could and did shut an engine down in flight was the HS Trident 3.
[Edited 2013-05-10 02:20:22]
Contrail designer
cobra27
Fri May 10, 2013 9:03 am
Quoting Starlionblue (Reply 31):
Quoting mandala499 (Reply 34):
You have a point. I looked at show Blended Wing Body design, and there were no inwing engine like B-2 bomber
oly720man
Fri May 10, 2013 2:07 pm
Quoting cobra27 (Reply 36):
Commercial aircraft don't need low observability.
Having buried engines means a compromised inlet flow which isn't good for performance efficiency.
mandala499
Fri May 10, 2013 4:00 pm
Quoting Pihero (Reply 35):
You mean it took off on 3.5 engines, climbed on 3 and cruised on 2 engines?
cobra27
Fri May 10, 2013 6:13 pm
Quoting oly720man (Reply 37):
Like Lockheed Tristar middle engine? As oposed to MD-11 engine?
oly720man
Fri May 10, 2013 10:04 pm
Quoting cobra27 (Reply 39):
No, like in a B2, though the S bend on the Tristar, B727 and Trident is less good for the engine performance than a straight duct.
wingscrubber
Tue May 14, 2013 9:08 am
A lot of negative in this thread! This concept is achievable, but the motivation and benefit for doing so is the question.
I think the best example of auxiliary engines shut-down in flight is the B-36 peacemaker, which augmented the props with 4 turbojets, but the only reason for doing so was the limited turbine technology available at the time, together with the range requirements of the aircraft. The turbojets of the era were too thirsty to achieve the required range, but the props alone weren't powerful enough to allow the aircraft to take off, so it had to carry spare engines, but they were not retractable and dangled in the slipstream causing a drag penalty for the remainder of the flight.
http://en.wikipedia.org/wiki/Convair_B-36
But the golden example of a drag-reducing retractable jet engine has to be this-
http://www.gizmag.com/bonusjet-glide...h-jet-engine/16017/picture/119190/
But this is clearly for a niche application, with a very small jet   Achieving the same thing with an RB211 on an airliner would be a bit more challenging, and the drag penalty reduction wouldn't be worth carrying the weight, might as well just use the engine rather than tuck it away.
Airliners with JATO installed is a worthy concept though, no?  http://www.youtube.com/watch?v=97rSobuKBxI
Resident TechOps Troll
Tue May 14, 2013 9:20 am
Cost ineffective
Added weight
Complex mechanism
Assymetry chances.
Pihero
Tue May 14, 2013 12:20 pm
Quoting wingscrubber (Reply 41):
... or a runway built like a huge conveyor belt
Contrail designer
cobra27
Tue May 14, 2013 7:38 pm
Well if it is not double digit improvement it is not worth doing it.
7BOEING7
Tue May 14, 2013 7:44 pm
The option was available on 727's for Mexicana Airlines out of hot/high Mexico City way back when.
http://www.youtube.com/watch?v=G7LErwBNobU
cobra27
Thu May 16, 2013 5:20 pm
Quoting HAWK21M (Reply 42):
Cost ineffective - Yeah really?
Added weight-yes but considering you burn less fuel, the takoff weight should be lower for the same distance, otherwise is not god doing it
Complex mechanism- maybe you don't need a foldable engine, just a aerodynamic fitting over inlet
Assymetry chances.
Small assimetry like 2 engines in tail don't produce so much assimetry
Users browsing this forum: Bing [Bot] and 2 guests
