Reggaebird
Boeing 747-400 Wing Variances?
Sun May 12, 2013 7:15 am
Hello,
I was out plane spotting and saw a BA 744 landing, immediately followed by an AF 744. I made videos of both landings and, upon review, noticed that the flaps look different on the two birds. So I thought I would ask the following. Other than engine type-related variances, are there any major mechanical variances in the wings/flaps of the BA and AF fleets? I thought that all 744s were pretty much the same, with the possible exception of the 744ER.
The visual difference in flaps that I am referring to can be seen at 0:24 (BA) and 2:24 (AF) in the video link below.
http://www.youtube.com/watch?v=ojsnpUnh2Qw
Any insight would be appreciated.
Thank you
[Edited 2013-05-12 00:19:10]
747classic
RE: Boeing 747-400 Wing Variances?
Sun May 12, 2013 8:09 am
Probably BA performed a flaps 25 landing
Seen the increased spacing between the TE flap segments, AF performed a flaps 30 landing.
On all 744 series, incl. the 744ER, the TE flaps are identical.
[Edited 2013-05-12 01:32:16]
Operating a twin over the ocean, you're always one engine failure from a total emergency.
Reggaebird
Sun May 12, 2013 10:51 am
Quoting 747classic (Reply 1):
Thank you for the information. That begs the question why the different flap configurations for the same flying conditions? However, I suspect I will need to go to flight school to learn that answer.
Ronaldo747
Sun May 12, 2013 10:55 am
Quoting Reggaebird (Reply 2):
IIRC for saving fuel the approach with flaps 25 is quite common with BA 747s at Heathrow.
747classic
Sun May 12, 2013 11:24 am
A lot a variables can influence the decision for a flaps 25 or flaps 30 landing :
- Landing weight
- Runway length
- Local noise regulations (idle reverse, upon landing))
- OAT
- Field elevation
- Autoland
- Aircraft defects (one brake U/S, reverser U/S )
- Company policy (fuel saving - noise avoidance)
- Maintenance costs (flap tracks - brake wear)
But, in the end it's always the captain's decision.
[Edited 2013-05-12 04:29:02]
jetmech
Mon May 13, 2013 4:28 am
As stated by 747classic, and amongst other reasons, the particular procedure for each airline has a lot to do with landing flap choice.
One airline made the choice to do flap 25 landings as a standard procedure, to reduce noise fees as well as TR and flap maintenance. Page 125 of the following also states that flap 25 landings were chosen to put more energy into the brakes, which actually decreased wear rates.
http://www.atsb.gov.au/media/24447/aair199904538_001.pdf
Regards, JetMech
Max Q
Mon May 13, 2013 5:45 am
F25 is also preferable in strong, gusty wind conditions.
Aaron747
Mon May 13, 2013 6:40 am
Quoting Reggaebird (Thread starter):
There are only four major variances you will ever find on 747-400 wings, and two of them are cosmetic:
1. The engine pylons differ significantly in size and shape depending on whether PW, GE, or RR are installed.
2. No winglets are installed on the -400D.
3. Some operators have a painted stripe on the 2nd and 3rd flap slots, while others are solid colored.
4. Some operators have a darkened area running the length of the center skin panel on tops and bottoms of the wings (the areas covering the fuel tanks)
Scooter01
Mon May 13, 2013 8:25 am
The Airliners.net Photo Search Engine is an amasing place to look up all sorts of things,
and truly amasing what one can learn.
By searching through "Aircraft Window Views" on the Boeing 747 flaps , you can see all kinds of landing-configurations,
from this:
Photo © Fyodor Borisov - Russian AviaPhoto Team
to this:
Photo © Hayk Martirosyan
ending up with:
Photo © Andries Waardenburg
All series Boeing 747 featured triple slotted flaps, ECEPT the -SP which had a double pivot, single slot flap:
Photo © Sam Chui
Scooter01
Mon May 13, 2013 8:37 am
Quoting Scooter01 (Reply 8):
The -8 has single-slotted outboard flaps and double-slotted inboard flaps.
Scooter01
Mon May 13, 2013 8:53 am
Sorry, forgot about that one. (It's too new for me, haven't flown on one yet)
Scooter01
Mon May 13, 2013 8:59 am
Quoting Scooter01 (Reply 10):
Scooter01
No worries. The -8 throws people off.
[Edited 2013-05-13 01:59:54]
Viscount724
Mon May 13, 2013 6:47 pm
Quoting aaron747 (Reply 7):
-400D also lacks the wingtip extensions of other -400s to which the winglets are attached. It thus has the same wingspan as all earlier 747s.
Reggaebird
Mon May 13, 2013 9:01 pm
Are there any other large airliners that had/have triple-slotted flaps? Also, any thoughts on why the new -8 has discarded the triple-slotted design?
Mon May 13, 2013 11:40 pm
Quoting Reggaebird (Reply 13):
727. Ok so it isn't a widebody but definitely large.
Complexity costs both in construction and maintenance. With more modern aerodynamics Boeing could achieve the same performance without the triple-slotted design.
Same reason the 787 has offset hinge flaps and does away with flap tracks. Simpler and cheaper.
[Edited 2013-05-13 16:41:21]
[Edited 2013-05-13 16:43:01]
jetmech
Tue May 14, 2013 12:27 am
Quoting Starlionblue (Reply 14):
A great picture illustrating this;
http://upload.wikimedia.org/wikipedia/commons/5/51/Flaps_Mechanism_B787_A320.png
http://upload.wikimedia.org/wikipedi...5/51/Flaps_Mechanism_B787_A320.png
Regards, JetMech
Aaron747
Tue May 14, 2013 1:16 am
You can also find the cosmetic differences in the flap markings and wing skin panels I mentioned above
Tue May 14, 2013 2:46 am
Quoting Jetmech (Reply 15):
Great pic indeed. Another neat feature on the 787 flaps is that the spoiler panels droop to cover some of the gap when the flaps extend.
dynamicsguy
Tue May 14, 2013 10:39 am
Good picture. I've never seen anything similar in the public domain. The 787 angle is wrong though.
Quoting Starlionblue (Reply 17):
It came from the C-17, and is also a feature of the A350. The width of the slot is very tightly controlled on the 787.
Users browsing this forum: BravoOne, rmilstre, Woodreau and 21 guests
