hivue
Probes On Nose Of A350XWB
Tue May 14, 2013 10:29 pm
I tried this over on the civ av forum and got no bites, so I thought I would try it here.
http://www.airbus.com/fileadmin/medi.../A350_XWB_paint_shop_rollout_8.jpg
There are 12 probes clustered around the nose. Air data I assume, AoA vanes maybe, maybe some others. Are some of these only for test? I haven't seen anything that looks like a pitot tube anywhere else on the fuselage in the AB photos. WiIl this be the final home for all these probes on the production aircraft? Can anybody name all of 12 of the probes?
RE: Probes On Nose Of A350XWB
Wed May 15, 2013 12:19 am
I wish we could get a a better angle. These help a bit: http://www.airbus.com/fileadmin/medi.../A350_XWB_paint_shop_rollout_7.jpg
http://www.airbus.com/fileadmin/medi.../A350_XWB_paint_shop_rollout_9.jpg
My very wild arsed guesses going clockwise from bottom left to bottom right and ignoring the static ports (in the flat areas).
1. OAT probe.
2. AoA vane.
3. AoA vane.
4. (in middle group). Pitot.
5. Test article for airflow measurement?
6. Test article for airflow measurement?
7. Test article for airflow measurement?
8. Pitot.
9. ?
10. AoA vane.
11. Test article for airflow measurement?
12. OAT probe.
[Edited 2013-05-14 17:31:44]
hivue
Wed May 15, 2013 12:38 am
Quoting Starlionblue (Reply 1):
Thanks.
Yes, I should have linked to photos on both sides.
Is this arrangement unusually close tgether? It looks like a single bird strike could take out 2 AoA vanes.
I assume one pitot is the captain's and one is the FO's? So there must be another one somewhere else for the standby system?
GlobalMoose
Wed May 15, 2013 12:53 am
Continuing the numbering convention:
1. Icing probe
2. AoA vane
3. AoA vane
4. OAT(SAT)/RAT probe
5. AoA vane
6. AoA vane
7. AoA vane
8. OAT(SAT)/RAT probe
9. Pitot probe
10. AoA vane
11. AoA vane
12. Pitot probe
All a best guess - for the following reasons:
I'm used to seeing Items equally and oppositely divided on either side of the A/C which makes me wonder about my guess about the pitot probe
1. Looks like what we use in our jet and what is on the 744 (just prior to the wipers). It is a little piece of metal that vibrates (or doesn't, unsure) when ice builds up on it (pilot rumor)
2. Multiple AoA vanes - they look like they move around, just like an AoA vane would
4. Looks just like what we have on our jet (and this time I have been face to face with the probe and have read the labels on it)
9, 12. long, slender, tubular item with a hole in the front - looks like a pitot probe - but a bit confused as why they are only on one side.
We need an engineer - pilots only know so much (and usually specialize in how to break their jets!)
When it absolutely positively has to be there ... at some point.
Wed May 15, 2013 12:54 am
I think GlobalMoose's guesses are much better than mine.
Quoting GlobalMoose (Reply 3):
5. AoA vane
6. AoA vane
7. AoA vane
I think you are right in that they are airflow vanes, but I don't think they measure AoA due to location.
Quoting hivue (Reply 2):
You'd still have the ones on the other side. Also some of these probes may do double duty.
I don't know about the 350 but many large airliners have four pitots and four static ports, plus two standby static ports.
[Edited 2013-05-14 17:56:26]
[Edited 2013-05-14 17:58:53]
hivue
Wed May 15, 2013 1:25 am
Quoting Starlionblue (Reply 4):
Quoting GlobalMoose (Reply 3):5. AoA vane
6. AoA vane
7. AoA vane
So it sounds like this probe composition/arrangement may be special for the flight test campaign and is not intended to be the same as what will be on the production aircraft.
Pihero
Wed May 15, 2013 2:36 am
Difficult
Things have changed a bit these modern days :
Right side, from top to bottom :
- 2 MFPs, multi-function probes, they integrate Total Pressure / TAT / AoA sensors for ADIRUs 2 and 3
- 1 Pitot ( probably for tests as the usual Airbus STBY pitot is on port side )
Top of the nose, excluding the - you were right - ice detectors (2 electrical / 2 visual ), from left to right :
- 1 Pitot (Test I'd guess )
- 3 SSA probes ( side-slip angle, one for each ADIRU )
- 1 Pitot ( Test I'd guess )
Left side from top to bottom :
- 1 STBY Pitot ( for ISIS )
- 1 MFP for ADIRU 1
- 1 AoA sensor ( Test I'd guess )
- 1 TAT ( Test I'd guess )
( my best effort )
Contrail designer
boeingfixer
Wed May 15, 2013 3:43 pm
Here's my take on the probes.
Looking at the photo and going clockwise from lower left.
1. Ice Detector
2. Multi-Function Probe
3. Multi-Function Probe
4. TAT Probe
5 thru 7. Side Slip Vanes
8. TAT Probe
9. Pitot Probe
10. Multi-Function Probe
11. AOA Vane
12. Ice Detector
John
Cheers, John YYC
GlobalMoose
Wed May 15, 2013 5:30 pm
Makes perfect sense - you kind of need the AoA vanes to be oriented along the longitudinal axis and able to pivot up and down, not side to side!
airmagnac
Wed May 15, 2013 5:49 pm
Quoting boeingfixer (Reply 7):
1. Ice Detector
4. TAT Probe
8. TAT Probe
9. Pitot Probe
11. AOA Vane
12. Ice Detector
I agree with your take
Numbers 4 and 7 have big rectangular intakes which look more like TAT probes than pitot probes. Especially when compared to the stand-by pitot (nbr 9)
1 and 12 I'm not too sure, but they look the same. I'll go along with your idea of ice detectors
Wonder if the red markings may be a clue to indicate which ones are series probes and which are test probes
My goal as an engineer is to fill my soul with coffee and become immortal
Pihero
Wed May 15, 2013 6:41 pm
Quoting GlobalMoose (Reply 8):
That's why they are Side Slip Angle sensors
We need to agree on what we're talking about here : if you go clockwise from lower left, you go under the belly if you're an outside observer looking at the aircraft facing the nose.
I now stand by my first post... but I could be wrong. As a matter of fact, my only hesitation is on your #1, which IMO is a TAT probe reference for the top of the nose probes and could be, as Boeingfixer thinks an icing detector.
The most accurate view on this side comes from the rollout video.
http://www.youtube.com/watch?v=X61QDi1zEyQ
Starting at time .30 seconds, we see the left side probes : the difference between the MFP and the AoA ; The top pitot is clearly visible and the recognisable TAT probe at bottom.
Contrail designer
airmagnac
Wed May 15, 2013 9:23 pm
I haven't worked on air data probes for a few years, so technology might have moved on, but I remember the TAT probes being like pitot probes with bigger rectangular intakes ? After all, they perform a similar function of isentropic deceleration
Which is why I'd rather go for TAT sensors on either side of the SSA vanes on the nose. Or maybe some kind of MFP without the moving vane part (so just Pt and Tt measurement) ?
As for the 2 things on the bottom on either side, they look very much like the 2 on either side of the SSA vanes on the A380 :
http://www.airliners.net/photo/China...d=98b7e08c309196cadf158b50416d1042
In that view, the sensors really remind me of temperature sensors used in internal ductings. So maybe SAT/OAT probes ?
Pihero
Wed May 15, 2013 10:56 pm
Quoting airmagnac (Reply 11):
These are the A380 ice detectors.
I'd agree but that would make it 3 MFP + 1 TAT (left side ) + 2 TAT (top of nose ) = 6 TAT measurements, which seems to me rather a lot... on the other hand, I can't find any static ports associated with them. Those visible - 3 aligned on both sides of the fuselage belong to the ADIRUS, the two symetrically positioned under the cockpit windscreen are for the ISIS, so I'm for a search for aerodynamic data on this nose area.
(Based on previous Airbus solutions, the 380 in particular.
they measure TAT and compute OAT
1. Ice Detector
12. Ice Detector
Possible, but IMO, they are on top of the nose, under the windscreen. ( the center ones )
Contrail designer
Thu May 16, 2013 12:28 am
Quoting Pihero (Reply 10):
The confusion is was my fault. My nomenclature was clockwise from lower left from the viewpoint of the observer in the picture, not relative to the aircraft. Should have been clear about that.
airmagnac
Thu May 16, 2013 6:11 am
Quoting Pihero (Reply 12):
Je me coucherai moins bête ce soir, thanks !
boeingfixer
Thu May 16, 2013 11:55 pm
My list was from the viewpoint of the photo.
TAT probes and Ice Detector probes look and function totally different from each other. I don't "think" 1 and 12 are Ice Detectors, I "know" they are Ice Detectors. I've learned a bit after 23 years as a mechanic on transport category aircraft.
They are indeed Ice Detectors and are the same as those in position 1 and 12 on the A350.
1. Ice Detector
12. Ice Detector
Those items right under the windscreen are for the windshield wipers which have yet to be installed.
Correct me if I'm wrong but I thought the MFP's only measured AOA, Total Pressure and Static Pressure. This would leave only the 2 TAT probes outboard of the SSA Vanes.
John
Cheers, John YYC
Pihero
Fri May 17, 2013 1:00 am
Quoting boeingfixer (Reply 15):
No : they measure Pt / TAT / AoA . The static ports for the ADIRUS are aligned on the lower part of the fuselage, further back.
After having managed to enlarge the pics, I now think you're right. The video I linked apparently shows a shadow.
Mea culpa !
See this Goodrich description of their product :
Ice detection probe
As for the wipers, you're right, they are missing, but which ones of the six ?
Contrail designer
boeingfixer
Fri May 17, 2013 7:17 pm
Quoting Pihero (Reply 16):
Thanks for the info. Just found the patent here: MFP Patent PDF
Also a good photo of the MFP here: Multi Function Probe
I would hazard a guess that the extra 2 TAT probes are for flight test instrumentation.
Ice detection probe
Only the front windscreens have the wipers. The two large protrusions at the centre below the front windscreens are the posts that the wiper arms attach to. The two posts that protrude at the centre of the lower frames are Ice Detectors as well. Same thing as on the A380 HERE
John
Cheers, John YYC
Slcpilot
Sat May 18, 2013 6:09 pm
I was kinda hoping the same technology that allows the G650 to be in service without wipers might have made it to the A-350. It would certainly make for a quieter flight deck! I'm looking forward to this becoming more commonplace.
Also, it would be neat if the B-2s air data system could also make it into the civilian world. It doesn't have any probes/vanes, does it?
Cheers!
SLCPilot
I don't like to be fueled by anger, I don't like to be fooled by lust...
Klaus
Sun May 19, 2013 11:36 pm
Quoting Slcpilot (Reply 18):
How does that work?
Mon May 20, 2013 4:23 am
True, but the "pitot plates" are for low observability purposes. The fact that it uses non protruding sensors doesn't make it better for civilian applications I bet the B-2 systems are both more expensive and less reliable than the systems on airliners.
Slcpilot
Mon May 20, 2013 12:44 pm
It seems it's some sort of water repelling surface....
http://www.ppg.com/en/newsroom/news/Pages/20090408.aspx
The design for the heated glass windshields will be a carryover from the G550 jet, with Surface Seal water-repellent coating by PPG as the primary rain-removal system to enable Gulfstream to certify the aircraft without windshield wipers, which increase drag and weight.
Slcpilot
Mon May 20, 2013 1:05 pm
Quoting Starlionblue (Reply 20):
True, most designs are limited by a cost/benefit trade study. Let me share two personal experiences.
First, in the type of plane I most often fly now, the flight deck noise is often distinguished by which generation of wiper blade arms are installed. It makes one wonder what it would be like with NO wiper blades!
Second. In the Falcon 20 the wipers retract into a slot in front of the windscreen. On one particularly cold snowy night, the melting snow accumulated as ice in the slot due to a frozen drain hole. When the chuck of ice left shortly after takeoff, it became FOD for #1 and resulted in total thrust loss (we kept it running for hydraulic power), and an emergency declaration. It was not a fun evening.
With today's modern, miniature, inexpensive (not for certified airplanes, granted) electronics and sensors, I am a little surprised our aircraft are still littered with probes, detectors, vanes, antennas, etc! !
Fly Safe!
SLCPilot
Klaus
Mon May 20, 2013 3:54 pm
Quoting Slcpilot (Reply 21):
Thanks.
keta
Fri Jun 14, 2013 7:27 pm
Talking about probes, I saw that it has what looks like a huge red pitot tube on the left horizontal stabilizer:
Photo © Mike Stewart
Photo © T.Laurent
Where there's a will, there's a way
Klaus
Fri Jun 14, 2013 11:48 pm
Quoting keta (Reply 24):
From the location I would guess it's more for wing and engine effects observation (turbulent flow / local angle of attack).
Viscount724
Sat Jun 15, 2013 12:43 am
DC-8s have been flying without wipers since 1959. They have some type of "rain removal system" using bleed air.
Photo © Kjell Nilsson
Photo © Marlo Plate - Iberian Spotters
Photo © Erik Bentsen
