harrystanhope
Nose Wheel Design On 717
Fri May 17, 2013 5:40 am
Have noticed a few times the nose wheel on the 717-23S has something behind it. After a bit of research I've found to only see it on the 23S models. Much like this QantasLink one...
http://www.airliners.net/photo/Qanta...d=8a1fe4c4ec0b43cdffdc4a233473bd3d
Is it something to do with locking the wheel up in the hold? That's about the only thing I can think of..
rwessel
RE: Nose Wheel Design On 717
Fri May 17, 2013 5:59 am
Unfortunately it's pretty mundane. It's a fender. Keeps the nose gear from spraying water into the engines. On some aircraft there's special ridge molded into the side of (some) of the tires which does the same thing.
Scooter01
Fri May 17, 2013 7:58 am
Also used on some of it's forefathers:
Photo © Michael Carter
Photo © Jason Taperell - AirTeamImages
Scooter01
N243NW
Sun May 19, 2013 4:16 am
Quoting rwessel (Reply 1):
Yep. The industry term (that I've always heard) is "spray deflector." The MD-80 has similar devices fitted to the main gear as well.
harrystanhope
Wed May 22, 2013 5:16 am
Thanks for the replies, although I did think it would be something a bit more interested!   Still good to know they didn't leave the chocks on!
Scooter01
Thu May 23, 2013 1:01 am
Quoting harrystanhope (Reply 4):
You're welcome! -You might find that most A.net members are always happy to please.
For curiosity's sake, you might also like to know that Boeing was offering something similar on the -200 series or their 737 model. It was actually a whole "gravel-kit" that not only consisted of a nosegear deflector,
Photo © Jan Olav Martinsen
Photo © Robert Matthews - FliteZoneImages
but also of a tube that blew bleed-air down in front of each engine to prevent FOD
Photo © THPlanespotting
and a spray(?) deflector between each wheel on the main gears.
Photo © Mark Kryst - YXUphoto
(not too easily seen as most photographers prefer to take photos of the side of an airplane)  duck
Scooter01
[Edited 2013-05-22 18:53:41]
Users browsing this forum: BobPatterson, jumpship and 32 guests
